Question about Kodak EasyShare C643 Digital Camera
Sd card can't be erased because it has been protected.
Have taken many pics and downloaded them elsewhere from my sd card.
This time I went to delete them off sd card and found out that it is protected.
How do I unprotect this sd card so that I can delete the files?
  • 67 Answers
There is a little lock on the side of the card, unlock it.
Posted on Mar 10, 2009
How to delete pics off sd card via my vivicamx040
Format the memory card. This clears all data from the card and prepares it for further use.
Make sure the card isn't protected. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Apr 13, 2013 | Vivitar Cameras
Camper says internal memory is full and i have only taken 12 pics. i think there might be "protected" pics. but i don't even know how to protect pics or to un protect them.
Digital cameras that come with internal memory usually have a very small amount of storage capacity (usually 32 or 64MB). I'm not sure why the manufacturers even bother with internal storage when you can get memory cards that have much more capacity. You need to either download the photos you've taken to your PC and then delete the photos so you can take more shots, or you need to insert a memory card. Depending on your model of camera you need a microSD or SD card. Let me know the model number of the camera and I will tell you what you need to get.
Hope this helps!
Tom
Jul 21, 2011 | Kodak Cameras
My memory card is full so I can't take more pictures. I want to delete the old ones which are saved somewhere in the disk but it only shows the old pics in the camera, only when i put the memory card...
If your memeory card is a SD card then -
SD and Micro SD memory cards has a smallslide switch on the edge of the card, which write protects data on the memorycard. Slide the switch from the READ position tothe WRITE position, which is furthest away from the contacts.You can then delete the phots using your computer OR format the memory card using the camera.
Jul 15, 2011 | Computers & Internet
My Canon PowerShot A430 does not want to unprotect one image. I have tried to go to erase all in the menu, and I have tried to got to protect to see if it will reverse the protection but it does not do...
Reformat the SD card with your computer. This will delete all data on the card. Do you use a usb cable to upload pics to your computer or put the SD card in a media slot? Either way, find the drive that corresponds to your SD card or camera in "My Computer". Right click on it and select 'format'. A new window will open with a check box for 'quick format'. Check the box and click OK. A prompt will appear stating all data will be erased. Click OK. In a few seconds, the card will be reformatted.
Oct 06, 2009 | Canon PowerShot A430 Digital Camera
Power Shot A630 says card locked, will not take or delete pics
There is a switch on the side of the SD card, slide to unlock position then go to the SETUP menu, format the card (before doing that, make sure you have saved all pictures from the SD card to your computer)
this post may help
http://www.fixya.com/support/t2167722-screen_saying_memory_card_protected
May 08, 2009 | Canon PowerShot SD550 / IXUS 750 Digital...
Unable to view pics
Copy the existing photos on to your PC, switch off the camera. Remove the SD card and format the SD-card using a SD-card reader, this will clear all the card contents. Now try using it in your Camera again. Ideally, you should be able to save photos on this SD card. Other way would be to insert another SD card into your camera and click photos and check whether those photos are being saved into the SD card(this can be done using display option in your digicam.)
Dec 17, 2008 | HP Photosmart E327 Digital Camera
How do you erase the SD card from the camera?
You cannot erase the card fromm the camera(You can delete the pic one by one using the delete option though). However you can connect the cam to your PC using the USB cable. The cam will be shown as a drive. Just right-click and click format. As for the flash no, you dont have to hit the flash button for every pic.
Sai.
Nov 30, 2008 | Canon PowerShot S51S Digital Camera
Micro sd card says write protect when inserted what does that mean
Hi , means you connot delete the picture , the only remedy to erase the write protect to format the micro sd , for the next time dont click to write protect .
Mar 03, 2008 | GE E1040 Digital Camera
Retrieving file
There are companies that claim to be able to retrieve deleted files on mem cards, if their space has not been written over by other pics taken sense, or a mem card FORMAT. Google it.
Your better approach may be to try to recover the files showing 3Meg size on your computer download. Sounds like mem card quit working correctly after first 100 photoes. Was this a name brand SD card like San Disk or Panasonic? Beware of off brand junk sold on ebay or other sites CHEAP. They are designed to report back the size they claim to be, but are 1/2 size capacity or less in reality. You never know until you need your photos. The other thing is SD cards fail and are never a good as a BackUp source for files. For file xfers only in general.
Good lesson for all is to be sure all your pics show up on your computer before deleting on camera.
Jan 01, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Pictures mysteriously deleted
Are you sure the pics aren't in a separate folder?
Nov 27, 2006 | Panasonic Lumix DMC-LZ3 Digital Camera
Kodak EasyShare C643 Digital Camera Logo
144 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
