Question about Polk Audio Music
Fried microkorg I purchased a microkorg in japan and plugged it into the wrong power adapter and rapidly noticed that nasty burnt plastic smell. It seems i have fried a resistor and who knows what else. Am looking for a link to a schematic or service manual for the microkorg help please
  • Sandra hoang Jan 20, 2012
    Hey naznoronha,
    I did the same mistake as you...(how stupid i am..).i wanted to know what you did to fix it?and hw much it cost you?
    Thanks a lot for your help in advance,
    Sandra
    My email is hoangsandra (a t ) gmail.com
    Scholar:
  • 109 Answers
A diode or two could need replaced. I can't find a schematic. A microkorg would not be a fun project to take on yourself. Check this page and put your zip code in and check for a repair center (if you are in the US..I don't know if there is a repair center in Japan.
http://www.korg.com/SupportResults.aspx?productid=128
Posted on Jun 20, 2009
My CTK 720 isn't powering on from the adapter anymore but battery power is working. I bought a new adapter but it still isn't powering on. Can this be repaired?
This could be a loose plug inside the unit or it could be a circuit that is bad. If the plug failed it is from physical damage from something like tripping over it or heavy use. That can be repaired by replacing the plug. If it is something like a component in the unit on a board then it becomes a little more involved.
Mar 26, 2016 | Casio CTK-720 Electronic Keyboard with...
Microkorg sounds are off but lights are on and midi works, but i hear no sound it the headphones
Look into all the settings, some of these has a setting to turn internal speaker jacks on and off. I have a casio that can turn them off when playing into the computer.
May 04, 2012 | Korg MicroKorg synth (includes microphone)...
I have a Korg Microkorg XL. The volume control is not fully functioning. It won't get really quiet or really loud.
The volume control must be have dirt in it. When you move it do you hear rustling noise. A quick spray of WD40 spray into the control will solve the problem.
Mar 10, 2011 | Korg Micro Microkorg Xl Synthesizer...
My amp stopped working after 2 days from the day bought it. It stayed on standby for a while, about ten to fifteen minutes, but once I switched it on it started humming and making crack and pop noises.I...
Take it back for warranty replacement or repair since you only had it for 2 days. Since there is burnt smell this could be very serious problem. Probably a fuse blew due to any of several problems.
The pilot light runs off a rectified output of the power transformer but it is fused. There are three sopplies from the transformer and any of those could have a short and blow the main fuse or their individual fuses.
Take it in as I stated as this is NOT DIY repair. There are high voltages in this unit and if one is not adept at electronics you probably would not be able to repair it anyway.
Nov 29, 2010 | Peavey ValveKing VK112 50W Combo Amplifier
What do I need to record/play loops&samples w/microKorg on stage?
I'd recommend a looping pedal as the simplest solution. Check out this link:http://www.recordingreview.com/articles/blogs/67/Confusion-With-Loop-Pedals.html Consider joining. It's free and there is a wealth of good info on gear, Midi, recording etc. Let me know if this helps.
Jan 08, 2010 | Music
Microkorg not turning on
I can tell you what it is from first-hand experience. The audio in LED's coming on and going out means that a power supply putting out more than 9 volts DC was used...or the wrong polarity. Korg sells a repair manual for about $12 but they ultimately need a whole new circuit board. If the wrong polarity supply was used, then maybe only a diode was damaged. This would be a cheap fix. But more than likely it knocked out one of the large surface mount IC's that us techs don't even dare to replace. Korg charges around $280 for a new circuit board. A used working microKorg sells for this much.
Honestly, I would stay away from Korg products and many others. Many companies are now using surface mount components which are cheaper and harder to fix. Moog synths are expensive but they are completely fixable(and are built to last). If Korg would install a $0.25 voltage regulator on the input of the DC jacks, the unit would be saved. I think this pretty much sums up the build quality. This is probably not what you wanted to hear but is how it is unfortunately.
Aug 23, 2009 | Music
Burnt ic chip on Korg microKorg pcb.
Hi Mate, I have the exact same problem, casued by wrong adaptor being connected by accident, did you manage to find what the code is on the IC5 chip ?, I can see NSV, but there is another letter or number before it but cant make it out as that where its burnt.
Jan 17, 2009 | Korg Music
Music Logo
1,134 people viewed this question
Top Polk Audio Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Polk Audio Music Expert? Answer questions, earn points and help others
