Question about OKI MICROLINE 520 Matrix Printer
Oki macroline 520 alarm
Apon switching on of printer, alarm light stays on, and therefore sel button cannot activate, printer has been switched on and off, to no avail, still the same. printer has been cleaned and silver rod has been wiped, but still no response. printer is quite old and has been giving problems of lately, after each print, printer has to be re-set, please advise. asap
  • 328 Answers
Are you using pin feed paper Alot of times I find the paper holes down under the platen and blocking the paper sensor flag. Get a can of compressed air, remove the platen and paper deflector and clean,clean,clean.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Posted on Aug 02, 2007
My oki microline 520 elite is showing alarm and the Character pitch of 15 is flashing
This is a checksum error. I would suggest replacing the main control board
Dec 09, 2010 | OKI MICROLINE 520 Matrix Printer
I have an alarm light onthe display, printer does not want to print?
I have an alarm light onthe display, printer does Problem with the OKI MICROLINE 520 Matrix Printer
Dec 08, 2010 | OKI MICROLINE 520 Matrix Printer
Oki Microline 395 install problem
This printer will print with the Windows Generic/Text driver. It can also be set to print with IBM or Epson FX drivers. Follow these steps:
1. Press on the "SHIFT" Button, while holding it down press the SEL Button. The "SEL" Indicator will light up.
2. On the controll pannel, press the "PARK"
Button. The Printer will print a Setup Page.
The last line that is printed will be what it is
set to - ML or IBM or FX.
3. With the "TEAR" button you can set it to
the driver you want.
4. To save the config you selected, Hold the "SHIFT" Button and press the "SEL" button.
The "SEL" indicator will turn off and save the configuration.
Aug 03, 2009 | Office Equipment & Supplies
Oki Microline 320 turbo alarm light
First, make sure that paper feed switch is set accordingly to the paper path you are using (rear feed, bottom feed or friction). If you make a change, turn the unit off and on.
If it is set correctly, there might be an obstruction on the printer top cover that interferes with the cover sensors. This forces the printer to think that the lid is still open and will signal it as you have described.
The last option will be a damage to the sensors or to the mainboard. This is rare, but if the case, you need a repair center.
Be blessed.
Nov 07, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Oki 520/521 logic boards
Check if the Pico fuse is blown ? next to the heat sink on the transisitor array with the number 2025.if the fuse is gone than the fuse plus the 2025 transistor must be replaced.
Dezzi
Nov 22, 2007 | OKI MICROLINE 520 Matrix Printer
Oki 520/521
Cover on these are often broken causing the two little switch's to not close on left and right of lid
Printer Alarm Light
Your carriage motor could be the problem.
Dezzi
Nov 20, 2007 | OKI Pacemark 3410 Matrix Printer
How do i identify the font settings set in my printer
Your printer is designed to change font and pitch from the front panel. Just press the SEL/MENU button to take the printer offline. Then press the PRINT QUALITY button (to the right side of the panel) to make the lights switch to different fonts. Finally, press SEL/MENU to activate the changes and return the printer to online status. Be advised, these changes will not be permanent. To make a change permanent, you need to read the user's manual which I can email to you. Finally know that Windows does not pay attention to these settings, they are only goog in text applications such as DOS.
Sep 21, 2007 | OKI MICROLINE 520 Matrix Printer
Double Printing
check the printer drvier properties and make sur the defaulf is not set to print 2 copies.
Jun 14, 2007 | OKI MICROLINE 520 Matrix Printer
Oki microline 520
It is likely that a few different things can cause this condition. First suggest looking for the paper present sensor. This is usually an optical sensor with a lever which contacts the paper. If the lever is broken, or sensor defective, an error condition is exhibited, and printer won't operate. There is also a sensor for printhead home position, and perhaps one or more sensors at one end of the platen assembly. Some printers sense whether a lever is set for tractor feed style paper, or for standard single sheet. A NEC p6200 has one, and probably other printers too. Check for the presence and proper operation of these. You might have to remove a cover to see them... As you probably know, dot matrix printers are practically dinosaurs these days. You should be able to pick up a decent Epson or other good model for practically nothing, if diagnosis on your rig is fruitless. Companies began getting rid of these critters years ago.
Jun 05, 2007 | OKI MICROLINE 520 Matrix Printer
OKI MICROLINE 520 Matrix Printer Logo
357 people viewed this question
Top OKI Office Equipment & Supplies Experts
Steve Allison
Steve Allison
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
