Question about Olevia 227-S11 27 in. LCD TV
Remote does not work, changed batteries and still does not work, might need to reset the code. How can I get the code?
Try code 1065; if necessary try 1188,1382
Posted on Apr 28, 2009
My remote battery is died when i am opening the door by key the alarm goes on! what can i doe abouth it?
you can have a shop reprogram the reciever in the car to accept the remote. once the battery is removed from the remote it resets the code it transmit (Rolling code)
Dec 21, 2014 | 2001 Hyundai Elantra
Changed the batteries and it just stopped working ,I get nothing
If you have changed the batteries of the remote control, all setup codes previously it have, been resetted. You have to setup the remote to your TV, by it code, once again.
Jun 20, 2012 | Hitachi CLU-4324UG Remote Control
Remote quit working for litex ceiling fan
after changing the batteries make sure you didn't change the remote code. If you didn't there should be a reset button inside the battery compartment, it may just look like a small hole. Just use a toothpick and insert it into the hole and lightly depress the reset switch.Replace the battery cover and try using the remote again.
Apr 13, 2012 | Casablanca Fan Dryers
Will not operate tv can not turn tv off or on have changed battery 3 times
Good day!!!!
once the battery is disconnected to the remote you need to reset the code....
or set the remote code again...
Thanks for using fixya...
Aug 04, 2011 | Televison & Video
My remote stopped working can it be reset
Hello;
I found the following reference to resetting anything related to the ZN110 remote:
"This remote control works well for all the basic functions on the television: changing channels, adjusting volume, and turning the set on and off. There is not a way to program the TV with the remote control, so if you need to reset the channels after a power outage, for example, you have to do it manually on the TV set itself."
Or it could just be batteries?
Feb 26, 2011 | Zenith ZN110 Remote Control
Changed batteries remote wont work
You need to reprogramme the codes again.Some remotes resets the codes after removing the battery
Thank You
Sep 10, 2010 | Televison & Video
ALL OF A SUDDEN MY REMOTE ISN'T WORKING. I CHANGED A CHANNEL AND NOW NOTHING. CHANGED THE BATTERIES AND TRIED TO RESET THE CODE. STILL NOTHING. HAVE A PHILIP MAGNOVOX. ANY IDEAS?
Take off the battery, open the back of your remote, lift the circuit board, clean the green painted part with cotton balls slightly damp with rubbing alcohol as well as the black thingy behind your remote pad, let it dry put it back together, replace with a new battery and try if it works.
Jun 12, 2010 | RCA RCU403 Remote Control
TV won't change channels or adjust volume
Do you have a universal remote? If the batteries are taken out for a little period of time, the remote will loose the codes and they will have to be reset. You can find the codes by google universal remote codes.
If you have a factory remote that came with the television, than it may be faulty or the sensor on remote or tv may need to be cleaned.
Mar 11, 2009 | Televison & Video
Volume Problem
change battery first by going so you will reset the code to the remote bye taking them out if this does not fix it re program another code from rca code page thompson consumer electronics home page they are rca <<<
Jan 04, 2009 | RCA RCR450 Remote Control
Philips universal remote control cl034
hey i tried this and it worked. hold code search till the light stays lit(it may take a couple of secs ) then after its lit press tv and then keep pressing channel up or down till the channel on your tv changes when does press mute to save the code. also the power button will work to during code search , but i use channel because if you accidentally skip your code you can go back the other way. you might need to take out the batteries then re-insert to reset any previous codes. hope this works for you guys as well.
Mar 08, 2008 | Philips Magnavox Learning Universal Remote
Olevia 227-S11 27 in. LCD TV Logo
79 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
