Question about Dryers
Noise & bumping sound when Maytag dryer is turned on
This occurs when it is first turned on and sort of evens out as the tub picks up speed. It dries the clothes fine.
  • 1 more comment
  • skifferz Mar 10, 2009
    How do I get to the rear drum rollers?
    Thanks! I will try this. Is the "lid" the door that opens to put clothes in the dryer? My dryer door opens from the front of the machine.
  • Anonymous Mar 10, 2009
    Can jumptrout51 or someone else tell me if the "top lid" that jumptrout51 referred to is the lid that opens to put clothes in or a lid to get to the belt and drum? my dryer door opens from the front to put clothes in.
  • Dryers Master
  • 3,361 Answers
Replace the rear drum rollers.
They are worn out.
Posted on Mar 10, 2009
  • steve
    steve Mar 10, 2009
    Raise the top lid on the dryer.
    Remove the 2 screws holding the front of the dryer to the cabinet.
    Remove the front panel and disconnect the wiring.
    Remove the belt and the drum.
    Remove the drum rollers from the rear of the dryer cabinet and replace them with new rollers.
    Re-assemble the dryer in the reverse order from above.
  • steve
    steve Mar 10, 2009
    The top lid on a Maytag is the top of the dryer...not the door.
    2 screws on the bottom right and left of the dryer...near the floor.
    Remove the screws. Pull the front panel towards you and then up.
    Remove the top right and left screws on the dryer cabinet and raise the lid.
    Remove the dryer belt...then remove the drum.
    The drum support rollers are attached to the back wall.
Dryer tub makes noise as it turns. 2000 model kitchenaid clothes dryer. noise occurs while drying. thumping sound.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Aug 01, 2011 | KitchenAid Dryers
Whirring noise on spin cycle
i have had this problem before you need to repace the tub bearing assembly which reqires special tools to do the job and the whole unit needs to be torn apart
Oct 19, 2007 | Maytag Performa PAV2200
My dryer is making a bumping noise, almost ike something is rubbing, It sounds like tennis shoes are being dried. If I put mt head near the bird cage I can hear a little noise. If I grab the tub I can move...
Without a model number all I can do is pass you a generic response. There are 2 sizes of repair kits that include drum rollers (Flat spots on yours) a belt and a drum felt. 27 inch and 29 inch. Having said that... the drum rollers are what are causing your thumping noise. PN: 303373
I would also replace the belt: 31531589 the drum glides 306508 and the drum seals Multi-listing here: http://www.repairclinic.com/Maytag-Dryer-Gasket-Or-Seal-Parts?z=50 also inspect the idler pulley and bearing. Not sure how old your dryer is but by doing the above you should get more than 5 years good service out of your dryer. It is worth the time effort and expense to repair it.
Thanks for choosing FixYa,
Kelly
May 09, 2011 | Maytag Dryers
I have a 2005 GMC Sierra Z71 4x4 that recently started making a loud creaking noise in the front end. It is very loud and occurs instantly when turning the steering left or right, and also is noticeable...
You might want to check the ball joint. None of them have grease zerks and can dry out. They will cause a noise when turning or hitting a bump, if really bad. Hope this helps.
Aug 13, 2017 | 2005 GMC Sierra
Bumping noise while drying
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
Jul 01, 2010 | Maytag MDE9700AYM Electric Dryer
Thumping noise (similar to shoes drying) and burnt smell
that one needs a serviceman to look at it too many variables as to cause
Jan 23, 2010 | Maytag Atlantis MDE6400AY Electric Dryer
My dryer started making a bumping noise when it
Your slides are worn and when you put clothes in the metal tub is now getting tracktion/ making metal to metal contact when it shouldn't and overloading the electric/belt drive. There is a kit to fix the problem but the dryer will need disassebled to put it in. At this time it would also be adviseable to replace the belt and tub bearing as well.
Sep 22, 2009 | Kenmore 65924 Electric Dryer
My Maytag gas dryer is not heating correctly. It gets warm, but takes several cycles to dry even small loads.
one thing u can do remove vent tub,
turn on dryer run for about two min
open door touch inside door if hot
u have a vent problem
May 12, 2009 | Maytag PYG2300A Gas Dryer
Squeeking noise
it could be the bearings going out on the tub from the sounds of it
Jan 24, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Noisy maytag dryer
the blower wheel sounds like it is bad it should be tight on the shaft and not turn unless the tub turns
Nov 15, 2008 | Maytag PYE2300AY Electric Dryer
Dryers Logo
134 people viewed this question
Top Dryers Experts
