Question about Frigidaire FER231A Electric Dryer
Dryer not heating
I have checked the thermostat, the door switch, and the thermocouple. I get good readings on them all, and its still not heating
  • edanielcox Mar 10, 2009
    good power, problem still exists
    element good
  • 188 Answers
Check for 240V at the outlet and check the continuity of the element coil.
Let me know if you still need help.
Posted on Mar 10, 2009
  • Paulo Mar 10, 2009
    Did you check the element for continuity?
  • Paulo Mar 12, 2009
    Hard to say for sure without seeing it but if you've checked for 240V, checked the thermostats and the element The only things I can think of that are left, a loose/shorted wire somewhere in the circuit, or perhaps the temperature switch or timer is defective.
Replaced coils & igniter but dryer won't heat. Tested all thermostats and they read good. Can't see if the igniter is glowing or not.
check psu to ignitor and the main burner valve sets and resets
you can do this manualy by removing the thermocouple and testing the burners does it try to strike??? and doesnt burn or does the burner try to come on then go out if it wont strike perhaps the door catch isnt right you dont give a make model etc details so its hard to even guess,,,?
Dec 20, 2014 | Dryers
Propain gass dyer. runs but very little heat. replaced gas valve coils and no change. Now I believe I have to check limit switches, but not sure how to test..What about the RADIANT SENSOR? NEED...
Hi.
More than limit switches if burner is turning on but heating is poor you should check cycling themostat and then blower motor, lint filter and parts comprised in blower assembly.
When the problem is the high limit, there is no heat at all.
When the problem is radiant sensor, there is no heat at all.
Poor heating means either: defective cycling thermostat; clogged air ducts; defective blower system, problem with timer or temperature selector.
If the heating turns off in the middle of the cycle check also door switch.
Here Cycling thermostat:
The cycling thermostat is located in the blower assembly. Here removal instructions. Disconnect power first:
The thermostat can be tested using a multimeter. Set the multimeter on impedance (Ohms). Good thermostat will read about Ohms at room and will read open (infinity) at 150F.
Once in there also check the thermal fuse and check blower assembly. Remove lint and make sure blower is working. Thermal fuse is tested reading impedance across its two contacts. Remove fuse from circuit and touch with multimeter probes fuse's contacts (same for thermostat). If fuse is good it will read zero Ohms or very little impedance. a bad fuse reads infinity.
Check also the exhaust. Make sure there is no blockage.
Operations are illustrated from page 72 of service manual: Here the service manual.
About the flame sensor, that is a part that rarely fails. If the dryer ignites the radiant sensor is not responsible for the fault.
The radiant sensor is mounted in parallel with the coil.
When temperature is reached the sensor opens up allowing power to burner valve (valve 2). Testing the flame sensor like a thermostat is difficult because it opens up at high temp. I read volts while operating. I suggest users carrying only maintenance that can be performed with power off.
If the burner shuts down at random more than the sensor check the door switch. Run a cycle with door switch contacts jumped.
Start checking cycling thermostat and air ducts, those are problems that usually cause low heating.
Regards.
Ginko
Oct 21, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Dryer runs but does not get hot. Ohmed out the over temp thermocouple on the exhaust pipe is not an open. Ohmed out the heating element is not an open. What else would cause the dryer to not heat up?
Hi tnderbst...
Here are a few things to check:
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor/thermal fuse one at a time by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor/thermal fuse as it is faulty.
If you have an ohm meter then you can test the thermostat/thermistor/thermal fuse,
then you do not have to tape the wires together as described above.
To test your thermostat/thermistor/thermal fuse remove the wires from the thermostat/thermistor/thermal fuse and check for continuity, if you DO NOT have continuity then replace the thermostat/thermistor/thermal fuse.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST AS THIS COULD CAUSE A FIRE BECAUSE YOU HAVE REMOVED THE SAFETY.
Check your blower wheel to make sure it is secure to the shaft and not plugged with lint,socks,etc.
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset.
You can test it with an Ohm meter or continuity checker, remove both wires from the thermal fuse and put the test probes to each of the ends of the thermal fuse, if no continuity then replace the thermal fuse.
A vent clogged with lint can cause it to overheat.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace a generic element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
Please take time to rate me thumbs up
Sep 10, 2011 | Maytag Dryers
I have an amana electric dryer. Will not heat up. i checked thermostat for continuity it is good. i checked the two thermal fuses for continuity they are good. I even jumped a wire accross all three...
Hi pitsburg69...
you have probably already checked some of these...
Check your Wiring
Sep 04, 2011 | Amana Dryers
Kenmore Dryer will not heat up ,heating element reads good ohms on volt and ohm meter. And element not broken, can you help me ?
Hi markprice04...
Check and see if this solves your problem.
Check your Wiring
wire is attached.
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape
or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged
with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
For video and pictures on how to replace an element go to the following website:
This is a FREE answer, Please rate me
Apr 18, 2011 | Kenmore Dryers
Dryer warms up but not enough to dry???vent is clean.is there a thermocouple or what else?
Check your Wiring
wire is attached.
Apr 15, 2011 | Dryers
Dryer want get hot change out the thermostat and hi limiter the dryer get warm but not hot ohmed out the heating element it ohmed to be good but its not heating like it should
Try some of these solutions...
Check your Wiring
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape and running the dryer to check to see if the element is red or not,
or with an ohm meter check the two terminals of the thermostat/thermister
after you have removed the wires, the thermostat/thermistor should have/show continuity across the terminals.
If the coil heats up, or the thermostat/thermistor shows an open circut
then replace the thermostat/thermistor as it is defective.
If it overheats the dryer will not operate properly.
It cannot be reset. A vent clogged with lint can cause it to overheat.
You can test it with an Ohm meter/continuity checker, if no continuity,
replace it)
For video and pictures on how to replace an element go to the following website, it will give you an idea what you are in for:
Jan 05, 2011 | Whirlpool Dryers
I have a whirlpool dryer model LER 7646EQ1 that will not heat. I have looked at the heating element seems to be ok not broken. How do I check the thermostat and fuse to see if they are good.
Check your Wiring
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
For video and pictures on how to replace the element go to the following website:
Jan 01, 2011 | Whirlpool LER4634J Electric Dryer
I have an LG DLE8377NM electric dryer that is spinning great and even blowing air great, but no heat. I read that it could be the heating element, thermostat, thermal cut out switch or it isnt getting...
You will use an ohm meter across the two terminals where the cord attaches to the dryer, and also read the receptical to make sure 220v is getting to the dryer...one hot lead to ground should read 110/120v.
When both leads read 110/120v then that is your 220v.
Here is a little more info for you:
Check your Wiring
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
Dec 27, 2010 | Dryers
Heats but not good
Check your Wiring
Oct 13, 2010 | Estate TEDS840JQ Electric Dryer
Frigidaire FER231A Electric Dryer Logo
206 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
