Question about JVC AV-56WP74 56" Rear Projection HDTV-Ready Television
My tv has no sound, its not on mute and the volume is all the wa
How do i fix this?
I had a similar problem finaly found that the "center channel imput" was in the wrong setting. At the moment I dont remember if it was on or off but go to the menu and on the sound page you should find the setting change it to the other position. Hope that helps I am on the road at the moment and cant go look at mine to see which way I changed it to
Ben
Posted on Mar 24, 2009
My Samsung tv is suddenly muted and I can't unmute. How can I fix this?
The volume buttons have 3 functions... down and up and straight down... that's mute. if that does not fix it go to menu.. the gear icon click on audio, likely we switch to an external sound device like DTS Amplifier...
Tony
Nov 22, 2017 | Samsung Audio Players & Recorders
My TV tuner gets the video just fine, but there is no sound. How can I fix this so I get sound?
1. Check to see if you have a digital television adapter (DTA) or digital-to-analog converter for your TV Tuner that came from the cable company. Using the remote for this adapter or converter, make sure you don't have the sound muted. This seems obvious but I was completely perplexed by the same problem and this was the solution.
2. Open Windows Volume Mixer, which will likely be in the Taskbar, during the time when you ought to be hearing sound from the TV Tuner. Make sure nothing is muted and the program, such as Microsoft Media Center, is not being muted from the Windows Volume Mixer. With Windows 7 it is now possible to mute one program while leaving other programs at full volume.
3. Try different software with your TV Tuner. First try VLC Media Player, and then try Microsoft Media Center, and then try whatever software came with the Sabrent TV Tuner.
Hopefully one of these ideas gives you a breakthrough.
Good luck and thanks for using FixYa.
Mar 05, 2011 | Sabrent TV Tuner / Video Capture Box USB...
I have an LG, LCD TV, I have picture but no sound
some times you have to turn it off, unplug it, wait for 20 secs and plug it in again and turn it on, this would be the last step after trying the remote control thing, you know, check if mute buttom or volume, or the languaje option, good luck, God bless
Jan 26, 2011 | LG 42LB1DRA 42 in. LCD Television
No volume
Look on remote to see if there is one button labeled "mute." If so push that when tv is on and see if that fixes sound. Or find volume buttons on tv and hold down button that is for increasing sound, should show a scale on screen with volume increasing.
Jan 15, 2011 | Toshiba MD20FM1 20 in. TV/DVD Combo
HOOKED ALL MY SPEAKERS UP BUT SUB AND CANT GET ANY SOUND FROM FM OR TV THAT I HAVE HOOKED UP AM I MISSING SOMETHING ALSO THERE IS A LIGHT THAT SAYS SOUND MUTE BY FM
From the remote control ONLY:
Press MUTING to mute the sound through all
speakers and headphones connected.
"MUTING" appears on the display and the
volume turns off (the volume level indicator goes
off).
To restore the sound, press MUTING again so that "OFF" appears
on the display.
• Turning MASTER VOLUME on the front panel or pressing
VOLUME +/- on the remote control also restores the sound.
Dec 22, 2010 | JVC RX-778V
No sound on laptop
Updated the drivers for your sound card? it could be incompatible (not the correct driver) if prior to updating the sound still works.
Dec 08, 2009 | Dell Inspiron XPS M140 Notebook
No sound
On your remote you should have a mute button. Or some will cancel mute when you press volume up or down. Make sure you are using the TV remote and not the cable or dish remote.
Jul 18, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Toshiba Regza 32C3000A tv sound keeps droping out, the mute button when pressed on and then off brings it back on. seems as if the tv is auto muting itself?
Could be a contact piece of the MUTE button from your remote that is causing it.
Go out and Big Lots or Radio Shack to get a cheap universal remote control(big lots would be between $5-$10) Pick up the code for it,and when the tv happens again,your the OLD remote MUTE button to turn it back on and then put away this remote control and use the new universal remote control.
However,if the problem is coming from the manual MUTE button on the TV,you need a repair tech, to fix it!
solutiondoct
Nov 10, 2008 | Toshiba Televison & Video
No Sound Issues
Hello!
Try the audio out. Run the audio to a receiver to see if the audio is there. If it is, then I'd leave it hooked up to the receiver and save yourself some money. If there is not any low level audio out then I'd fix the set. The only Sony set I've ever seen that was not worth fixing was a 32" model from the early 1990's that had bad picture tubes after only 5 years. I am a Sony factory trained tech. Good Luck!
barneyluc
Oct 13, 2008 | Sony KV-32FS13 TV
My volume sounds muted on my 36" toshiba tv, nothing is working
Good day.
Please check on the speakers of your unit. They may be busted.
chris
Mar 20, 2008 | Toshiba 36A40 36" TV
JVC AV-56WP74 56" Rear Projection HDTV-Ready Television Logo
134 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
