SOURCE: what type of motor oil used in 1994 harley davidson 883
harley recomends that you use their oil but i would be carefull because it is a cynthetic now if you were using regular oil what that will do is clean all the old build up out of the motor this can be bad because after time there are pin hole leaks that occure but the build up stops it from leaking but if you use cynthetic you cant go back to regular oil it will gum up on you and ruen your motor so you got to find out what has been put in it. but use a 10-30
SOURCE: 2000 Harley Davidson XLC Sportster 883 won't start
the heat from the bulb being continiuosly on may have melted a wire inside your headlight?
SOURCE: remove rear fender on
The bolts needs to be removed.They are very tight, but actually comes out.---------- Click this link below and follow the step by step instructions:--- http://howtobyme.blogspot.com/2011/06/how-to-remove-rear-fender-on-2006.html ------------------ This will help,.Thanks.Helpmech.
SOURCE: How to install a sissy bar
There are different mounts for a sissy bar. If it is a permanent mount sissy bar it mounts on the side fender braces. If you bought it new, the replacement bolts and shims( if required) should hve came with it
