Question about Epson Stylus Photo R300 InkJet Printer
Printer wont turn on
My kids disconnected my printer my my computer and then plugged it inot thier computer to print. After they reconnected back to my computer I can not get the thing to turn back on
  • Epson Master
  • 419 Answers
First things to check are that the power cord is properly plugged in and the socket it turned on (yes, sounds obvious but has caught me out in the past).
Beyond that, if your cable has a fuse in the plug, check that... try a different power cord and obviously check that the socket does indeed work.
Locating a working power socket and new cable that you know works and then seeing if that gives you any juice is the only other option... If that doesn't work your printer would appear to be in printer heaven.
Posted on Mar 12, 2009
Printer not responding
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Mar 27, 2012 | Lexmark X3650 Printer
Adding my printer back on my computer without the disk
  4. Reboot computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Jan 04, 2012 | Lexmark Z600 InkJet Printer
Wont scan
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
1. Disconnect the printer from your computer.
2. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
Nov 09, 2011 | Lexmark X8350 Print, Scan, Copy and Fax...
Printer not responding to print message order
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
4. Reboot your pc.
Sep 12, 2011 | Lexmark X2600 InkJet Printer
It want print anything!
4. Reboot your pc.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print again.
Sep 12, 2011 | Lexmark C533DN InkJet Printer
Print document system responds document is printing system responds that document is printed but no document is printed. Used troubleshooting for alignment and that works with printer?
4. Reboot your pc.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print/scan again.
Aug 23, 2011 | Lexmark Z816 InkJet Printer
Wont print
4. Reboot your pc.
Aug 21, 2011 | Lexmark X4550 AllInOne InkJet Printer
I got it hook up to my laptop and i wanted to print out 1 or 2 pictures. And it wont print.
4. Reboot your pc.
Aug 19, 2011 | Lexmark X3550 All-In-One Printer
Why won't my printer print after I installed the software? It says its ready but nothing will print
4. Reboot your pc.
Aug 18, 2011 | Lexmark PhotoJet Z705 InkJet Printer
My printer wont work. Its on and everything is plugged in correctly why wont it print it was just fine yesturday.
Turn the printer off. Disconnect the power-cord from the wall-outlet.
Turn the computer off.
Reconnect the power-cord & turn the printer on.
Turn your computer on, and try again.
Nov 30, 2009 | HP Photosmart C6180 All-In-One InkJet...
Epson Stylus Photo R300 InkJet Printer Logo
56 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
