Question about Toshiba Satellite A135-S4527 Notebook
Toshiba Satellite A105-S4048 problem with AC Adapter
When I turn the laptop on with the AC adapter, after checking the BIOS freezes and does not boot Windows. If I turn the laptop in only with battery boot and works normally. If I connect the AC Adapter when windows is working, the system freezes I have already changed the AC adapter and the problem continues Can someone help me?
  • Shoaib Rais
    Shoaib Rais May 11, 2010
    pls consider changing RAM if u have 2 installed try 1 by 1 see if it helps i dont think this power thing is causing problem as far as adapters are giving 19V and around see thru volt meter
2 Suggested Answers
RescueTechLA
  • 2653 Answers
SOURCE: Toshiba Satellite A105-S4048 problem with AC
There's not much you can do. The problem is definately with your motherboard. I'd recommend a bios update, but normally you can ONLY run a bios update if the battery and the ac are both plugged in.
This problem is pretty common among Toshiba's A105 and P105 models.
Besides replacing the motherboard there's not much you can do.
Sorry.
Posted on Mar 10, 2009
My Toshiba Satellite A105-S2031 laptop won.t boot up. When I turn on the laptop the two small lights below F 10 and F 11 light off then the computer turns off.
Try removing the battery (in case it's shorted), plug in the power adapter and boot to bios (using F2, F10, etc). Be sure there are no USB memory sticks connected, etc. If you are able to boot to bios, great! Then, it's a matter of eliminating the root cause: either battery or hard drive. If you don't boot to bios, then you're most likely facing a hardware problem. It may be as simple as an unplugged cable.
If you can't boot to bios, consider connecting an external monitor to rule out LCD display problems.
Aug 09, 2013 | Toshiba Satellite A50 Keyboard
I have toshiba a100 .....i uploaded window7 but i m unable to find its display drive.....help me!!!
Systems: Toshiba A100/A105 laptops
Note: the Toshiba support site recommends strongly a BIOS update:
BIOS update for Satellite A100/A105, Satellite M110/M115, and Tecra A7Posted on: 04/10/2007
Updated on: 04/10/2007 15:51:53
In very rare cases, the battery pack of your PC may stop accepting a charge, i.e., the battery stops working and no longer supplies power to the computer. To minimize the risk of ever experiencing this problem, we strongly recommend that you download and install the latest BIOS by clicking the 'Downloads' link that will appear when you are finished reading Support News.
Try the Toshiba Software Installer for Windows 7(v1.0; 10-16-2009; 31.87M)
found at:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
Dec 15, 2011 | Toshiba Satellite A100...
When I try to boot up my A105 (with battery in or out and AC/DC adapter connected) the battery light flashes yellow 10 times. I've checked the output of the adapter and it is good. Any suggestions?
If you have tested with another adapter with the same results, flashing the BIOS can resolve a power issue.
From the Toshiba website:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/outFrm.jsp?ofId=AskIris&searchString=a105+bios&x=11&y=8
Be sure to look at the ReadMe file.
Hope this helps.
Aug 04, 2009 | Toshiba Satellite A105 Notebook
Toshiba Satellite A105-S4048 problem with AC Adapter When I turn the laptop on with the AC adapter, after checking the BIOS freezes and does not boot Windows. If I turn the laptop in only with battery boot...
Sorry.
Mar 10, 2009 | Toshiba Satellite A105 Notebook
Freezing up
I think you need to do a power cycle. remove the battery and use tha AC adapter alone. If it boots, then thats good. U can try also booting on safe mode by pressing F8. Then re start the notebook in normal mode. If it wont works then i think u need to reinstall windows as a last resort. U need to use TOSHIBA RECOVERY DISK this time.
Sep 05, 2008 | Toshiba Satellite A105 Notebook
Toshiba Satellite Laptop Power Failure (A105-S1013 System Unit)
Okay, lets troubleshoot this:
1)Does your laptop run on battery alone ?
yes )test your jacks continuity to the motherboard using a continuity tester or Digital Multimeter.
a)test between the center contact and the motherboard.
b)test between the outside metal cover of the jack ,and the motherboard.
c)If either of these fails continuity,replace the jack.
2)does your laptop now power up on AC ?
yes)Stop
No)Try the BIOS upgrade.
Feb 10, 2008 | Toshiba Satellite A105 Notebook
Toshiba Satellite A105 PC Notebook
When you turn it on, do you hear any activity? Motors start working, fan spinning, etc…? Try to connect an external monitor and start the laptop. Check if you can get any video on the external monitor. If the external monitor is dead too, try to remove the battery and start the laptop from the AC adapter. It also might be a bad memory module or a bad connection between the memory and the motherboard. Try to reseat the memory module, move it to the second slot. If you have two memory modules, try to remove them one by one and turn on the laptop. Also, try to remove the hard drive and see if you can boot it to Toshiba screen without the hard drive installed.
There is no special button to reseat the BIOS settings. To do it, you’ll have to access the BIOS using F2 button on the laptop start up, but as you have no video, you cannot access the BIOS and set it to defaults.
I
Dec 27, 2007 | Toshiba Satellite A105 Notebook
Toshiba Satellite A135-S4527 Notebook Logo
256 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
