Question about Kodak EasyShare Z740 Digital Camera
Z740 camera help
Wont accept sd card wants to format
  • stormfelix Mar 10, 2009
    i bought another s.d. card still ask to be formatted
  • 68 Answers
If you are not able to find your connecting cable. and i am assuming your need is to transfer the data to comp. Well what you can do is you can take out the memory card and fix it into the card reader (you will get a card reader vey cheap anywhere.). and connect it to your comp. Now your card will work as a flash drive and you can transfer data easily then... Hope this helps you out.. :)
Posted on Mar 10, 2009
Kodak Z740 SD Card Format
Format it on a PC, and try again.
Dec 19, 2013 | Kodak EasyShare Z740 Digital Camera
I have a Kodak Z740 easyshare camera that will not format a 4gb sdhc memory card but will format a 512 mb card why is this
The Z740 works with MMC and SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work with the Z740. You need to use SD cards, 2GB and smaller.
Mar 14, 2012 | Kodak EasyShare Z740 Digital Camera
My Z740 won't format my 8G memory card. When I turn it on - it says memory card needs formatted. I tell it to format - and it just repeats the Memory Card requires formatting message. Rich
The Z740 works with MMC and SD cards. Your 8GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and will not work. You need to use MMC or SD cards, 2GB and smaller.
Feb 14, 2011 | Kodak EasyShare Z740 Digital Camera
Kodak Z740, want to know if the 4GB SDHC card Class 2 will work in the camera...I've tried a 4GB SDHC Class 10 and it won't format, but would a Class 2 work instead?.
Class 10 just means it will read and write information much faster than a class 2 card. The real issue may be that your camera can't use SDHC cards. Check your manual to see if it will only accept SD cards.
Nov 15, 2010 | Kodak EasyShare Z740 Digital Camera
Format my 4 g scandisk for my kodak easyshare Z740 digital camera
The Z740 uses SD cards. Your 4GB card is actually an SDHC card and, while it will fit into the slot, is electronically incompatible. You need to use SD cards 2GB and smaller.
Oct 08, 2010 | Kodak EasyShare Z740 Digital Camera
New battery new sdhc 4 gb card. asking to format. When I go to set up menu, then format, it will not acept card. ??????
Your camera will accept a maximum SD card capacity of 2GB. It simply isn't capable of handling anything of a larger capacity and in particular is incompatible with the more technically advanced SDHC cards.
Your fix is to either replace your camera with a later model or to stick to using SD cards with a maximum 2GB capacity.
Sep 25, 2010 | Kodak EasyShare Z740 Digital Camera
HAVE SDHC CARD 4 GB IT WILL NOT FORMAT
The Z740 takes SD cards. Cards bigger than 2GB are SDHC cards, as you've mentioned. While SDHC cards will physically fit into an SD slot, they are not compatible. SDHC devices will accept SD cards, but not the other way around. it's a hardware issue; you can't fix it with a firmware update. You will have to stay with cards 2GB or smaller for this camera.
Jan 30, 2010 | Kodak EasyShare Z740 Digital Camera
How do I format an SDHC card to use in the Kodak Easyshare Z740
Your camera will accept a maximum SD card capacity of 2GB. It simply isn't capable of handling anything of a larger capacity and in particular is incompatible with the more technically advanced SDHC cards, so there's no way to format them for your model.
Dec 26, 2009 | Kodak EasyShare Z740 Digital Camera
Kodak Z740 camera sd card formatting problem
Remove the card...turn on the camera and go into the menu...find "reset"...follow the on-screen instructions. Then try to format the card again.
Dec 18, 2009 | Kodak EasyShare Z740 Digital Camera
Same as yours
The Z740 supports only MultiMediaCards & SD Memory Cards. 4GB and larger SD cards are usually SDHC (Secure Digital High Capacity) types - and bear the SDHC mark on the label. These cards are not compatible with this camera. Use only MMC and SD cards. SD cards are 2 GB and under - although *some* 4 GB cards are marked as SD too; these cards may or may not work. If you purchase a 4 GB SD (not SDHC) card, make sure that it can be returned if it doesn't work reliably in your camera.
Oct 05, 2009 | Kodak EasyShare Z740 Digital Camera
Kodak EasyShare Z740 Digital Camera Logo
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
