Question about Kenmore 62802 Electric Dryer
Kenmore Series 90 dryer will not run when start button is pushed and released. If button is held down, dryer will run but will not heat.
  • Greg Schmidt May 11, 2010
    1. Check to make sure the coil is not bad in the start awitch. Manual push sends power to the coil which holds the switch closed.
    Gas or Electric??
  • Kenmore Master
  • 8,220 Answers
You have a broken belt.
Posted on Mar 10, 2009
Kenmore Elite Gas Dryer starts/runs/drys only w PTS held on?
push to start button needs replacing,sometimes you can jump that out if you have another switch that starts the dryer when you close the door
Jan 15, 2013 | Kenmore 73952 Gas Dryer
GE dryer starts but..... stops
What you describe is either a failed evenheat board or a failed motor relay.
Please post the complete model number from the machine and I can help you narrow it down. There should be a wiring diagram inside the console with voltage checks also.
Thanks/Mike
Nov 25, 2007 | Kenmore 63932 Electric Dryer
Kenmore 90 series heavy duty model 67902, when I push the start button the motor turns on briefly but when I let go of start button it stops.
http://fixitnow.com/wp/2009/03/17/easy-fixes-for-two-common-problems-with-the-whirlpool-even-heat-dryers/
Nov 27, 2010 | Kenmore Dryers
Kenmore 90 series... you push the start button and it hums but stops when you release the button and there is no movement with the tub
The infinity start button detent has broken.
Replacing the switch will get you up and running again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 01, 2010 | Kenmore Dryers
Runs when PTS held but shuts off when released/no heat
No problem at all.The motor has a start and run winding.Your run winding is bad.The reason you have no heat is the run winding has to run to close the contacts on the motor switch.Replace the motor ,both problems solved. Hope this helps Please rate my response :)
Dec 13, 2009 | Kenmore Washing Machines
When the start button is pressed and held down the dryer will run but when the button is not being held dowm the dryer cuts off. What could that be? It is a Kenmore 90 Plus Series Even Heat Dryer
i would say that it is in the "lockup" circuit in your motor. there is a centifugal switch which moves when it senses RPM of the motor which then in turn closes a set of contacts within the motor housing, thus locking the run contacts to keep your motor running. odds are that the switch, (which moves along the motor shaft) is dry or blocked by debris (lint) that gets caught in the motor housing.
a good cleaning and then a shot of lube on the shaft usuallly solves this problem....
good luck; jay
Mar 21, 2009 | Kenmore 62622 Electric Dryer
90 series will not stay running or heat
DO NOT KEEP THE BUTTON PUSHED IN AND RUN IT...It's the motor relay and the even heat board in the console. By keeping the button in, you're bypasssing a safety feature and could cause fire. It won't heat like that anyway. Repl. the relay witht the small blue wires and the board in the console and you should be fine.
Jan 30, 2009 | Kenmore 659 Electric Dryer
Kenmore Dryer 90 Series will start but suddenly stop...
Hello , Sounds like your motor is over heating , it will run until the sensor shuts it down from getting to hot , it is most likley because the motor is covered in lint and needs cleaned. Hope that helps.
Dec 30, 2008 | Dryers
Kenmore 62802 Electric Dryer Logo
373 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
