Question about Kenmore Washing Machines
Kenmore 80 Series washing machine - loud banging at end of spin
My washing machine makes a terrible banging noise and vibrates horribly at the end of the spin cycle (during slow-down). Every other cycle works fine. Could this be a brake problem?
  • 3 more comments
  • erobert73 Mar 10, 2009
    VersaStyle,
    Thanks for the speedy response. The problem is definitely as you describe. I think I will dig into it tomorrow evening. It has been making the noise for 2-3 weeks, which means that we've done 12-18 loads of laundry. I have three small children and its amazing how much laundry we do. I hope that hasn't been enough to damage the brake and drive tube. I'll let you know what I find. When I mentioned to my wife that it may not be worth fixing on an 8 year old washer, she started talking about buying a $1000 front loader. Of course, she'll also want a new matching dryer. Yikes. I guess I ought to give it a try as long as the parts aren't too expensive. Thanks again.
    Eric
  • erobert73 Mar 11, 2009
    Good call, VeraStyle.
    I have broken things down to the drive block and see that it is worn out. The spaces that the drive shaft tabs engage into are missing. I need to replace the drive block, but how do I remove the drive block from the basket?
    erobert73
  • erobert73 Mar 12, 2009
    VeraStyle,
    I figured out how the remove the drive block. I simply fell out when squeezed with a pair of plyers. I'll get a new drive block tomorrow. One more thing I am concerned about is the tabs on the drive tube. The corners of the tabs on one side apppear to have been bent inward toward the gearcase shaft. This would occur if the tube were spinning in the clockwise direction relative to the gearcase shaft. I read on another forum that the tabs should be bent back into shape such that the will engage in the drive block properly. Any suggestions here? Also, should the shaft be greased as I put things back together?
    erobert73
  • erobert73 Mar 13, 2009
    VeraStyle,
    Thanks so much for your help. I've got it put back together and it seems to be working properly. I don't know how long it will last since I had to bend the tabs back into place a little. I put the new drive block on the drive tube and then bent the tab into the slots. That way I didn't bend them too far and break them off. We'll see how long it lasts. Thanks again. You called it perfectly.
    Eric
  • Anonymous Mar 13, 2014
    At the end of the wash cycles the inside cylinder starts to spin uncontrollably and has a loud banging (marching band) noise, how do I solve this problem?
  • 188 Answers
With the lid open, set the cycle to spin and press the lid switch button with a pen. Wait until the drum gets to full speed and release the lid switch. If the drum makes a knocking/ thumping noise and doesn't stop spinning within 2-3 seconds, the basket drive block is worn and needs to be replaced. (The basket drive block is located on the gearcase drive shaft, under the tub and agitator) If this has been happening for a long time you may need to replace the brake and drive tube assembly as well.
Basket drive block part number is 389140
If that's not it, let me know and I will try to help you further.
Posted on Mar 10, 2009
  • 1 more comment
  • Paulo Mar 10, 2009
    A dozen or so loads shouldn't have caused any damage to the brake and drive tube assembly.
    The basket drive block is about $20. You will need a spanner wrench to remove the span nut that screws onto the basket drive block. They have one here for about $20
    Let me know if you need a walk through on how to replace it.
  • Paulo Mar 12, 2009
    If the brake and drive tube tabs are bent, your best bet would be to replace the brake and drive assembly. You can try gently bending them back with pliers, but I would hate for them to snap off completely. Be careful not to damage the seal in the process.
    Depending on the severity of the bend in the tabs, you may not need to do anything to them. Make sure to line up the tabs to the slots on the new basket drive block and hammer in down completely until the tabs and slots are flush. Inspect to see if the bent edges of the tabs are bent inward further than the width of the basket drive block slots. If they're bent too far in, it may wear the new block out quickly and the same issue will come up.
    When you re-install the spanner nut to the basket drive block make sure to tighten it hard (use the spanner wrench and a hammer/malet.)
    You don't need to grease the shaft.
  • Paulo Mar 13, 2009
    What you did sounds perfect, I would have done the same. Glad to help you out with your machine and your wallet ;)
    All the best and thank you!
Kenmore 80 series spin cycle isn't spining water out
could be defective part or lid switch problem
Dec 10, 2013 | Kenmore Washing Machines
Wahing machine makes a loud banging noise
This could be due to pending failure of the flexible joint beneath the tub
Jan 22, 2013 | Kenmore Washing Machines
My Kenmore 80 series washer won't spin, and it just makes a loud gear grinding noise. What could this be, and how do I fix, in the simplest form please I'm chick... :)
rebecca it is probably the motor coupler. Move or slide ur machine over and if there is ruber filings under it then it is the coupler.
Apr 04, 2012 | Kenmore 24032\24036 Top Load Washer
My Kenmore 80 series washer just started making a loud Aihaiha electrical or motor type noise. This happened during a heavy load cycle. Noise was very loud. When I click to regular, delicate or hand wash....
The following are the reasons for the drum not spinning :-
* Test the lid switch
* Test the timer control
* Test the centrifugal switch
* Test the water level switch
* Inspect the motor coupler
* Inspect the drive belt (belt drive only)
* Inspect under the washer for soot (clutch)
* Test the motor
* Inspect the pulley
* Test the transmission
In the case of loud noises in the machine, the drum bearings might have been damaged and might need a replacement. Also do check the leveling of the machine. Good luck.
Feb 28, 2009 | Washing Machines
Kenmore makes whining noise as it tries to spin
The drive coupling has probably broken. Usually happens when you overload the machine. Easy fix. READ MORE
Jan 21, 2009 | Kenmore 24902 Top Load Washer
Kenmore 80 series 110 washer making loud noise during final spin
Make sure all springs are still in their place tilt the machine back and look under it and you can see them. 2nd all legs must be level as well as the floor.
Dec 21, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore series 80 washer makes loud knocking noise during spin cy
Unless your front loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the shocks that are used to dampen the spin cycle might have been broken or damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
Dec 14, 2008 | Kenmore 24032\24036 Top Load Washer
Washing machine
it could be the break above the transmission. it engages what looks like break shoes when the machine is not spinning. if these are worn down to the rivets then it will make this noise. it requires a special tool to replace.0de7df9.jpg
Jul 14, 2008 | Kenmore 23822 Top Load Washer
Washing machine
This sounds like the brakes have gotten some residue on them and are grabbing way too hard. The banging is the tub stopping too fast and the torque from this makes the tub bang into the cabinet. Just one bang at the end of a spin. Is this correct???
Nov 25, 2007 | Kenmore 23012 Top Load Washer
Washing Machines Logo
3,898 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
