Question about Refrigerators
Defrost timer where is the defrost timer on a crosley frig bottom freezer
  • Ken Bledsoe May 11, 2010
    More then likely it is a pc board that controls the defrost cycle.
  • 27 Answers
Generally the defrost times are located very close to compressor compartment. it can be easyly detected, by its label
Posted on Mar 10, 2009
Have extra older Frig in th garage Mod 596.72232200
Sounds like a intermittent problem with the defrost timer. Sometimes they get stuck. Check continuity of the defrost heater and defrost thermostat. If both are good then replace the defrost timer, that should solve the problem.
May 30, 2014 | Refrigerators
Frig & freezer not cooling enough. Ice forming in back of bottom freezer.
You need to have the defrost cycle checked.( heater, limit stat, timer) If the frig can't defrost air can't move across your coils to cool properly. To temporarily get by until you can get a repairman, use a blow dryer to melt the ice build up. Once melted it will work normally for about 2 days till it freezes up again.
Nov 13, 2013 | Kenmore 73502 / 73504 / 73509 Bottom...
Freezer needs to be defrosted every 3 to 4 days
Let's Try turning the defrost timer clockwise slowly. 67001036 Defrost Timer The defrost timer is item location 12 in this photo HERE and there should be a hole with a plastic plug covering the hole that you place the screwdriver through. Turn timer with a flat head screwdriver slowly until the compressor and fans stop. With fans and compressor stopped for up to 30 minutes the defrost heater should come on. If doing this causes the defrost to take place simply replace the defrost timer. If not then please let me know and I will instruct you on how to change the=> 67001794 Defrost Heater Assembly and the 12001937 Defrost Thermostat Thanks Sea Breeze
Jun 28, 2013 | Refrigerators
The freezer keeps defrosting.....starts to cool down then back in defrost mode again. Also the bottom of the fridge is not keeping things cold anymore. Could you please help me on what could be...
the defrosting mode could a problem with the defroster timer. as for the bottom one if the top is not cooling the bottom one wont either. the freezer fan is what also keeps the bottom frig cool. the defrost timer should be on the bottom frig close to the ligth.
Jan 19, 2011 | Whirlpool ET8FTEXM Top Freezer...
Ice forming on back of freezer , refrigerator side not cooling GE modelgss22wgpe bb
You frig is not going through the defrost cycle. Locate the defrost timer and advance it to the defrost cycle.(one click). Empty the freezer and remove the rear panel. See if the defrost heater is starting to get hot. Located at the bottom of the evaporator. If getting hot, replace the timer. If not getting hot, unplug the frig and check the resistance across the defrost timer(should be a closed curcit when cold) and across the heater. If "0" resistance, replace heater.
When replacing the heater alwarys replace the defrost thermostat at the same time. Will save you work in the near future.
Dec 28, 2009 | GE Refrigerators
Refrigerator not cooling
It could have one of several problems. Is ice blocking the passage from the freezer to the frig? If so, then the problem is, it is not defrosting.
Or it could be it is not turning on after defrosting.
Either case would be a bad defrost timer. You can turn that with a screw driver till it clicks and see if anything happens.
There is a defrost timer, under the frig, accessible from the front. You can turn it with a screw driver. Turn it till you hear a click. If the timer hasn't been turning, that should turn on the defroster, a heating element nested among the freezer coils. Wait half an hour and if it is defrosting, water should be dripping into the drip pan underneath the frig. If so, then replace the defrost timer and you're good to go.
Or if turning the timer makes the compressor come on, then replace the timer.
If the timer is working, then perhaps the problem is the defrost thermostat, in with the freezer coils. When the frig defrosts, the defrost heater stays on until the defrost thermostat gets warm. It should be open circuit while warm. But if it is open circuit while cold, it is bad.
If you open up the freezer coils, use a hair dryer to defrost. That is safer than hot water.
Hope you can fix it.
Sep 16, 2009 | Refrigerators
I don't know this particular frig, but evidently the defroster doesn't work. Frost buildup has blocked the flow of cold air.
If that doesn't make it defrost, then the problem is probably the defrost thermostat, in with the freezer coils. When the frig defrosts, the defrost heater stays on until the defrost thermostat gets warm. It should be open circuit while warm. But if it is open circuit while cold, it is bad and is the cause of your defrost problem.
Aug 19, 2008 | KitchenAid Refrigerators
Freezer works but frig is not cooling
Aug 01, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
143 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
