Question about Danze D301644BN - 2 Handle Wall Mount Sirius Lever Handle Brass Drain Assem
Installed the rough in for the Sirus two handle wall mount faucet as per instructions. But the water value is too long and the sprout doesn't go back to the wall. Values are at the indicated lines through finished wall.
    Genius:
  • 1,605 Answers
Recalculate the distance, taking into account of drywall, tiles.
if you follow the instruction and the valves are at the indicated line, then you should be OK.
take a piece of scrap drywall and a piece of tile lay it next to the rough in just the way you would have when it is all finish. if it is till too far out, then you have to push the pipe backing back to adjust the distance.
hope that helps
Posted on Mar 27, 2009
Do you have a handle set with a 7 inch spread instead of a 8 3/4 spread and model #
Yes we do. how many would you like?
  • Kingston Brass CC543T8 Vintage 7-Inch Spread Wall Mount ... www.amazon.ca/Kingston-Brass-CC543T8-Vintage-7-Inch/dp/B0026ZPI0Y
    • KINGSTON BRASS
    Kingston Brass CC543T8 Vintage 7-Inch Spread Wall Mount Leg Tub Filler with Hand Shower, Satin Nickel in Showerheads & Handheld Showers.
  • Kingston Brass KB967 Magellan II Widespread Lavatory ... www.amazon.com > ... > Rough Plumbing > Faucet Parts > Faucet Handles Kingston Brass KB967 Magellan II Widespread Lavatory Faucet 8-Inch to 16-Inch Centers 7-Inch Spout Reach, Satin Nickel and Polished Chrome
  • images of 7 inch spread faucet bing.com/images th?id=oip.m9aaf750d3da8ce6a24cbe32ef9078ae8o0&w=103&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.m643aef6e35c24789db3419b21dd47a91o0&w=103&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.ma09426c72dcc25d64ff92045ab194af1o0&w=103&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.m9b0dc70d9ab53ad1ecca18fd130db74bo0&w=103&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.m9afd6495c16d35699054f30b9ee4d7e7o0&w=104&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2 See more images of 7 inch spread faucet
  • Water Creation F6-0007-05 Vintage Classic 7-inch Spread ... www.overstock.com > ... > Bathroom Faucets > Water Creation
    • 5/5
    • 1 RATING
    • $409.17
    Shop for Water Creation F6-0007-05 Vintage Classic 7-inch Spread Deck Mount Tub Faucet with 2-inch Risers and Handheld Shower. Get free shipping at Overstock.com ...
  • Apr 16, 2016 | Plumbing
    Adjust handle stop on Metro high arc
    Is it possible that you have installed the faucet incorrectly . Loosen it off and turn 90 degrees facing you so that one way is cold the other way hot.
    May 08, 2013 | Hansgrohe Metro E Single Handle Deck Mount...
    I installed a new 17 series single handle with temperature control unit several monthsa ago during a complete shower rebuild. No that I am ready to fire up the water, I can't get the water from from...
    Remove handle and check temperature adjustment it maybe out. Remove handle and slide little adjustment gear out and move it a 1/4 turn and reinstall it to see if any difference occurs. If it is not set right you want be able to turn water off and possibly cartridge maybe be bad. With it being brand new and it should work out of the box take it back if no simple fixes will work. You want the best and not have to work on something you just bought anyway. Something may have been left off the cartridge maybe seat bad or o ring.
    Aug 01, 2011 | Delta & Single Handle Shower Faucet
    Water is leaking around base of "spout" and
    If you have properly replaced the diverter assembly, there is either a problem with valve or debris was left in the valve from old diverter when new diverter was installed. Disassemble diverter by pulling spout back off. remove new diverter and check valve. Cup your hand over faucet and turn cold water handle on to attempt to flush any debris left behind. Try several times then reassemble. If this doesn't do the trick then replace. Get a quality filtering system and take care of your new faucet by making sure it's dry and polished after use. You won't be replacing your fixtures as often from calcium and corrosion.
    Apr 23, 2011 | American Standard 4271S 'The Standard...
    The cold water handle assembly of my Kohler Stillness wall mount faucet keeps unscrewing from the valve body after a few days of use. I've hand-tightened it as the instructions say to but is there...
    Automotive Thread-Lock compound will secure the parts during normal day to day use-and still allow the faucet to be disassembled for servicing. You will only need a drop or two, don't over do it.
    Dec 31, 2010 | Kohler K-T945-4 Stillness Laminar...
    How to replace sprout seal kit?
    After you remove the handle, the chrome cap should either snap or spin off.It also may come out with the cartridge... There are 3 screws that hold the cartidge in the faucet...take them out and you should be able carefully work the faucet are off of the core of the faucet. Put a little cooking oil on the o-rings after you install the new ones... just to allow the faucet arm to slide on without damage... Hope this gets you dripless!! Let me know if you have a question. K
    Jun 05, 2009 | American Standard 4175.200.002 Colony...
    How to replace sprout seal kit in american standard faucet ?
    just pull straight up,wiggle back and forth,the o-rings are holding it on .
    Jun 05, 2009 | American Standard 4275.550.002 ColonySoft...
    No water to single hole faucet after installation
    the cartridge has trash in it.remove and clean,will work after that is done.
    May 24, 2009 | Danze D222158 Parma Single Handle Hole...
    Hot and cold backwards on a moen shower faucet
    tun off the water.
    unscrew teh allen screw under neath the handle. pull out hteh handle. undo the wall plate and gain access to the cartridge in the handle body. turn the artridge around 180 degree and reisntall all parts.
    Apr 06, 2009 | Moen 3175 Legend One Handle Shower Faucet...
    Danze D301644BN - 2 Handle Wall Mount Sirius Lever Handle Brass Drain Assem Logo
    128 people viewed this question
    Top Danze Plumbing Experts
    john h
    Andrew Bugbee
    Are you a Danze Plumbing Expert? Answer questions, earn points and help others
