Question about Brother HL 5150D Laser Printer
Duplex tray is broken. Where can I order one?
I got this printer from a friend of mine without toner and I haven't get one yet because every time I turn it on, it made a terrible noise. I found out that two of the small "wheels" of what is called "duplex tray" part (according to the manual) are broken. I took out the broken wheels and put back the duplex tray and now it doesn't make the sound; however I assume it won't work without those wheels. I looked on line to get a duplex tray but didn't find one. Does anybody know where to get one? or does anybody know if the printer will work without the "duplex tray" system working properly? I don't want to buy a toner if the printer won't work.
  • 37 Answers
You can purchase it from Brother and the part number is LJ7661001
DX FEED ASSY. The small "wheels" can also be purchased if you don't want to buy the whole unit, but I am not sure which ones you are talking about as there are several in the unit. The printer may print fine as long as you don't print Duplex.
Posted on Oct 10, 2009
Rear cover jammed
Hi madeleine,
1.Press the cover release button and then open the front cover.
2.Slowly take out the drum unit and toner cartridge assembly. The jammed paper will be pulled out with the drum unit and toner cartridge assembly.
3.Open the back cover.
4.Pull the tabs at the left and right hand sides toward you to open the fuser cover (1).
5.Using both hands, gently pull the jammed paper out of the fuser unit.
6.Put the drum unit and toner cartridge assembly back in the printer (press firmly).
Fully close the front and back covers.
Pull the duplex tray completely out of the printer.
7.Pull the the jammed paper out of the printer or the duplex tray.
8.Put the duplex tray back in the printer.
9. Make sure that the Back Cover LED and the Paper LED are off and then, the Status LED lights green.
Still having Problem Then follow Us For
Brother Printer Support
Jan 29, 2014 | Brother MFC-5460CN All-In-One InkJet...
Duplex feed not working
Check the C6200 Device Settings in the properties and make sure that the Duplex Unit is installed.
original?v=mpbl-1&px=-1
Dec 09, 2013 | Brother HL 5250DN Laser Printer
Paper jam printer 3524
Clear the jammed paper as follows.
If the jammed paper is removed completely by using the information in the following steps, you can install the paper tray first, and then close the front cover and the printer will resume printing automatically.
If the printer does not start printing automatically, press the Go button. If the printer still does not start printing, please check that all the remaining jammed paper has been removed from the printer. Then try printing again.
Pull the paper tray completely out of the printer.
Pull the jammed paper up and out of the printer.
Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of the jammed paper from the paper tray. If the jammed paper can not be pulled out easily, turn the jam dial towards you as you gently pull the paper out.
Open the face-up output tray. Pull the jammed paper out of the fuser unit. If the paper jam can be cleared, go to Step 7.
Open the jam clear cover. Pull the jammed paper out of the fuser unit.
Close the jam clear cover. Close the face-up output tray. If the paper jam still cannot be cleared, for HL-5130 and HL-5140 users go to Step 10, and for all other users go to the next step.
Pull the Duplex Tray completly out of the printer.
Pull the jammed paper out of the printer or the Duplex tray. Put the Duplex tray back into the printer.
Push the lock lever down and take the toner cartridge out of the drum unit assembly. Take out the jammed paper if there is any inside the drum unit.
Put the toner cartridge into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically.
Put the drum unit assembly back in the printer.
Put the paper tray in the printer.
Close the front cover.
Dec 21, 2010 | Office Equipment & Supplies
After firmware upgrade the HP 4015x will not boot up with the duplex unit installed. Boots up ok without the duplex. We even reapplied the firmware upgrade.
I had the same problem. HP Pro Support advised me to
deinstall the additional paper tray and the toner.
and reapply the firmware update 3 times.
It sounded stupid to me but it worked!!!
Be sure to use usb connection and wait 30 min between progress.
1 st time - no paper tray, toner, wait 30 minutes
2 nd time - no paper tray, wait 30 minutes,
3 rd time - all together now, wait 30 minutes
I hope this will help you and others,
Arthur
Nov 05, 2010 | HP LaserJet P4015N Printer
How to open drum to remove the jammed paper inside
Hi Good day!! here are the steps how to remove paper jam in brother hope it help's you!!
1. Pull the paper tray completely out of the printer.
2. Pull the jammed paper up and out of the printer.
3. Press the cover release button and then open the front cover.
4. Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of the jammed paper from the paper tray. If the jammed paper can not be pulled out easily, turn the jam dial towards you as you gently pull the paper out.
5. Open the face-up output tray. Pull the jammed paper out of the fuser unit. If the paper jam can be cleared.
6. Open the jam clear cover. Pull the jammed paper out of the fuser unit.
7. Close the jam clear cover. Close the face-up output tray. If the paper jam still cannot be cleared, for HL-5130 and HL-5140 users go to Step 10, and for all other users go to the next step.
8. Pull the Duplex Tray completely out of the printer.
9. Pull the jammed paper out of the printer or the Duplex tray. Put the Duplex tray back into the printer.
10. Push the lock lever down and take the toner cartridge out of the drum unit assembly. Take out the jammed paper if there is any inside the drum unit.
11. Put the toner cartridge into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically.
12. Put the drum unit assembly back in the printer.
13. Put the paper tray in the printer.
14. Close the front cover.
Oct 19, 2010 | Brother MFC-7440N Laser Printer
H5-01 error on sharp AR-M450N
Sharp AR-450 H5 01 Papersensordefective in the fusing unit 02 Fusing unit temperature error C1 00 MC unit malfunction C2 00 TC unit malfunction E7 00 Image Processing Unit error 01 Memory back-up battery dead 02 Laser unit problem 03 HDD defective 10 black level calibration error 11 white level calibration error 13 CCD calibration error 90 Image Processing Unit error F1 00 Lost communication with the Sorter 01 Sorter registration problem 02 Paper transport motor overloaded in sorter 04 Bin position error in sorter 05 Bin position error in sorter 06 Shift sort motor overloaded 08 Stapler position error 08 Stapler overloaded 11 Sorter problems 14 Second shift tray jammed 15 Sorter drive problems 50 Sorter not installed properly 80 No powerin sorter F2 00 ID pattern reading error 02 Toner add mechanism malfunction 31 ID pattern reading error 32 ID pattern reading error 39 Drum thermistor error F3 12 Paper does not lift in the tray 22 Paper does not lift in the tray F9 00 Printer board problems 01 Printer board problems 02 Printer board problems 03 Network card error 04 Firmware error 05 Not enough memory 10 Printer board problems 90 Printer board problems H2 00 Fusing unit temperature error 01 Fusing unit temperature error H3 00 Overheated fusing unit 01 Overheated fusing unit H4 00 The fusing unit doesn't heat up 01 The fusing unit doesn't heat up H5 01 Papersensordefective in the fusing unit 02 Fusing unit temperature error L1 00 Scanner position error L3 00 Scanner position error L4 01 Main motor drive overloaded L6 10 Polygon mirror motor not up to speed L8 01 Zero cross signal error 02 Zero cross signal error U2 00 EPROM error 11 EPROM error U4 02 Duplex not working properly 03 Duplex problems U5 00 Communication with the ADF is lost 01 Registration sensor problem in ADF 02 Exit sensor error in ADF 03 Timing sensor problems in ADF 11 Paper feed drive overloaded in ADF U6 01 Paper lift problem in 1'st optional tray 02 Paper lift problem in 2'nd optional tray 08 Paper feed unit without power 10 PFU paper transport motor overloaded 22 Paper feed unit without power 50 Paper feed unit not installed properly 51 LCT not installed properly U7 00 Main board malfunction U9 00 Op panel problem 90 Op panel problem EE EU Low toner density in the developer EE EL High toner density in the developer FA 01 Memory back-up battery dead PC Key counter not installed
Apr 01, 2010 | Sharp AR-M450N Copier
My Brother HL 5250DN printer has started making a loud clicking sound when it tries to feed paper for printing. It then stops and the paper light starts flashing.
Observe Cautions signs in printer.
Always remove all paper from the paper tray and straighten the stack when you add new paper. This helps prevent multiple sheets of paper from feeding through the printer at one time and prevents paper jams.
1. Press the cover release button and then open the front cover.
2. Slowly take out the drum unit and toner cartridge assembly. The jammed paper will be pulled out with the drum unit and toner cartridge assembly.
3. Pull the paper tray completely out of the printer.
5. Pull the jammed paper up and out of the printer.
6. Open the front cover again.
7. Open the back cover.
8. Pull the tabs at the left and right hand sides toward you to open the fuser cover (1).
9. Using both hands, gently pull the jammed paper out of the fuser unit.
10. Close the back cover.
11. Pull the duplex tray completely out of the printer.
12. Pull the the jammed paper out of the printer or the duplex tray. Put the duplex tray back in the printer.
13. Push down the blue lock lever and take the toner cartridge out of the drum unit. Clear the jammed paper if there is any inside the drum unit.
14. Put the toner cartridge back into the drum unit until you hear it lock into place. If you put the cartridge in properly, the blue lock lever will lift automatically.
15. Put the drum unit and toner cartridge assembly back in the printer.
16. Put the paper tray firmly back in the printer.
17. Close the front cover.
18. Make sure that the Paper LED is now off and the printer is ready.
After clearing paper jam if noise persist printer may need a Repair Tech and parts replacement for broken or wore parts.
Dec 04, 2009 | Brother Office Equipment & Supplies
Hi sir......i have minolta machine 1080......i want to cancel the mark of toner....how?...plz..
Minolta 1080
C000 Main drive problem C001 Main drive speed. Too fast or too slow C004C Fan motor problem C004E Power supply fan problem C0070 Toner motor drive problem C0071 Toner motor speed. Too fast or too slow C010 Drum motor drive problem C011 Drum motor speed. Too fast or too slow C0400 Exposure lamp does not turn on or AE sensor problem C0500 Low fuser temperature during warm-up C0510 Low fuser temperature after warm-up C0520 High fuser temperature C0600 Scan motor drive problem C0610 Lens motor drive problem C0620 Mirror motor drive problem C0990, C0991 Main tray up problem C0992, C0993 Main tray down problem C0994 Elevator motor problem C0996 Main tray shift problem C0998 Tray shift problem C0999 Tray shift return problem C099A, C099b Shift home problem C099c Shift drive motor C0b10 Auto exposure sensor problem C0b11 Paper clamp motor C0b30 Paper aligning motor C0b31 Paper aligning motor C0b50 Stapler motor C0b51 Stapler problem C0b52 Stapler sensor C0b60 Sorter bin motor C0b61-C0b64 Sorter bin movement C0d00 Duplex rail sensor sensor problems C0d20 Duplex home sensor C0d50 Duplex drive motor problem C0d51 Duplex drive motor speed C0F10 Auto exposure sensor problem C0F30 Paper aligning motor C4100 Exposure lamp stays on C0F79 Paper empty sensor problem
Sep 13, 2009 | Office Equipment & Supplies
Cannot print
If this is a 2200dtn, have you checked the duplex turn around tray under the printer? You can access this by removing tray 2, inside on the front left you should see a small green tab which will release a drop down tray. Many times a sheet or even just a piece of paper can get lodged in the sensor causing a paper jam condition.
Nov 21, 2008 | HP LaserJet 2200dtn Printer
Oki C9300 - paper keeps jamming in the 2 same places, reads either 383 paper jam or non paper sense error. All drums and tonners are new, paper is loaded.
your getting a 383 paper jam, find paper in two different places.
See if it's a duplex related problem. print single sided documents, if that works, try printing two sided documents (it'll be the duplexer) if it only fails while printing duplex.
Also, check the back door. Make sure the back exit tray is closed all the way.
You can also have a paper jam in the duplex unit (open the front door), the duplex unit slides out the front. You can easily remove the duplex unit and run the printer without it.
Oct 20, 2008 | Office Equipment & Supplies
Brother HL 5150D Laser Printer Logo
132 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
