Question about Crosley CAWC529JQ Top Load Washer
Washing machine doesn't full up
I set the machine and pulled out the knob. It turns on, water runs into the tub, but it just runs and never fills up.
  • Crosley Master
  • 3,361 Answers
Raise the drain hose and or repair the air gap where the drain hose enters the drain line.
Posted on Mar 10, 2009
My washer fills and doesn't stop. I try to advance it to the spin cycle but none of the cycles work. I changed the lid switch because it wouldn't fill at all. Now it fills and nothing else. Tested...
The fill switch is bad. That's the only "safety" on the washer that will shut the water off after reaching desired depth. To test it, run your machine on the various water levels. For example, start out on the low setting. If the water doesn't shut off after the tub is half full, then it's the fill switch inside the unit next to the tub.
Sep 13, 2011 | Washing Machines
We have a whirlpool LSR7233EZO. When I set the dial where it should fill with water no water runs in but the agitator runs. This happens on any of the load choices. From what I've been able to find out I...
Your problem sounds like a faulty water level switch,not your fill valve. With the machine empty at the beginning of your cycles, the switch should internally be in the "empty" position to energize your fill valve solenoid(s), then when the machine completes the filling to the level selected on your water level knob, the level switch repositions to the "full" position to energize your timer to advance the cycle. If the switch is stuck in the "full" position all the time, as soon as you pull your timer knob out to start any cycle, the machine already thinks it has filled to the desired level, and immediately energizes your timer to advance to the wash step and begin agitation, even though the tub is dry. I will refer you to the following link for a video showing you the fill/switch replacement procedure: http://www.youtube.com/watch?v=bIs9gX0YjxI&feature=related
I hope I've addressed your problem as described
kcomp1863
Jan 20, 2011 | Whirlpool Washing Machines
Kenmore 600 with atc. water temp change
to change water temp when a cycle has started, pull the knob and reset the water temp, then move the dial to the desired setting. push knob in. resolved by trial and error!
Nov 05, 2009 | Maytag MAV5920E Top Load Washer
Hot water stream when tub fills & how full tub gets super wash
there should be a knob connected to your water lines that come from the wall, turn the hot to the left.
Jun 22, 2009 | Estate Washing Machines
Doesn't fill with water - goes straight to agitation.
open the console and find the pressure switch. it has a clear hose attached to it. pull the hose off the switch and turn on the washer. if water starts to enter shut it off and blow through it back to the tub. some piece of junk may have plugged it causing the switch to "think" the tub is full of water. put the hos back on and run a short spin cycle to reset it and try again making sure to run a small load to see if it shuts off properly. if no water enters when hose is pulled off most likely bad pressure switch. keep the lid closed while doing these tests. some units wont work w/lid open.
May 25, 2009 | Whirlpool Washing Machines
Kenmore 80 Series Overflow
We've now had this happen three times and the exact same thing caused it all three times.
If the water level selector knob hasn't "clicked" into one of the given load levels on the control panel(i.e. the knob is in between levels) it will continue to fill until you discover water everywhere and turn the knob until it "clicks" into a level.
As far as I know, it has nothing to do with loose hoses or bad switches, it's bad design. There seems to be no safety mechanism to turn off the water if you over- or under-shoot the desired water level.
Apr 29, 2009 | Kenmore 24032\24036 Top Load Washer
Water runs into tub but does not fill?
be sure the drain hose is not lower than the wash tub this will caust the water to run out, 2nd be sure the drain hose is not pushed to far into the house stand pipe and the there is rome for air to go inbetween the drain hose and stand pipe eather of these will cause the machine to siphon mostly on rince cycle or on the 2nd and third loads you do. last your house drain could be starting to back up fill the washer with water and listen to it drain if you hear a gurggling sound in the house pipe you may need a plumber to cleanthis out for you.
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
The washer overflows with water. help
make sure the water level hose is connected to the tub and the switch,you can remove the front panel to and flip up the top check,let me know now you do-mike
Dec 02, 2008 | Washing Machines
Hot water continues to run after rinse, filling tub overflowing
sounds like you are right the water inlet solenoid on the hot side is sticking remove the hoses and clean th escreen out and the valve try agin with a fill on hot to see if it stops on a small load if not replace the water inlet valve
Mar 15, 2008 | GE WVSR1060A Top Load Washer
Crosley CAWC529JQ Top Load Washer Logo
94 people viewed this question
Top Crosley Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Gerry Harvey
Gerry Harvey
Are you a Crosley Washing Machine Expert? Answer questions, earn points and help others
