Question about Metrik MTA-80 Car Subwoofer
Need to know how to wire my bass tube
Need to know how to wire my metrik bass tube
  • Timothy  Lee
    Timothy Lee May 11, 2010
    two questions
    1) Do you have an amp?
    2) Where do you want it installed?
Replaced battery in truck now I have no sound from stereo. Do I need to reset something??? All lights on stereo are lit and functioning. 1600w amp metrik, cdxgt24o sony stereo
The advisable thing is that it checks the connection to see if coming to this him sign to the amplifier and to check the exits or loudspeakers
Aug 31, 2011 | Metrik MAB-922 Car Audio Amplifier
What size fuses do i need for the 3 slots and im blowing the power fuse its all hooked up right
  • A Metrik MAX-1404 Amp requires 3 20 Amp Maxi Blade Fuses yellow in color.
Regards, Tony
May 23, 2011 | Metrik Amplifiers MAX-1404 Car Audio...
Pyramid PB1500 vs. Metrik Rem. Bass knob????
Yeah it's probably not going to work because it's not even the same brand
Jan 18, 2010 | Pyramid PB1500 Car Audio Amplifier
Peavey 6505+ NO BASS FREQUENCY EQ
HI,
Switch your amp on and leave it in the stand-by mode, you see tubes glowing.
Than you can pull another tube (same type) out of the amplifier and put it in those sockets. If they are also not glowing, there must be a wiring problem.
It very strange that there are two tubes not glowing.
Give it a try, you can do it yourself.
Reagrds Gerard
Aug 11, 2009 | Plantronics Audio Players & Recorders
Subs wont play music
Sounds like your RCA's are the source of your problem. Unplug your RCA's before you turn your car on. You may need to isolate your RCA's and the ground wire on the back of your head unit.
Feb 04, 2009 | Metrik Amplifiers MAX-1202 Car Audio...
Goes into protect mode
Your amplifier is trying to draw too much current. Your battery doesnt have enough power to run the subwoofers. My solution to the problem would be buying a power cap with equal or more power capasity to your current amplifier. The power cap stores a high amount of current so that when your subwoofers hit those low notes that draw a lot of current, instead of taking it directly from your battery, it will use the stored current from the powercap and wont go into protect mode. Also make sure that your connections on the back of the subwoofer arent touching. If you are hitting hard bass notes and the speaker (+) and (-) wires touch, it will short out and go into protect mode. But I dont think this is what your problem is. I am 99% sure if you go with the powercap, it will solve your problem.
Feb 24, 2008 | Metrik Amplifiers MAP-602 Car Audio...
Vrx Bass Tube Built in amplifier
hi there mate, is the sub earthed? sometimes this might be the problem, also check that all the cables are correct in the amp, there should also be a switch on the amp to lower or increase the output, this maybe turned all the way off, the remote lead generaly is usualy the thin blue wire behind the head unit the best way to connect this to your amp remote wire is to simply go to your local halfords etc and get a little wire joining clip. then you can conect them. any other problems please ask
cheers
adam
Nov 07, 2007 | Bazooka MBTA8200 Marine BT Series 200-watt...
Metrik MTA-80 Car Subwoofer Logo
135 people viewed this question
Top Metrik Car Audio & Video Experts
xxxxxx xxx
Are you a Metrik Car Audio and Video Expert? Answer questions, earn points and help others
