Question about GE RM24911 Remote Control
I have GE universal remote and TV is toshiba I am not able to get the code search button on remote. whr do I find tht?
  • Anonymous Mar 26, 2009
    I have a GE universal remote with a Tosiba TV. I need the code
4 Suggested Answers
SOURCE: gemini universal tv remote
I am use the Gemini TV Box, but my tv box driver cd is breckup, so, i required of driver for installation the gemini tv box. plz help to solve this problems.
dipankarcc@rediffmail.com
Posted on May 18, 2008
  • 50 Answers
SOURCE: emerson tv codes for GE RM-24930 4-Device Universal ...
check this site for your codes. (Jasco is GE)
http://www.jascoproducts.com/support/universal-Remote-codes.asp
Posted on Nov 18, 2007
AvioriX
  • 689 Answers
SOURCE: PHILIPS CL034 UNIVERSAL REMOTE
Hi
I am attaching a link that you can obtain free user's manual which contains step by step instructions and code list. Click on the link below
http://rsk.imageg.net/graphics/uc/rsk/Support/ProductManuals/1500115_AD_EN.pdf
Good Luck
Posted on Nov 10, 2008
the q guy
  • 393 Answers
SOURCE: NEED CODE FOR SETTING GE UNIVERSAL REMOTE FOR SONY TV
I found that this website should have all the codes and instructions for most remotes
http://www.xdiv.com/remotes/
or http://www.remote-codes.com/
Posted on May 11, 2009
I have a ge universal remote and my tv is a Magnavox can I find the code for my tv with this remote
You can use code search to find something that works. If a search through all codes stored in the remote fails, you may have to try a different universal remote (such as Philips). All universal remotes do not store all possible codes.
Jul 07, 2016 | GE Televison & Video
We have a naxa converter box with a GE universal remote searching for the code
About 17,100 results (0.72 seconds) Search Results
    GE Universal Remote Codes and Instructions ' direcTutor
    www.directutor.com/content/ge-universal-remote-instructions
    Enter the three or four digit code for your device using the number buttons in the GE Universal Remote. After your code is entered the INDICATOR LIGHT will ...Missing: naxa
    Apex Digital TV Converter Box DT250 code ' ManualsOnline ...
    tv.manualsonline.com/support/...digital/tv-converter-box/code-1082992
    Nov 15, 2008 - Brock Search data: Universal remote control code apex dv converter... 4 I NEED CODE FOR APEX CONVERTER BOX FOR GE UNIVERSAL ...
    Trouble programming Universal Remote to a DTV Converter ...
    www.fixya.com/.../t2045188-trouble_programming_universal_remote_d...
    Apr 21, 2009 - So I'm trying to program my GE Universal Remote to work with my Digital Stream Converter Box but I can't find the codes to do it... If someone ...
    Control It All With Universal Remote Codes - Digital Landing '
Feb 08, 2016 | GE Televison & Video
How do I program a GE universal remote RC 94904-B 1129 to a Toshiba TV?
Your GE universal remote should have a "code search" capability you can use to find a suitable code. Codes are stored in the remote. If a thorough search produces no result, you may have to try another universal remote. Not all remotes contain the same codes.
Sep 19, 2014 | Televison & Video
Hello i have a toshiba md9dm1 tv/dvd combo and i lost my remote I have a universal ge remote none of the codes work Do you know the code for my tv/dvd combo?
hi,
If you remote is a 4 digit one then the codes are
0394, 0924
If the remote is a 3 didgit one then the codes are
394, 902
MANUALLY ENTERING CODES
1. Manually turn on the device (TV, VCR, DVD, etc.) you wish to program.
2. Press and hold the CODE SEARCH/SETUP button on the remote until the
INDICATOR LIGHT lights, then release.
3. Press and release the button for the device you are programming (TV, VCR,
DVD, etc.). For AUX, press AUX then the device button you are assigning to
AUX. The INDICATOR LIGHT will blink then remain lit.
4. Enter the three or four digit code for your device using the number buttons in the
turn off.
5. Aim the remote at the device (TV, VCR, DVD, etc.) and press the POWER
button. Your device should turn off
OK
Aug 03, 2011 | Toshiba MD9DM1 9 in. TV/DVD Combo
I have a ge universal remote and have a toshiba tv dont know codes and how to programe it could you please help?
Which GE universal remote do you have? Does the remote use a 3-digit or a 4-digit code? To program most GE remotes for a TV, turn on the TV. Then press and hold the Code Search or Setup button until the indicator light comes on. Then press and release the TV button. Enter the first code available for your device. The indicator light should go off then check if the remote controls the functions of the TV. Repeat the above steps if the code doesn't work or doesn't control all the features of your TV.
The manuals and code lists for GE remotes are here: http://www.jascoproducts.com/support/universal-remote-codes.asp .
Toshiba 4-digit TV codes are: 0159 0178 0109 0120 0181
.............0105 0049 0095 0170 0260 0358
.............0394 0924 0012 0095 0117 0141
The 3-digit codes are 170, 181 or 641 for Toshiba HDTVs.
Please note that the remote probably only has codes for devices that were released 6 months or more before the remote was programmed. If your TV is newer than your GE universal remote, you may need a newer remote.
I hope this helps.
Jul 06, 2011 | RCA Televison & Video
I purchased a GE Universal remote and I do not know the code to set up for MV20FM4. Please help.
HelloHello
You haven't given the model number of GE remote you have purchased. Yet I hereby give you some universal remote codes for Toshiba TV/VCR combo. Try with these. If you fails to synchronise with; inform me the model number of your GE Universal remote:
Four digit codes for Toshiba TV/VCR combo are: 0260 0358
Three digit codes for Toshiba are: 013/ 049/ 089/ 105/ 109/ 117/ 118/ 120/ 159/ 178
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
OK. Thanks for using Fixya.
Apr 07, 2011 | Toshiba MV20FM4 20 in. TV/VCR Combo
CANT FIDE CODE
Ask them, they are specialized in finding remote codes
Jul 08, 2009 | GE RM24911 Remote Control
Need codes for philips universal remote on a toshiba TV
i don,t know the code to this remote it is a ge universal remote
Jan 06, 2009 | Philips Universal PH301S Remote Control
Program a ge universal remote to an emerson 12" tv
i have a ge RM24911 universal remote but i need the codes
Apr 15, 2008 | GE RM24912 Universal Remote Control
Televison & Video Logo
742 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
