Question about Sony VAIO VGN-NR120E/S Notebook
My sony laptop with windows xp home media center keeps rebooting
The system keeps rebooting and i try everything like safe mode and last configuration that worked.
HELP i cant find my recovery discs.. Will i lose my data?
  • julesinpr Mar 10, 2009
    Thank you. however I did not receive discs with my computer it came already loaded.So what can i do?
  • Sony Master
  • 4,338 Answers
When XP gets into the rebooting mode, you will have to run a chkdsk or do an XP repair. You will not lose your data. But you do need your recovery cd or a WinXP cd.
Take the Windows XP disk. Boot from it, then DO NOT select F2 (automated system recovery) but continue through the procedure until you get to the point where you can choose between installing Windows XP and entering the Recovery Console. Once you get into the Recovery Console, do chkdsk and fix potential errors on your disks! Type chkdsk C: /R at the prompt in the recovery console.
XP repair
When you boot with the Win XP install CD-ROM, it loads a minimal operating system, similar to DOS, but compatible with Win XP. At the first screen you select install Win XP (not Recovery Console) and at the next screen it will find that you already have Win XP and offer to attempt a repair. This repair should not touch your Applications or data; it just reinstalls the Windows files. This is great because when it works you don't need to reinstall all your software.
Lastly, your drive can be taken out of the unit and set into an enclosure or adapter. The data can be saved, the your hard drive can be formatted and programs and data reinstalled.
Good Luck,
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Mar 10, 2009
  • JDTec
    JDTec Mar 10, 2009
    On new Sony laptp, the software the recovery spftware comes on the unit. The customer is supposed to create recovery cd's. But it is not stated clearly in the documentataion, so many customers overlook it. In your case, you would need to order the recovery cds from Sony :
  • 1-239-768-7691
    Toll Free Service: 1-800-488-SONY (7669)
    Hours of Operation:
    Mon - Fri 9:00AM - 10:00PM EST
    Sat 10:00AM - 7:00PM EST
    Sun 12:00PM - 6:00PM EST
  • Good Luck,
  • Joe
Ok my Sony vaio Model #VGN-NR120E keeps restarting on windows error recovery. I try starting in save mode,safe mode with networking, save mode with command prompt, last known good configuration...
HI dmanhd97,
Try this, restart your pc then press f8 continuously, this will take you to safe mode. then after that go to start>run> type in msconfig (windows xp) , and start>search> type in msconfig (windows 7)
this will open up the system configuration under the general tab
select the diagnostic start up then apply>ok>restart
Hope this helps,
thx
banaple
Sep 02, 2010 | Sony VAIO VGN-NR120E/S Notebook
Cyclic boot and reboot after installing SP2
If you have the Windows XP recovery disk you should boot into the disk and do a repair install of the Windows OS. You can also press 'F8' before or right after the Windows XP splash screen comes up and tell it to either boot into Safe Mode or "Boot with last configuration that worked". If you boot into safe mode, go to control panel and programs and uninstall the sp2 installation. Please comment back if you need further assistance. I will be providing a How-To on how to recover a system using system CDs today.
Good Luck,
NOLA Tech
Jan 27, 2010 | Computers & Internet
Laptop restarts over and over
Is it Win XP or Vista? hit F8 and see if you can get into Safe Mode, if you can goto start , run and type msconfig, disable all and reboot.
If you cant get into to safe mode, hit F8 when computer turns on and scroll to Last Known Good Configuration. see if lets you in.
If you are running Win XP and none of that works. You will have to run your XP CD and do an OS repair, just load the XP CD at boot when setup starts hit ( Enter F8 then R) let it do its thing. Hope this helps Good Luck.
Jul 24, 2009 | Computers & Internet
Rebooting constantly
tap f8 as the PC starts up and try the option "Last Known good configuration", if that doesn't work, try to enter safe mode using same procedure and try the system restore program when it prompts you,
Thanks for the feedback
Mar 30, 2009 | HP Compaq Presario V6000T Notebook
Stalled screen, openning 75 windows at a time, dead blue screen
Reboot and while its rebooting keep tapping on F8 to go to Safe Mode. Once in Safe Mode select "Last known good configuration" and press Enter. If that doesn't work continue to go to Safe Mode and do System Restore to an earlier date of before this happened
Jan 31, 2009 | Microsoft Windows XP Home Edition
Keeps cycling between Startup and Windows Screen
On the safe mode page look for the "last known good configuration"
Should work if it doesn't it may be a a lost cause service pack 3 does this a lot especaily on media centre computers
Jan 28, 2009 | Microsoft Windows XP Media Center Edition...
Screen saver freezing
  1. Boot normally and do a System Restore to a date before you deleted some programs
Or
  1. Select a different screensaver
Or
  1. Reboot and keep tapping on F8 to go to Safe Mode.
  2. Once in Safe Mode select "Last known good configuration" and press Enter.
Or
  2. Continue to Safe Mode and do a System Restore to a date before you deleted some programs
Jan 18, 2009 | Acer Aspire 3000 Notebook
After booting process done. Screen goes blank and Keyboard not working only Mouse cursor is dispaly and working on the blank screen in My acer Laptop.
Try booting the system to Safe mode.
To boot to safe mode:
Restart the computer. As soon as the BIOS has finished loading, F8 key on your keyboard. When Windows Options menu appears, scroll to select the Safe mode menu item, and then press Enter.
Select "Last known good configuration" then press Enter.
If that doesn't work reboot again and keep tapping on F8 to Safe Mode and instead of selecting "last known good configuration" select "Repair Your Computer"
Or you can try this:
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
  1. Place your Windows XP set up disk in your CD drive.
  2. Turn off your computer and change your BOOT order to boot from CDs first.
  3. Turn your computer back on.
  4. Press any key on your keyboard when it asks you to.
  5. Press enter when you see a blue screen, one of the options should say, "To setup Windows XP now, press ENTER.".
  6. Press enter to start the windows set up.
  7. Accept the Licence and Agreement and confirm that the setup is searching for current versions on XP.
  8. Press "R" when the set up has found your current version of XP.
  9. Notice that the Set up is deleting all your windows xp files and replacing them. (This will not cause loss of data)
Jan 11, 2009 | Acer Aspire 5610 Notebook
Windows vista home premium service pack one
There are a myriad of problems that could have resulted in this.
1. A virus has shut down your system
2. Memory has gone bad
3. Last software you installed has corrupted the hard drive
Possible solutions:
1. When it is coming up – hit F8 (over and over again) till the menu comes up :
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
See if you can get in safe mode. IF NOT – repeat these steps, and instead of clicking on Safe Mode – Click on “Last Known Good Configuration”
IF THAT does not work:
Insert your recovery CD and see if you can boot up to that.
If THAT still does not work, you have a hardware problem, either memory chips (RAM) or your Hard Drive.
Jul 16, 2008 | HP Media Center m1080n (PC099A#ABA) PC...
Sony VAIO VGN-NR120E/S Notebook Logo
311 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
