Question about GE Ovens
Oven element for older GE model J D14Y1WH
I cannot find the part # for the lower element for an older GE wall oven model J D14Y1WH. thanks
  • rlmkjones Mar 10, 2009
    I have the plate in front of me and it has on it
    J(space)D14Y1WH serial# is EYD90336
    Thanks
  • steve
    steve May 11, 2010
    For help, please correct your model number.
  • GE Master
  • 3,361 Answers
Still can not locate a part number.
Unplug the range.
Take the element out and take it to an applince parts store. They will match it up with the correct element.
Posted on Mar 10, 2009
How do I replace the bottom element of my GE oven?
Hundreds of GE ovens, so can't give procedure, but problem is not necessarily the element - could be switch, connection to element, etc. Google GE (model #) lower element not heating.
May 27, 2016 | GE Ovens
I have GE model#JKP45WOP2WG double oven wall unit. Lower oven isn't heating up properly. Bottom of lower oven doesn't seem as hot as the top of the oven... replaced oven sensor, not
Most double wall ovens are technically two separate oven boxes. The lower oven box has its bake, boil elements, high limit thermostat and ofcourse its own oven sensor. If the lower oven box boil is working good and less heat on bake feature may suggest that the bake element is burned out and only getting preheated with boil element. Just a suggestion here
Dec 05, 2014 | GE Ovens
I need to replace the lower heating element in my older model oven. I think the serial number is 316071601. How do I remove the old element? I am clueless at repair but this should be relatively easy to do...
YES IT IS EASY BUT UNPLUG IT FIRST. REMOVE THE SCREWS FROM THE BACK WALL ABOVE THE ELEMENT AND SLOWLY PULL THE WIRES WITH THE ELEMENT THROUGH THE WALL ABOUT A INCH AND DISCONECT THEM FROM THE ELEMENT
Jan 12, 2010 | Frigidaire Ovens
Heating element is broken - lower (baking) element. What part do I need and is this user-serviceable?
With the model number you can order a new element from repairclinic.com
You can remove it by pulling the oven out from the wall, unplugging it, removing the rear panel, and then disconnecting the element and swapping it out. Fairly simple for anyone with patience.
Let me know how this works out for you.
Benjamin
Jan 10, 2010 | GE Ovens
Lower oven element doesnt work
You can usually tell when the element itself burns out. It might have small holes or bubbles on the coil. Replace the element, if found defective.
It will , also, show no continuity when measured with a meter as well.
Jul 12, 2009 | GE Ovens
Install bake unit in GE wall oven model JKP07J
I honestly believe you are right. you should be able to wiggle it back and forth and pull it out.
Dec 27, 2008 | GE JKS05 Electric Single Oven
Electric Oven doen't heat
cdkd, there should be a TC0, on the back of the oven. Thermal cut out. You want to check to see if it is open. You will have to pull the oven out enough that you can remove the back panel cover and check it. The lower and upper oven should have one. It's a very cheap part to replace. If this TCO fails, no heat. Check this first before buying a new board. Catriver..post back.
Nov 17, 2006 | GE Profile JTP56 Electric Double Oven
Ovens Logo
167 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
