Question about Kenmore 22422 Top Load Washer
I have a sears 7o series washer...it is full of
I have a sears 7o series washer...it is full of water...it buzzes when you turn iton...at times it will try to spin for a couple of seconds...is there a way to get the water out short of baling...
  • Kenmore Master
  • 3,361 Answers
Bail it out.
Then replace the water pump.
Posted on Mar 10, 2009
I purchased a Bosch 300 series from Sears. My son was home when the technicians installed the washer and dryer. They connected cold water pipe with the hot water hose and the other way around. The mac
Hello Ion;
My name is Peter. I am a retired (excuse the expression) Sears field service appliance technician.
First, The people who installed your appliances are not technicians. Sears contracts delivery people to deliver appliances.
Often, It is not uncommon for me to make service calls the day after an appliance has been installed.
First, shut both the hot and cold water supply valves off. Remove the connection hoses from the valves. Be careful, where I am going with this is, after years of not being operated your shut off valves my be bad and partially block with rubber seating material. So, when you turn off the valves some water will still be in the lines. Your valves could be turned off, faulty and full open.
Now, with the hoses removed, open each water valve. Check for full flow. If you have a blocked cold water valve you will get an error code.
Next, the connections on your washer are marked; 'C' & 'H'. Make sure you have the hot water line to the 'H' and the cold water line to the 'C'. You will get an error code if the lines are reversed.
Nov 11, 2014 | Bosch Vision 300 Series 6.7 cu. ft....
My Kenmore washer (series 90) stopped working in between the rinse and spin cycles. It will not drain (half full as we speak), agitate or spin. It will fill with water but once it reaches the proper water...
Something stuck in Pump. Pump on your model is driven by washer motor, so if Pump can't turn, motor can't work and will hum until it overheats and shuts down.
Sep 28, 2017 | Washing Machines
My Sears series 80 washer fills till it is overflowing and doesnt shut off water flow, it was overflowing onto floor this morning, it is full to the rim now, and wont drain or do anything when it is turned...
The usual arrangement is there are 2 electrical water inlet valves, one for Hot and 1 for Cold. These valves are turned on by the timer, and remain on until the water level switch turns them on, and allows the washer to then run. It sounds like this water level switch is bad. This switch should be in the panel above the top of the washer, and has a rubber/plastic tube that goes toward the washer drum. It is also possible that the rubber tube is off or blocked. (if the water inlet valve is stuck open, turning the washer off will NOT stop the water).
Good Luck,
Bill
Aug 17, 2012 | Kenmore 23822 Top Load Washer
80 Series Kenmore Washer, No draining or spin cycle
It does sound like a controller problem. Go to: SearsPartsDirect.com for parts diagrams and part numbers.
Nov 02, 2009 | Kenmore 22422 Top Load Washer
I have a sears series 90 top load washer. The
The best way to unclog your dispenser is to pour hot water into it.
Aug 15, 2009 | Washing Machines
Kenmore series 70 washer doesn't fill
check your incoming water supply, the buzzing sound is coming fromthe waterinlet valve , soundslikke its trying to fill. possible that the valve is no good as well,
Nov 23, 2008 | Kenmore 22422 Top Load Washer
Will not advance to the rinse and spin cycles...
The buzzing can only be that the pump if sticking or the inlet valve is sticking, other than that it is lack of water supply. Regards Advisor
Aug 23, 2007 | Kenmore 2.1 cu. ft. Portable Top Load...
Kenmore 22422 Top Load Washer Logo
35 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
