Question about Sony KDS-60A2000 60" HDTV
I have a sony KDS-60A2000 that wont poer on
I was getting the 5 blinking light code that said the ballast was bad. I purchased one from Partstore.com and replaced the board only to get the same 5 blinking lights. I saw other forums say it could be the bulb so I ordedred a bulb and know I get a continuous blinking red light. The tv powers up for 4 or 5 seconds (nopicture) then clicks off and begins the continuous blinking.
  • 13 more comments
  • Freddy Torres Mar 10, 2009
    With the new bulb in place my lamp red light blinks consistently. When I put my old bulb in I get the 5 Consecutive blinks saying the ballast is bad. i have replaced the ballast and the bulb. Someone said I need to reset the TV how do I reset the TV
    Where do I find the signal board and what do I look for.
    The new bulb is a Phillips P22-100/120W 1.0
    The bulb is a brand new Phillips bulb from Partstore.com
    The TV doesnt power on so I can not access the Menu
    I noticed that the 5 blinking red lights comes from the power led when I have the old bulb in. With the new bulb i get a constant blinking light from the lamp led.
    Partsstore online sent me a bulb phillips P22 as a replacement for the XL-5200 is that right
    Is it possible to have a faulty IC on both the old and new ballast
    I am new to fixya so I cannot see any previous solutions.
    Is there a way to test or self replace the color wheel.
    I cannot find any info on a Sony Color Wheel. Most sites state that these 2006 Sony models did not come with a color wheel.
    The lamp fan turns on for 3-5 seconds then shuts off
    I will try to contact Partstoreonline to exchange the bulb
  • Freddy Torres Mar 11, 2009
    I unplugged the main power wire from the ballast and then plugged the TV back in and it does the same thing.
    I have become so familiar with this tv as as many times as I have taken it apart and put it back together. I have checked every connection multiple times. I am trying to see if I can get a replacement bulb and Ballast from Partsstoreonline.
    Scholar:
  • 124 Answers
Go here. Follow instructions.
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C461251&sliceId=1&docTypeID=DT_KNOWLEDGEARTICLES_1_1&dialogID=77882474&stateId=0%200%2077884777
Hope this helps just in case i will keep looking.
Good Luck! Please rate & MSG back if need to work on problem further.
Posted on Mar 12, 2009
    Genius:
  • 1,239 Answers
Hi you already told you checked both lamps new and old,,,,then it is definitely lamp driver or the circuit resistors problem...no use in hard reset or cold reset...beter to check them both
other than than these two there will be no problem,,,thank u
Posted on Mar 11, 2009
  • Sony Master
  • 19,396 Answers
Five blink was "Lamp driver error".
Ththat means that it was detected a faulty lamp driver (aka power block , or ballast board).
You can get same error because of a defective lamp, that was the real problem in your case.
Now that the you replaced the lamp the TV starts , but goes immediately in general protection error state, this probably in consequence of a bad assemblage either of ballast board or bulb, as this error did not come up before (continuous blinking).
    Master:
  • 497 Answers
Hi..my guess is that u have a lamp driver problem..try to re install it..hope this wrks for u
Thanks for using Fixya
  • 4,234 Answers
Unfortunately, the diagnostic codes are generic indicators only. This can be caused by a bad part or a poor cable connection. Since you have purchased the parts already, try re-installing them paying particular attention to any cables or screws. These sets have many interlocks that must be activated in order for the set to turn on. If the part is not entirely seated, the interlock will not be activated and the set will report a problem. Re-instlall the ballast, the lamp and make sure that the access doors are fully closed.
Keep us posted.
Dan
Posted on Mar 10, 2009
  • ABRsvcs Mar 11, 2009
    If the reseating has had no effect as you report, then I would guess that you received a ballast that was DOA. While rare, this does occur. The partsstore should be willing to replace the part at no cost to you. They may request that you return the initial one first.
    Keep us posted.
    Thanks,
    Dan
    Scholar:
  • 164 Answers
Hello There
Don't you just love modern technology?!! Panasonics have the same problems. The problem is a power supply problem. In particular some of the IC's on the power supply board die due to what they call dry solder problems. In short the power supply/circuit board needs to be changed.
Not sure how long you've had the TV but it might be worth doing a rapair cost analysis to see if you would be better off with a new TV.
Hope this helps
  • 15,935 Answers
5 blinks does mean "Lamp Driver is Faulty" and usually indicates a bad ballast.
It is not uncommon for a ballast to fail even when it is new.
This is indicative of another simultaneous problem.
2 flashes - Temp Over - (lamp heating abnormally)
3 flashes - Lamp Cover - (lamp cover not attached correctly)
4 flashes - Fan Error - (fan power not supplied or connected properly)
5 flashes - Lamp Driver - (lamp driver faulty)
6 flashes - Power Error - (D5V is not supplied)
7 flashes - Audio Prot - (speaker line is shorted)
8 flashes - Power OVP - (7v is over voltage)
9 flashes - Device Error - (temp sensors, Bus decoder ICs...)
Open the lamp door and try to power on unit.
Thanks for using FixYa
    Sergeant:
    Champion:
  • 289 Answers
Hi..AKB circuit (automatic kine bias), the timer/standby
indicator blinks for about 30 seconds then goes to the
self-diagnosis function. Something is wrong with the
video. Check video out, Q705, 732, 761 and other
components on the C board, also check Q218, 219, 220
on the A board. In addition, unit could be in IK blanking,
try turning up screen slightly.
try this out..
thank u..
  • 70 Answers
It has to be something with the circuits there is probably some kind of moisture or corrosion on the main board or the circuit board, I have a Mitsubishi 72in HD tv and it does the same thing it just continually blinks and wont power on a certified repairest came over and said that there was moisture on the circuit board. hope this helps.
  • Cameron Keller
    Cameron Keller Mar 10, 2009
    the lamp hums and buzzes when u go to power it on its the board or circuits.the bulb needs to be replaced also.
  • 10,594 Answers
You should ask Sony XL-5200 bulb from Part Store and return compatible bulb.
Sony DLP TV does not have color wheel thing inside.
5 times blinks represent problem in Lamp (bulb) driver circuit and in my opinion, Philips bulb is not compatible with your Sony TV. so please demand original XL-5200 bulb.
After replacement of bulb, make sure that lamp door is seated properly.
need further info, write as comments.
  • Shahid Electronics
    Shahid Electronics Mar 10, 2009
    I will pray for your TV.
    Shahid Electronics Mar 11, 2009
    Please ask original Sony ballast supply and lamp from parts stroe online to resolve this problem.
  • 294 Answers
TRY TO RE-INSTALL YOUR LAMP COVER SOME TIMES IT MIGHT NOT BE SCREWED IN RIGHT CAUSING THIS OR IF YOU DID'NT PUT YOUR FRONT COVER ALL THE WAY ON THEN IT WILL CAUSE THIS TO HAPPEN ALSO TRY TAKING YOUR BULB OUT AND RE-INSTALLING IT.
  • JEFFrey BAKER
    JEFFrey BAKER Mar 11, 2009
    re-install the lamp cover when not installed right it wont let the lamp turn on also the cover for your t.v. has a switch that when putting the front cover on it pushes in the switch letting the t.v. know that its on make sure this is on tight if not then the t.v. wont power on if your not getting any blinking codes then its one of these 2 things also make sure the connectors for your lamp are on tight i had this problem when re-placing mine and i had the same thing just the blinking stand by light till i took the lamp out and re-installed it
  • 611 Answers
Change the picture tube
  • 790 Answers
Hi
Maybe you have defective power oscillation or you have leak capacitor
Thanks!
  • carlos fernandez Jr.
    carlos fernandez Jr. Jun 10, 2009
    Hi
    the best ay is to set in to service mode to see what happen in your unit!
    Thanks!
    President:
  • 1,952 Answers
Open up the back and adjust the top control on the flyback transformer by turning it clockwise just a bit until the picture returns. This should only take a slight turn. The flyback is the large part with the red wire coming out of the top. Be careful as there is high voltage in that area. If the picture comnes on and stays on, then the tube is starting to fail. This adjustment is just a temporary "fix" and will buy you time to look for a replacement set.
  • 1 more comment
  • mohammed marika thambi
    mohammed marika thambi Mar 10, 2009
    There should be a 3-way splitter type of thing at the other end of the
    red wire from the flyback. That should have the adjustments on it for
    each tube. Try each one, one at a time. The one that kicks in the set
    will be the tube that is starting to fail.
    This mught be an indication that the picture tube is failing
    mohammed marika thambi Mar 11, 2009
    ya ........sure ....... contact Partstoreonline to exchange the bulb
  • 58 Answers
Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
and if i helped u solve ur problem in any way...please help me by clicking on the fixya rating..
thank you.
    President:
  • Sony Master
  • 1,779 Answers
First thing I need you to do is, while your behind the set and close to the area of the ballast, have someone turn the set on and you listen for the ballast trying to start, it will sound like an arcing sound, and also the fans are running. Make sure the lamp door is secure. If the fans are running but you don't hear the ballast trying to start then I would assume without being there that the Color Wheel is not turning, which is probably bad. The first thing in that section to start is the color wheel, if that's ok, then the ballast and finally the lamp and that's it. The reason could be for the same blinks meaning the ballast, is the color wheel must start first if it does'nt the ballast won't and the micro detects it didn't start, giving that code. Let me know if you need further help!
  • 1 more comment
  • Jim Krause Mar 10, 2009
    Did you hear the ballast try to start and fans running?
    Well, since the inception of DLP sets ( Digital Light Processor) they have used what is called a light engine which has a color wheel. In the past year Samsung came out with a LED version which eliminated a color wheel and Mitsubishi came out with laser which did basically the same thing. All of our suppliers are selling the optics block for your set which we found incorporated everything including the DM. (digital module). I am curious to know what type of light processing system you have since your friend at sony says you have no color wheel.
    Did you also make sure the lamp fan is running, try giving it a spin and see if it starts.
    Sergeant:
  • 300 Answers
Its the faulty ic on the ballast board thast causing the problem.the number of ic is I489JR that ic is gone faulty,so the bulb is not getting resetted how much you try.just replace the ic and it will be fine.other wise get it replaced from near by repair center.as the cost of new ic is not more then $5.
thanks.
  • 201 Answers
I don't think this will help you much, but if you'd like to try it:
To reset your tv to factory settings, Hold down the 'up' arrow on your remote control, press the 'power' button on the tv, release the 'power' button, then release the 'up' arrow on the remote control. The tv should turn off, then on again with intitial setup.
I hope your Philips was the equivalent of the Sony XL-5200.
  • 10,515 Answers
Lets talk about reset Tv.
There would be 2 ways :-
1. Combination of buttons on remote.Refer maual.
2. Unplug the cord for 4 hours and it would reset tv when you plug in the cord after 4 hours.
Now, in regards to 5 blinks...
Five blinks may have to do with the AKB circuit (Automatic Kathode Biasing) or control of the bias on the picture tube guns.
There is a nice discussion about the circuit
http://www.agoraquest.com/viewtopic.php?topic=15966&forum=34
though it's for sony KV-32FS17, it's the same circuit for your Tv.
If you know how to get into the service mode (www.fixyourowntv.com) and are brave you may hunt around for the AKB adjustment and see if that will help. I don't know if this model even has an AKB adjustment like the bigger sets do; this one may be fixed at the factory.
The best i can do for you to arrange a service manual for a similar model....
http://www.schematicsforfree.com/archive/file/Sony/Video/Sony%20KV32FX20%20Chassis%20BE3E%20Service%20and%20Schematic.pdf
Its around 8 mb. Go to page no. 7 to look at AKB circuits.
If you are satisfied, Do rate this solution as Fixya.
Thanks for using fixya.
  • 5 more comments
  • taran_2005
    taran_2005 Mar 10, 2009
    the replacement is right.However, i seriously doubt the AKB circuit because that's the main component that might affect your picture, you must be aware of.
    thanks.
  • taran_2005
    To check whether there is a faulty ballast or not, we can go for troubleshoot.
    Download
    http://www.canlyte.com/pdf/FAQ-Ballast%2...
    Thanks.
  • taran_2005
    Sir we really value you as a customer, however all the options have exhausted from ballast to AKB. I would advise you to call technician, because we have discussed all options and you are not satisfed with any solution.
    I don't believe so there is much left that we can discuss, One of the experts earlier discussed about IC and you denied that solution.
    Kindly read all the solutions. If your problem would be solved, Great!!!
    Unless call customer care - Sony.
    Take Care.
  • taran_2005
    Solution that was initaially offered by an expert
    its the faulty ic on the ballast board thast causing the problem.the number of ic is I489JR that ic is gone faulty,so the bulb is not getting resetted how much you try.just replace the ic and it will be fine.other wise get it replaced from near by repair center.as the cost of new ic is not more then $5.
    thanks
    I hope this would solve the concern.
    Thanks and do rate the solution.
  • taran_2005
    Yup,
    You can get a new repalcement color wheel which comes with free instalation instructions and INdexing proceedures. Heres the link.
    http://servicemanuals.vstore.ca/
    Thanks for using Fixya.
  • taran_2005
    I know its contadictory. But i have got this link from sony forum.
    Few post said sony and jvc do not have any colour wheel....However, few posts , experts told that there is a way to rectify that.
    let me call my friend who is working in sony, and i would tell you within few minutes.
    Thanks.
  • taran_2005
    Thanks for your patience and i confirmed the same.
    There is NO colour wheel in sony HDTV.
    Thanks.
  • 94 Answers
Its your power supply
  • 583 Answers
This is the procedure to reset  1. With the TV on, press and hold the MENU button on the TV front panel.
2. While holding that button, press and hold the MENU button on your remote.
3. Hold both buttons for ~5 seconds until the service menu comes up on the TV.
4. Release the remote MENU button first, then the TV MENU button.
5. Press and hold the ENTER (or OK) button on the TV front panel.
6. While holding that button, press and hold the MUTE button on the remote.
7. Hold both buttons until the Lamp Life Hours show up on your TV screen.
8. Release the MUTE button first, then the ENTER button on the TV front panel.
9. Make a note of the lamp hours if you want.
10. To reset the lamp hours, press the SELECT button (the one between the four arrow keys with two concentric circles on it) on your remote.
11. It will ask you to confirm the reset--press SELECT again to confirm.
To verify you've reset the hours, you can repeat steps 1-9 above and then just press the EXIT button on your remote.
or other system  Mute + 1 + 8 + 2 + Power.
Your TV set should now say “Loading Factory”.
Browse down to “Option” then press Enter (or the right cursor button).
    Brigadier General:
  • 8,619 Answers
Try resetting the unit by going into service mode as errors doesn't get cleared after replacing the faulty part
Clearing/Reset is done by going into the service mode ( press display,then channel, 5, volume plus, then power) then press 8 and Enter, which will return everything to the factory preset condition.
Please ask for further clarifications.
Thanks
Rylee
  • Rylee Smith
    Rylee Smith Mar 10, 2009
    Remember when you follow the above procedure TV should be off.
    And after, it has entered the service mode,
    Use numbers '1' and '4' to select the item to adjust
    Write down the old value in the corner.
    Use the '3' and '6' to adjust the value of the data.
    When you have made all the adjustments you want press 'Mute' then 'Enter' to exit.
  • Sony Master
  • 1,800 Answers
U hear like a metalic sound right.
its the bulb and bulb housing is defective.
re-replace it again
    President:
  • 987 Answers
The projector bulb has gone out you need to replace it.
  • Sibananda Mar 10, 2009
    Either bad capacitors -vented - on power supply board or bad E2P eprom
    board on DM board.Probably the capacitors-4-1000Ufd and 2-3300ufd.You
    should get expert help from reputable tv shop.Not really do it yourself
    fix either way.
  • Sony Master
  • 13,433 Answers
Just to check, is the lamp the matching model? do the model numbers match? or partnumbers?
  • 6,784 Answers
Its the signal board. check the components on this board
  • 916 Answers
Sony has provided a"self-diagnosis function" with your TV, that in the case ofabnormalities or problems the LED or red blinking light on theTimer/Standby indicator flashes a number of times to indicate theissue. Here are the values of the various blinks.
  • 0 times,Diagnosis: Power does not turn on. Possible causes include: Power cordis not plugged in, Fuse is burned out (F6001) (G board). Symptoms ofthe problem: Power does not come on, No power is supplied to the unit,AC power supply is faulty.
  • 2 times,Diagnosis: B overcurrent (OCP). Possible causes: H. OUT (Q8024) isshorted. (D board), +B PWM (Q8035, 8038) is shorted. (D board) Symptomsof the problem: Power does not come on, Load on power line is shorted.
  • 3 times,Diagnosis: +B overvoltage (OVP). Possible causes: IC501 is faulty (Gboard), IC5002 is faulty (G board). Symptoms of the problem: TV hasentered standby mode.
  • 4 times, Diagnosis:Vertical deflection stopped. Possible causes: +- 15V is not supplied.(D board), IC8003 is faulty. (A board) Symptoms of the problem: TV hasentered standby state after horizontal raster, Vertical deflectionpulse is stopped, Power line is shorted or power supply is stopped.
  • 5 times,Diagnosis: White balance failure (Not balanced) Possible causes: Videoout (IC7101, 7201, 7301) is faulty (CR, CG, CB board), CRTdrive (IC309) is faulty (A board), G2 is improperly adjusted. Symptomsof the problem: No raster is generated, CRT cathode current detectionreference pulse output is small.
  • 6 times,Diagnosis: LOW B OCP/OVP (Overcurrent/over voltage). Possible causes:+5 line is overloaded. (A, B boards), +5 line is shorted. (A, Bboards). Symptoms of the problem: No picture.
  • 7 times, Diagnosis: Horizontal deflection stopped. Possible cause: Q8035, 8038 is shorted. (D board)
  • 8 times, Diagnosis: High voltage error. Possible cause: T8005 is faulty. (D board)
  • 9 times,Diagnosis: Audio error. Possible causes: +- 19V line is shorted. (A, Bboards), IC708 is faulty. (A board), PS701 or PS702 is opened. (Aboard). Symptoms of the problem: No sound
From what you say I would suspect the D board
    Sergeant:
    Novelist:
  • 277 Answers
After eachg part replaced the the tv has to reset .and it can also be the colour wheel problem.read the link and the reset procedures how to replace the colour wheel with diagram and procedure
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
how to replace the lamp in 5 minutes with diagram and procedure
http://www.jangro.com/a/2006/08/03/how-to-change-your-samsung-dlp-lamp-in-5-minutes
how to replace the ballast with diagram and procedure
http://www.consumermeet.com/entry/samsung-dlp-ballast.html
Red power light flashed 5 times
There is no color wheel. This is an SXRD TV. If you have 389 at the ballast, then your ballast is bad. 5 flashes is a bad lamp driver. No TTL signal return to the mainboard. Put a new ballast in. Do not try and measure ballast output without good high voltage gear. The startup pulse is close to 20,000 volts.
Mar 17, 2016 | Sony KDS-60A2000 60" HDTV
Put new bilb on tv blinks green then goes red in 5 blinking sequence
Most likely with a 5 blink error, your lamp driver aka ballast is defective. There is a chance however that your lamp is not in properly, or you got a defective lamp. Last case scenario is a defective G board, but highly unlikely.
Mar 15, 2013 | Sony KDS-60A2000 60" HDTV
Sony kds-r60xbr2 power wont come on and hte power led is blinking red 5 times
The 5 blinks is indicating the lamp ballast needs replacement your model uses the Sony lamp Ballast 147401211 for sony models KDF42E2000, KDS-50A2000, KDS-50A2010, KDS-55A200, KDS-60A2000, KDS-60A2010, & KDS-60XBR2 amd LDS-R60XBR2
Which is available at the bottom of the page at the following link. The ballast comes with installation instructions,
http://www.tvrepairworld.com/sony_circuit_boards/sony_dlp_circuit_boards
Aug 04, 2012 | Sony KDS-R60XBR2 Television
Sony kds-60a2000 power light flashes 5 times, no picture
This is the error code that usually means the ballast (it is the power supply for the lamp) is bad.
SD TECH
Apr 20, 2012 | Sony KDS-60A2000 60" HDTV
Green power light on my sony 60a2000 blinking repeatedly but no picture
This is a error code normally its the lamp thats burnt out. Count how many times it blinks and check this link for the diagnosis.
http://www.somelifeblog.com/2007/08/sony-tv-led-blinking-codes-what-does-it.html
Jun 06, 2011 | Sony KDS-60A2000 60" HDTV
Blink on standby green after awhile then blink red
The blinking green light signals that the inverter board is charging the bulb. If the blinking goes to red it means that this process has failed because either the inverter board is not full operational or the bulb itself has failed.
Most likely you will have to replace the bulb - here it is
http://www.partstore.com/Part/Sony/Sony/KDSR60XBR1/Royal+Philips+Electronics/Philips+Lighting/F93087600RL/New.aspx
If this doesn't fix it then you will have to check the inverter and power boards and replace the failing one.
Here is the ballast/inverter
http://www.partstore.com/Part/Sony/Sony/KDSR60XBR1/Sony/Sony/146893613/New.aspx
Here is the power board
http://cgi.ebay.com/SONY-KDS-R60XBR1-G-POWER-SUPPLY-1-867-733-11-Free-S-H-/120703310513
Mar 27, 2011 | Sony KDS-R60XBR1 60" Projection HDTV
I HAVE A SONY KDS-60A2000 WONT TURN ON. RED LIGHT BLINKS THREE TIMES. TRIED NEW BULB. NO DIFFERENCE
3 times red light blinking indicates that Lamp Cover has not been fixed in its location properly after lamp replacement.
Please make sure lamp cover (its first thing that was removed to replace lamp) is installed securely.
Thanks.
Mar 11, 2011 | Sony KDS-60A2000 60" HDTV
I have no picture and light flashes 5 times
If you pull the right side out (as you look at the front), get you ear down to the fan exhaust area and turn the set on. If you do not hear the fan turn or feel air being blown out, then you have a defective fan. It is a common problem.
Hope this helps,
Skyassoc
Jun 22, 2009 | Sony KDS-60A2000 60" HDTV
Sony KDS-60A2000 60" HDTV Logo
881 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
