Question about Whirlpool LSR5132PQ Top Load Washer
The inner tup on my whirlpool washer is loose.
The washer does not spin the clothes as dry and sounds unbalanced when it spins. How do we tighten the inner tub?
  • 686 Answers
Look at this part at www.repairclinic.com/SSPartDetail.aspx?=t-LSR5132PQ-%3d%3di541811&PartID=541811 This is a washer's lint catcher and when clogged will prevent complete water removal. As far as the unbalanced check the levelness of your machine in both directions.
Posted on Apr 06, 2009
Washing machine makes loud knocking noise
drain or drain pipes blocked
bearings gone
Aug 18, 2014 | Washing Machines
My whirlpool duet washer hammers very loud when it spins. The outside of the machine doesn't seem to vibrate much but it is very loud.
That is a common occurrence with dryers such as this one. Even though it sounds bad, it is harmless. If it really bothers, you can re-balance the load and it should reduce the vibration.
Jul 29, 2008 | Whirlpool Washing Machines
Tub during the spin
It sounds like it may be a worn drum bearing. A loose transmission bolt could also cause the problem.
Dec 15, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer is not spinning fast - so the clothes are more wet when done
sounds like washer is load sensing either overloaded or unbalanced when it decides to low spin insteasd of high spin dose it stop for second rotate 3 times and change direction 3 times the just spin slow.... if so either u have misloaded the machine by overloading orthe clothes are unbalanced in load may need add a towel or something to balance the weight evenly in the tub
Jan 28, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washing machine make loud noise after spin cycle quits. Noise continues until cycle winds down. Sounds like a machine gun being fired
Hello,have to tell you that most noises from a washing machine occur during the spin cycle. If you hear loud thumping noise during the spin, the load of cloth may have become unbalanced. Stop the washer and redistribute the cloths, then restart the machine. Repeat these steps if necessary.
Thanks
Jun 04, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
AWM 8163 Whirlpool washing machine
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
during the spin, the load of clothes may have become unbalanced. Stop the washer and
redistribute the clothes, then re-start it. Repeat these steps if necessary.
Aug 29, 2008 | Whirlpool AWM8163 Front Load Washer
Noisy Spin Cycle
hi there,
Jun 12, 2008 | Whirlpool LSR9434PQ Top Load Washer
Whirlpool lhw0050pq washer will not spin
Possible your belt is loose; you have to unscrew the back after disconnecting electrical connection from wall socket. If the belt "gives" more than half an inch, you have to loosen the motor bolts and push motor upwards, then tighten the bolts very well. Try spin only to check, before closing the behind. It shd spin very fast.
Apr 25, 2007 | Whirlpool LHW0050PQ Front Load Washer
Whirlpool awm5125/4 washing machine
If the washer seems to complete all of its cycles, but it doesn't spin: 1) Be sure the load of clothes is not lop-sided. If the tub becomes unbalanced, it may spin erratically or not at all. Open the lid after 2 minute gap and reposition the clothes. This automatically resets an off-balance shut-off switch. Close the lid and re-try. 2) Check the lid switch and the tab on the lid that strikes it. If the plastic tab is broken, the washer may halt during the spin cycle. If the switch doesn't click when you press and release it, it's probably broken. If you're experienced at home repair, you can remove the switch, test it, and replace it if needed; otherwise, call an appliance repair service person. 3) The belt may be loose, worn, or broken. If you're fairly handy, tighten or replace the belt, otherwise call an appliance repairperson. Pl post back results
Apr 17, 2007 | Whirlpool AWM5125/1 Front Load Washer
Whirlpool LSR5132PQ Top Load Washer Logo
198 people viewed this question
Dan Webster
Dan Webster
Sal De
