Question about Hayward 2HP Pool Pump Motor A O Smith Electric Pool Motor for 56J Frame
How do i replace the bearings on a whiperflo - Hayward 2HP Pool Pump Motor A O Smith Electric Pool Motor for 56J Frame
  • Hayward Master
  • 1,383 Answers
Not a easy task, the bearing are easy to damage . try looking for your local pool pump motor repair shop (your zip code) cost should be around 85.00 with a new shaft seal (a must !)
Posted on Apr 07, 2010
Is it possible to remove and replace front wheel bearings with out a press
In order to remove the front wheel bearings without press hub off the bearing and then the bearing out of the knuckle. To do the first step need a a Support Bridge.It is a special tool. Make bridge and use a general bearing pulled kit to replace bearings. use a "Front Wheel Drive Bearing Removal Adapters Puller Pulley Tool Set Kit" .To replace the bearing, remove front CV shaft taking care not to move the CV shaft too far out .
Nov 06, 2015 | 2002 Kia Rio
When I changed Pentair Whiperflo motor with new Impeller & Diffuser seals the new motor shaft does not turn. Diffuser is pressing against Impellor not allowing it to rotate. What is wrong ?
Take the Diffuser off and run it if the impeller turns then might be tightening the Diffuser too much, it just needs to not move, doesnt really need a super waterproof seal or anything like that. If it still doesnt turn with the Diffuser off it might have locked up when replacing the Impeller, you can try to turn the impeller manually or remove the cover plate on the back of the moter and turn the shaft manually back there. OOoorr you broke it
Aug 03, 2015 | Pentair 2.0 Hp Whisperflo Pump
How to replace bearing on driveshaft of a 1992 isuzu rodeo
to replace the bearing you must seperate the axle from the rear differential. Then remove the rear section of the driveshaft and then the carrier bearing assembly. Replace the carrier bearing assembly then replace the driveshaft.
Nov 20, 2013 | Vehicle Parts & Accessories
The bearings on my Whirlpool Cabrio WTW6400SW3 make a racket on the spin cycle. The Whirlpool parts diagrams show that to replace the bearings, the entire drum is replaced. I can see one of the bearings...
Yes you can just replace the bearings but be careful. they say to replace the entire drum as the materials they are made out of is not very strong and you can distort or damage the drum when removing the bearings.
Oct 25, 2010 | Washing Machines
I think the bearing on front of motor is going . Can it be replaced or does whole motor need replacing . Unit is cooling very well but making some noise and shaft of motor getting hot. Unit is Coleman...
the bearings are replaceable on some motors.. its a bit of work and you might first check the cost of a replacement motor .. it might be low enough to offset the amount of labor required to replace the bearing .. around here we have a hardware store that has a stock of most common replacement bearings ... some motors have welded bearing cages or bent metal captures .. those are harder to deal with. a way to make at least temporary repairs of such bearings involves punching the bearing to expand it , then re-drilling the bore to the correct size .. you might be able to force grease in the bearing for now to give you a little more time .. as it is it will eventually damage the motor shaft such that bearing replacement will not be reasonable ..
Aug 15, 2010 | Coleman Mach III Air Conditioner
I have a Whiperflo 3hp pool pump. The water
There are a couple things that you will need to check when pool pumps start losing pressure. Air bubbles are definitely one step, but check these things as well. Check you impeller to see if there is a clog or obstruction. You pump strainer could also be clogged. It could be that your o-ring needs to be replaced also. Try these things, reprime the pump, and see if it maintains pressure.
Jul 19, 2010 | Pentair 3hp Whisperflo Pool Pump In -...
You will need a press. If you dont have it take it to an electrical motor shop. it should not cost you more than 50 bucks. just make sure you do replace the seal to when you put back together..
Mar 10, 2009 | Aqua Pool & Spa
Bearings Replacement
Bearings can be replaced without replacing the drum.
this is a major job,So,I would not recommend trying this yourself
Please rate this fixya
Jan 28, 2009 | Hotpoint WMA66 Front Load Washer
Pinion Bearing
the only way to replace pinion bearings is to remove the differential. you shouldnt have to remove the bearing to replace the seal
Nov 17, 2008 | 2004 Dodge Ram 1500
Hayward 2HP Pool Pump Motor A O Smith Electric Pool Motor  for 56J Frame Logo
248 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
