Question about Refrigerators
I have side by side whirlpool,It quit working not
I have side by side whirlpool refrigerator,It quit working not cooling or making ice compressor is surging on and off. Does it need freon?
  • robstew 28 Apr 20, 2009
    HAVE AMANA ARS9167AW SXS .WILL NOT COOL, FAN RUNS CONTINUOUSLY,HUMING NOISE FROM RELAY FOR ABOUT 10SEC THEN CLICKS OFF,DOES THIS ABOUT EVERY 10 MIN,COMPRESSOR IS QUITE WARM
  • 410 Answers
No it probably doesnt need freon. the noise your hearing is the compressor trying to start  due to either a bad start relay or a stuck compressor. on whirlpool refrigs the most common problem is bad relays this is a very easy part to replace and the part is in expensive. less than 70 dollars. the part number is 8201786 and the kit has very good instructions for doing it your self. if you have any questions please ask thanks Peyton
Posted on Mar 10, 2009
Ice maker quit making ice on whirlpool refrigerator
either it needs to be serviced, or replaced.
Check voltage supply and other things from your side.
maybe the Compressor needs servicing.
Aug 18, 2012 | Whirlpool Refrigerators
Ice maker quit working and is causing ice build up on the back of the freezer
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 20, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool 25.6 cu. ft. side by side Refrigerator with in door ice
The process of Refrigeration is for one section to be hot while cooling another section. I.e freezing in one section result in the heat build up and dissipattion else where. Any compressor working properly is going to be quite warm to the point of being hot to the touch when working NORMALLY. There is nothing that you need to do for the continued safe operation of your compressor. If your freezer has ice build up again in the near future your uint is not defrosting properly. If it functions normally after 2 or 3 days of use then you more than likely had a one time buildup of ice usually caused by someone leaving the door partially open
Jan 03, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Oct 03, 2009 | Whirlpool 25.3 Cu. Ft. Frost-Free...
Whirlpool refrigerator not cooling freezer seems to be working
my icemaker makes ice and water but the ice doesn't come out when pushing the button what is the problem?
Aug 30, 2009 | Whirlpool ED2FHEXNS 21.8 Cu. Ft....
Whirlpool GD5SHA XLTO2 problems. Last night, awoke to a sort of burnt plastic smell coming from refrigerator. Turned off ice maker and smell stopped coming out. Today, freezer was not keeping things...
sounds as if your overload relay, controlling your compressor has burnt out heres a part number that should getyou back in working order( complete with intructions pn# 8201786
Jun 15, 2009 | Whirlpool GD5SHAX Side by Side...
Freezer quit freezing
HI,
you can try this suggestion first.
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
any further question let me know.
thanks,
Mar 22, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
My Whirpool Side by side refrigerator, the fridge isn't cool
whirlpool side by side refrigerator, quit working. not cooling or making ice compressor surging on and off.Does this mean it need freon? and can we do it our selfs.
Mar 09, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Will not cool - ice maker will not work
Hi there, if the compressor is making a lot of noise, its broken. If the compressor is running smooth with no pings, it just needs a recharge. here's another tip. check the control panel for lose connections.
Feb 15, 2009 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
219 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
