Question about GE Microwave Ovens
The micowave will not heat or cook anything
Everything works it goes to the motion with the rotating plate and timer but nothing warms or cooks
  • Anonymous Mar 13, 2009
    everything works but won't heat up anything I put inside
PLEASE HELP ME TO FIX THS PROBLEM....
Posted on Mar 10, 2009
My Russell Hobbs microwave seems to be stuck on some kind of timer and I've tried everything to cancel it but it's not having any of it. When it's not actually cooking it seems to be in some get ready mode...
Put a glass of cold water in it as see if it heats up? All microwaves have a timer so that after cooking the internal fan stays on to remove cooking smells and condensation from the chamber. It should however turn off after about 5 minutes as long as the door is closed. The plate should only rotate when a time is set and the cook button is pressed.
Oct 18, 2017 | Russell Hobbs Microwave Ovens
Kenmore 62463 / 721.62463201 Stainless Steel 1200 Watts Microwave. My daughter used it as a timer for reading and set it to cook for 30 minutes with nothing in it. It turns on but is loud and no longer...
You probably fried the magnetron(it actually makes the microwaves that do the cooking). I bet you will find the magnet is broken(from excessive heat). There should be a diagnostic guide sheet somewhere inside the housing(due to running production changes,this is a guide for the pros to test the power supply,magnetron,etc with an ohmmeter to determine which is defective.
Sep 18, 2013 | Kenmore 62463 721.62463201 Stainless Steel...
Micowave just stopped working
The main fuse in the microwave oven has blown, this is often caused by one or two door switches going bad usually the result of food partical build up and must be replaced to fix the problem.
Mar 18, 2012 | Sunbeam Microwave Ovens
No Heat but everything else works
Magnetron and diode most likely. Need more info.
Nov 02, 2009 | GE XL1800 1100 Watts Microwave Oven
GE Microwave won't heat or cook - one year old
More than likely the magnetron has failed. This could be for a number of reason. Do you use your microwave to heat wheat packs or warm plates? If so, you may have dried the magnetron out (they use the moisture in whatever you're cooking to heat it, and plates/wheat bags have no moisture).
I'd say a trip to your local Microwave repairer could be in order. It could also be the High Voltage Fuse which has failed. Either way a repairer will be able to tell you!
Mar 25, 2009 | GE Profile Spacemaker Over-the-Range...
Oven cooks but turntable will not turn, so it cooks unevenly. How do I reset the keypad so it goes back to normal factory presets, in case I entered something that stops the turntable revolving. Is there...
The manufacturer has set the rotational plate in motion at the same time the microwave tube is energized. They work together as a team. At no time should the plate be idol, unless you remove it completely, and then only the center spindle will turn by itself. It is possible for the rotational spindle in the center of the oven to break, but that is unusual unless some sort of pressure (like stopping it when it was moving) was applied. Also, it has been reported that some individuals tend to put items with too much weight or too large for the oven to manage; thus damaging the rotator. As long as the oven still provides Microwaves to cook your food, it is still OK. Years ago, there were no rotating plates and using the energy was all it took to get the job done. For even cooking, just manually stop the oven at times and turn the food to avoid over heating in one spot.
Jan 14, 2018 | Kenmore 62222 / 62229 1100 Watts Microwave...
Everything works except the cooking part/no heating/turntable not turning, help!
you may have gotten a power surge and that can cause some funny things to happen, 1st is there power to the oven, 2nd if so there may be an internal fuse protector built in to the oven, check with the manual for anything of that sort listed. if not you may have to take it in and have it repaired by a pro. there is a lot of voltage in these ovens and unless you know what you are doing a person could get hurt
Jan 03, 2009 | Whirlpool GH4155XP Microwave Oven
Microwave does not heat food placed in the center of the turntable. Leaves a cold spot in the middle of the food.
This is normal. That's why I always recommend to my customers that the food be placed slightly off-center on the turntable. An analogy I refer to is stirring paint: If you stir paint with a stick by simply rotating the stick in the center of the can, it's far less effective than pulling the stick around an imaginary circle halfway bewteen the center and the edge.
Jun 09, 2006 | Whirlpool MH6150XMS Microwave Oven
Microwave Ovens Logo
87 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
