Question about Whirlpool ED2FHSS Side by Side Refrigerator
My refrigerator light went out
Yesterday, when I opened my refrigerator door, I found out that the light was out.  I changed the light bulb thinking that may have contributed to the problem, but didn't work. What should i do?
  • 61 Answers
U have to use special bulbs for refrigerator.. are u sure the u use one??
Posted on Mar 10, 2009
My interior lights in my Viking VCSB423 are out, I tried replacing 2 of the bulbs, it went out after door was open for an extended period of time,(like 10 minutes)
sandra, not being sarcastic but why keep the fridge open for ten minutes? It can cause other problems too. Try not to keep the fridge open for long after bulb change and see if it works. Good luck.
Oct 21, 2014 | Viking VCSB423 Side by Side Refrigerator
Light bulb burned out
Did you have a hinge kit recently replaced? If so call them back they missed something. If not, look into the light circuit a if it goes to ground this light issue would happen. Most of these issues I found in the upper section behind the upper grills. I hope this helps
Dec 25, 2013 | Viking Professional VCBB363SS Stainless...
How to remove cover so I can change bulb
I think the best way to explain how to change the light bulb can be found on page 26 of the=> JFC2089HE User Manual If you have problems with the above link then click HERE and then enter your model number and answer the questions above the plaace you enter model number. I will be here to answer any questions you may have Thanks Sea Breeze
You will need Adobe Acrobat Reader to view these documents. The Adobe Acrobat Reader is available as a free download.
Dec 19, 2012 | Jenn-Air JFC2089HE French Door...
WHIRLPOOL REF DOOR OPEN INDICATOR STAYS ON
There is a switch that tells the computer if the doors are open. If it fails, the comp. will think that the door is open & prevent water & ice dispersion. With this problem the light should stay on. Possibly when the power was restored it spiked, burned out the bulb and killed the door switch.
murf427
Jun 27, 2012 | Refrigerators
Both of our light bulbs on top burned out the same time/day. Model # GLRT218WD My husband changed one light bulb and it didn't work. Does that whole piece come out of the top, where the light bulbs...
Check the door switch. Alot of the time when the freezer door stays open it creates condensation and than when you close the door is can freeze the door switch closed so the switch thinks that the door is always closed. If you need further assistance or this does not cure your problem please reply.
Aug 01, 2011 | Frigidaire Gallery GLRT218WD Stainless...
Light went out. Changed bulb. New light bulb does not work...?
it may be the switch damaged, when you open the door the switch will close the circuit.
Jun 10, 2009 | Refrigerators
Remote works only when Garage Door Opener light is OFF
I discovered that certain light bulbs interfere with the remote sensors. Harware stores have clear vibration reisistant bulbs for garage doors, try them instead. After spending money on a new remote, resetting remotes, and weeks of aggravation...poof.....i found it was the type of bulb I was using. Used a clear bulb and the problem went away. Hope this helps.
May 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage Opener Lights will not come on
IF YOU CAN - TEST FOR 110V AT THE CENTER TANG OF THE LIGHT SOCKET.
IF NO POWER YOU PROBABLY HAVE A BAD TIMER CIRCUIT ON THE BOARD - NO EASY FIX NEW BOARD.
IF YOU HAVE POWER YOU MAY HAVE ISSUES WITH THE SOCKET OR ARE USING THE WRONG BULB - A STANDARD LIGHT BULB IS ALL THAT IS REQUIRED. SOME OF THE NEW BULBS HAVE A SIMILAR LOOK BUT DO NOT WORK IN A STANDARD SOCKET.
Apr 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Light won't work even tho changed bulb whirlpool fridge
Have you checked the door switch, might be stuck in or defective.
Apr 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
My Whirpool refrigerator light went out
the light switch may be faulty replace it
Mar 10, 2009 | Whirlpool ED2FHSS Side by Side...
Whirlpool ED2FHSS Side by Side Refrigerator Logo
103 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
