Question about SimpleTech SimpleDrive Pininfarina 320GB External USB 2.0 Hard Drive - Blue
Simpletech 320GB BOM No.: 96300-41001-012 is new has never worked
I purchased it new and plugged it into my laptop and it does not do anything.
  • 2 more comments
  • hlnowns Mar 10, 2009
    I plugged in power cable and usb cable. The blue light shows on top of the harddrive. But nothing shows on my computer. When I go into my computer it will have the internal harddrive C and the DVD drive, but the external drive does not show up.
  • par417 Mar 12, 2009
    I notice that nothing happens when I plug in the USB, perhap it needs ac adaptor and power adapter which it did not come with. It's a 500mg, searched found info suggested it DID need above, 12 v 2 amp adaptor. It this correct? Specs say no adaptor needed.
  • suavenar21 Apr 16, 2009
    I need the device driver installation software.
  • Dick
    Dick May 11, 2010
    Did you plug in the power cable too, or just the USB cable?
    New Friend:
The original power supply is "SB2D-020-1HA SIMPLETECH AC ADAPTER 12V 1.5A FOR EXTERNAL HARD DRIVE" . Just find a replacement with the correct size plug (center positive) that supplies 12v DC at 1.5amps (1500ma)
Posted on Mar 06, 2015
5 Suggested Answers
  • 79 Answers
SOURCE: Need an AC power supply for a 96300-41001-012
It is a 12V, 2A, tip positive supply.
Posted on Mar 21, 2011
  • 336 Answers
SOURCE: I have a simpletech 1TB ext. hard drive BOM No.
You need to install the hard drive driver for the PC to recognize it. If you don't have one, just look in the internet for a free driver.
Regards,
Jeep Brainy
Posted on Aug 14, 2009
  • 79 Answers
SOURCE: looking for software/driver download for
SimpleTech hard drives do not require a driver to work. You might try a different cable or check it on another computer. If you need more help, please call HitachiGST Tech Support M-F 8AM to 6PM PST at 1.888.426.5214 and a technician will be happy to help you.
Posted on Jan 31, 2011
bronk50
  • 27725 Answers
SOURCE: need driver for 96300-41001-012
if you are having trouble with your drivers
here is a general look at the drivers and how to update them
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
make sure the lead/s that attach to this drive have a secure seating and are not bad/faulty the light on only tells that its getting power it might not be getting enough power you might test the lead/s or
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
Posted on May 15, 2011
Hi, i have a SimpleTech External Harddrive... and it won't open when i plug it into my computer - i have taken it to bestbuy where i had purchased it, and they tried to open it as well - they had no...
Data recovery can be expensive the most expensive recovery labs may charge $2000. But for a 320GB drive you can get the data recovered for much less money.
This guy does data recovery remotely over the internet and works for donations http://FreeDataRecovery.us
Another good low cost option is http://300dollardatarecovery.com
Jul 21, 2011 | SimpleTech Signature Mini 320GB External...
I just got a new laptop and I no longer have my softward installation disk for my simpletech 320GB external hard drive. I've gone onto simpletech.com and am having trouble finding the software program. ...
If you have a new laptop, you should not need the install disk to see the drive as the drive is USB 2.0 compliant.
And no, nothing will get erased unless you erase it on purpose.
Plug the drive into you laptop (USB cable).
Plug power into to the external drive.
Turn the drive on.
It may take a minute or so but your laptop should recognize the drive. It will get assigned a drive letter (assuming you are using Windows).
Apr 19, 2011 | SimpleTech SimpleDrive Pininfarina 320GB...
When i plug my simpletech hitachi 320gb black cherry hard drive into my laptop the light comes on on the hard drive but my computer doesnt find it, went into device manager and it says the device wont...
i,m not a big fan of simple tech do to the fact that they sell cheap products and 9 times out of 10 they fail mechanically you can try and format to see if that works
Mar 23, 2011 | SimpleTech Signature Mini 320GB External...
Regards,
Jeep Brainy
Aug 14, 2009 | SimpleTech 1TB SimpleDrive Pro External...
SimpleTech SimpleDrive Pininfarina 320GB Power up problem
It could be that it's internal power supply burnt out,
in which case the drive itself could still be fine.
Try opening up the external case, and removing the drive.
Once you do, plug it in to your computer directly using its SATA cables, and see if that works.
Hope I helped,
Tom
Jun 21, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
SimpleTech Signature Mini (320GB) unable to find on my laptop
if you hear a constant clicking return the drive it is faulty.
Mar 27, 2009 | SimpleTech Signature Mini 320GB External...
Lost ac/dc adapter for a 320 GB Simpletech External Hard Drive
I have the 320GB Simpletech External Hard Drive.
The AC adapter Model number is SAWA-05-153
The output is +12V --- 1.5A
Nov 16, 2008 | SimpleTech SimpleDrive Pininfarina 320GB...
SimpleTech SimpleDrive Pininfarina 320GB External USB 2.0 Hard Drive - Blue Logo
2,094 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
