Question about Netopia Cayman 3347W-Ent Wireless Router
Can't find LAN address on etopia 3347
Been fighting this thing for days trying to get it to push traffic through a Check Point firewall. Changed the LAN IP address to match the original internal subnet (172.20.32.33) and now it won't show itself at all.
I'm guessing I must have mistyped the address. There is no USB port on it so there is no way that I can see to get back in without having to go through ATT support.
Anyone know a way?
    Scholar:
  • 62 Answers
You can make the lan ips what ever you want them to be. The way you get thru firewalls, which on the router is NAT, is to set up mapping from your WAN ip to the LAN one you creat.
if you are saying instead, that you put the netopia in bridgemode, and are passing all the ips thru the router to the Check Point firewall you have set up behind it, then you need to configure your firewall correctly.
spin
Posted on May 01, 2009
How do i open the ports on my thomson wireless router so i can change my nat status on call of duty black ops
I dont undestand your question to well, NAT stands for (Network Address Translation) examle, your router has a LAN IP address of let say 192.168.1.1 and has a WAN IP address of let say 69.51.200.23 than for the traffic to be able to flow trough the WAN side to the LAN side the router NAT's the traffic from one side to the other, PORTS on the other hand are to let a spesific service trough the FIREWALL on the WAN side to a sepsific machine on the LAN side, since NAT is not a service, I dont think you need to open anny ports in your router's FIREWALL to play or modify a setting in the console. As for the game (I'm not an expert) but i think it uses the term NAT for some sort of filter to filter out un wanted players I think (nothing to do with Network Adress Translation or PORTS)
IF I'm wrong just post a coment!!!
Mar 22, 2011 | Computers & Internet
NetGear WGR826V has no clear port forwarding section in the setup, the mamnual is as clear as brick as to forwarding...so how do I forward a port on this brain dead router?
Forwarding Port – If you select 'Same as Incoming port' then all incoming traffic on specified Service is forwarded to LAN server without modifying Destination Port. – If you select 'Forward to another port range' then all incoming traffic received on the Service port (or range of ports) is forwarded to this port or range of ports of the LAN Server. – This field is disabled if action selected is "Block Always". – If you want to forward the traffic to a single port then enter port value in start port and leave finish port empty. – If you want to forward the traffic to range of ports then enter non zero value in finish port and make sure that service record attached to this rule has range of ports and range is equal to that of forwarding ports. – For example if you select Service as HTTP (TCP/80), LAN Server IP address as 192.168.15.10 and Forwarding port as 8080 then all traffic coming from internet on – TCP/80 (HTTP) to this Router is redirected to TCP/8080 port of 192.168.15.10 • WAN Users: These settings determine which packets are covered by the firewall rule, based on their source (WAN) IP address. Select the desired option: – Any All IP addresses are covered by this firewall rule. – Address range If this option is selected, you must enter the "Start" and "Finish" fields. – Single address Enter the required address in the "Start" fields. • Log: This determines whether packets covered by this firewall rule are logged. Select the desired action. – Never - never log traffic considered by this firewall rule, whether it matches or not. – Match - Log traffic only it matches this firewall rule. (The action is determined by this firewall rule.)
Ok well this is out of the manual, to me it seems straight forwards, but it is a brick too though, there is an example to help you, basically you tell it the Address of the PC, (Right click on NIC and get address) that you want ports to go to.. then ALLOW it, UN-disable actually.. in the tables.
Feb 05, 2010 | NetGear WGR826V Router (wgr826vna)
Good morning, I am trying to set up my voip (magicjack) on a DIR-655 wireless and I can send call but cannot receive them. I am not on the LAN as i am wireless, can you help
You _are_ on the LAN -- via your "wireless" connection.
However, the "unsolicited" TCP/IP traffic caused by the "incoming" call is being blocked by the firewall software inside the D-Link router.
Follow the MajicJack instructions for "port-forwarding", so that all that unsolicited traffic gets "forwarding" to the IP-address that is assigned by the router to your computer.
Feb 03, 2010 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
How to block some website on asa 5505?
do the name resolution for the website and write a policy to block the traffic from your trusted network to that website ip address. If required i shall write the policy and give it to you, for this i need the following details.
1. Name of the websites
2. Local network range (LAN ip address with SNM)
But this is very hard for you if there is more number of websites, For this you shall integrate a URL filtering software like WebSense, N2H2 etc with your firewall.
Nov 14, 2009 | Cisco ASA 5505 Firewall
The signal do not going thouth to the router to the computer
Are you saying you are not getting an IP address? If you are, then there is two way communication happening between your router and the computer. Is the router getting an IP address off the WAN? You need to verify this by logging into the router and looking for the WAN setup or status. If both of those are true then you have a config issue either on your firewall or the routers routing table or firewall. Check your computer first to make sure it's allowing traffic from the routers LAN IP address. Then check your router's routing table and the firewall settings.
Oct 28, 2009 | Encore 802.11G WIRELESS LAN ROUTER...
I am trying to telnet through a Linksys RVS4000 from the wan side of the router to a fixed device on the lan side of the router. Both networks wan & lan are operational and I can ping the Wan side...
run netstat on the lan pc to see if telnet server is listening on port 23. look at logs on the router and pc to see if it is blocking any traffic. make sure lan pc has route back to wan
May 14, 2009 | Computers & Internet
Netopia 3347 LAN problem
Can you ping them, there may be a type of firewall that is blocking that traffic on the netopia router. Try and ping between computers and see what you have any comminication.
Jan 16, 2009 | Netopia Cayman 3347W-Ent Wireless Router
Need to network SG300 Firewall and Qwest (Motorola) 3347-02 Modem
The modem needed to be set to a 192.168.x.x network, and the SG300 Firewall WAN port needed to be set to a dummy IP on the same network for it's IP, and the specific 192.168.x.x address for the gateway and DNS.
Nov 05, 2008 | Cyberguard SG300 (00852503000366) Firewall
FTP problems.
There are 2 ports used for FTP. They are 20 and 21. When you initiate a connection that occurs on port 21, but data traffic is on port 20. Your firewall sees your outside FTP server trying to 'initiate' a connection on port 20 and breaks the connection to that IP address.
What you need to do is either use 'passive' ftp or open both ports 20 and 21 for ftp traffic in the firewall.
Apr 02, 2008 | D-Link DFL-800 Firewall
ActionTech Wireless Gateway can't route Wireless to LAN
Disable firewall on all devices. All types of security sofwares should also be disabled in order to ping each devices.
Oct 07, 2007 | Actiontec GT704WG Wireless Router...
Netopia Cayman 3347W-Ent Wireless Router Logo
230 people viewed this question
Top Netopia Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
