Question about Maytag MDG6657BW Gas Dryer
My Maytag Dryer Wont Heat, Im an amateur repairman
I have an ensignia dryer, md # MDG6657BWW> runs just fine but has no heat. Have the front panel taken off. What do I need to check first? Bought it new about 4yrs ago.
  • 3 more comments
  • annabella91 Mar 10, 2009
    where is that located exactly?
    There is nothing lit or glowing as far as I can see.
    What do I need to do now?
  • hx58979 Apr 05, 2009
    I have the same problem.  Is there any way to get the part's list so I can order a part number?
  • steve
    steve May 11, 2010
    Is the glow bar ignitor coming on and glowing?
    New Friend:
I changed a three prong too a four prong power cord now it wont heat
Posted on Mar 30, 2016
  • Maytag Master
  • 3,361 Answers
Inside the dryer on the bottom right corner.
Posted on Mar 10, 2009
  • steve
    steve Mar 10, 2009
    Call a technician to replace the glow bar ignitor.
Our Maytag Centennial Electric dryer is not cycling in auto dry mode but will in timer mode. Any thoughts?
There is a sensor that the clothes have to touch when the drum spins. This sensor measures how wet the clothes are. If you don't have enough of a load in the dryer then the sensor wont detect the dryness. Or it could be a bad sensor or connection or main board.
Nov 02, 2015 | Maytag Centennial 7.0 Cu. Ft. Super...
I have a Maytag Ensignia Electric Dryer Mod. # MDG7758AWW. It starts up but runs cool air only and intermittenly will give off some heat but can run for a hour with cool air only. The vents and lint...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 15, 2011 | Maytag MDG7758AW Gas Dryer
Dryer running fine but just stopped heating. lint traps all clean.Maytag Neptune MDE5500AYW. HAVE THE DOOR AND FRONT PANEL OFF ALL ELEMENTS LOOK CLEAN AND ATTATCHED. No problem with home power...
Hi,If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.if you dryer is gas check out this gas no heat tip....If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 23, 2011 | Maytag MDE5500AYW Electric Dryer
Maytag ensignia dryer not heating up As of just yesterday found dryer not getting hot at all. Did clean lint from lint trap in front and back. Checked online saw needed to check fuses by taking back panel...
heatman101
Aug 16, 2011 | Maytag Dryers
The short wire to the element keeps burning through on my maytag ensignia 200 dryer.
make sure your using a heat compatible connector when replacing ,, the ones you get for automotive work just can't handle the heat range in a dryer, also, check the element itself for any weak spots or charred sections,
Jun 09, 2011 | Dryers
Wont heat
First make sure both of the breaker switches for the dryer are on at your electrical service panel. There are two, both together, usually, sometimes they are connected together, sometimes they aren't. If one is flipped, the dryer will run but not heat. Secondly, unplug and plug the power cord for the dryer to make sure the connection isn't loose. If none of that works, unplug the dryer and take the top off. That usually requires removing a few screws and popping the top off. There is often a single ground wire that runs to a connector screwed directly to the top of the housing over the drum. If that wire is okay I would either call a professional repairman, or obtain a repair manual for the dryer, as there is either a heating element that is bad or a switch.
Mar 02, 2011 | Maytag HYE3658AY Electric Dryer
Hello< My dryer is spinning no
The problem when the dryer runs but doesn't heat is usually caused by a failed high-limit thermostat and a blown thermal cut-off both located on the heater housing. Verify this by bypassing both parts for troubleshooting purposes then running the dryer.
Disconnect power then remove the screws attaching the bottom front panel to the bottom flange of the cabinet. Slide the panel down and off the cabinet to access the heater housing.
Remove the hex-head screw from the heater shield and remove the shield.
Disconnect the red wire from the thermal cut-off and the red/white stripe wire from the heater. Connect the red wire disconnected from the thermal cut-off to the heater terminal where the red/white stripe wire is disconnected from.
Reconnect power then start the dryer. The problem is indeed with the two bypassed components if the dryer heats up. Replace both the thermal cut-off and the high-limit thermostat and it should solve the heating problem. Do not use the dryer with those parts bypassed due to high risk of fire hazards. Let us know should you need further advice.
Jan 11, 2011 | Kenmore Dryers
LD 8410 MAYTAG DRYER .... DRUM TURNS .... NO HEAT......HOW DO I TAKE OFF THE BACK
  • before taking it apart, if it is an electric dryer, then check the circuit breaker in the house. sometimes only one side of the dual breaker will trip leaving you with a running dryer with no heat.
  • maytag dryers are accessed from the front. look for 2 screws on the front panel near or at the bottom. these hold the front panel on.
  • let me know if you need more help
Jul 04, 2008 | Maytag Dryers
MAYTAG PYE2300AYW ELECTRIC DRYER not heating
Check the terminal block and make sure you're getting 220. If you only get 110, the dryer will run but without heat.
Apr 03, 2008 | Maytag PYE2300AY Electric Dryer
Doesn't heat and dryer light no longer works
make sure you have power to BOTH legs of the 220v.
Feb 17, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag MDG6657BW Gas Dryer Logo
742 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
