Question about Ovens
Can`t set clock on omega OA602
I am unable to set the clock on the oven in my newly purchased house. The manual is missing several pages, the one I need being included. I believe it is an Omega OA602 and would probably be about 4 or 5 years old. Internet searches have turned up nothing. It has 3 buttons underneath the clock but it is near impossible to work out how they work.
  • 14 Answers
SOURCE: Omega OF601XA Thermostat Light Not Working
if the oven is working ok , and cycles on and off when it reaches temp then it is just the lamp needing replacing or wiring has came lose
Posted on Dec 13, 2009
  • 234 Answers
SOURCE: Omega oven model number is OO910XA
If it is a common problem with Omega, they may not be ready to admit it. Since it occured 2 times, possibly the hinges use nylon rollers for smooth and quiet operation, but the hinges are not well shielded from the hi heat of 500-600 degrees and the nylon parts fail after a few months constant heat exposure. There is a common problem that happens with oven doors when they do not seam to close tight: besides being old and normally worn, if a door is leaned on while it is open, the hinges could be stretched and then they will never allow the door to close tight. This has happened to many ovens regardless of age, and the customer never realized that the weight or pressure they applied to the door when in the open position has done damage; yet they wunder why the door does not close well. Goodluck,Macgivor
Posted on Jan 27, 2010
  • 69 Answers
SOURCE: my omega europa oven is not heating up .grill fan
Sounds like a faulty fan oven element. To replace: Disconnect from power (usually easiest to switch off at fuse box). Remove racks etc from inside oven. Remove rear panel inside oven- four screws. You will now see a heating element that goes around the fan- often you see blow mark on element. You need to remove the back panel of oven to access the nuts that hold element in- two nuts, undo nuts, remove wiring from element. New element available from any good appliance repair shop. Reverse procedure to refit. Happy fixing!!
Posted on Mar 18, 2010
SOURCE: Omega Europa 20-1 oven. What do the symbols mean?
Fan symbol - defrost (fan only - does not use thermostat)
Fan symbol within a circle - fan forced oven
3 little triangles - static grill (keep oven door open)
3 triangles above the fan symbol - fan grill (keep door closed)
Posted on Jan 23, 2011
SOURCE: my clock is flashing on
http://www.users.on.net/~cepus/s3/files/europa%20oa60-1.pdf
Posted on Feb 28, 2011
BO6255SS - The clock turns on but we are unable to set it and therefore cannot turn it on. Can you help?
this is as much as the manual says
After your appliance is connected to your mains supply for the
first time, the numbers on the timer display will flash. Before
you can select a cooking function or set a temperature, you
must set the appliance into manual operation mode.
o To select manual operation mode, press the manual operation
button (9) on the control panel.
http://www.manualslib.com/manual/956107/Baumatic-Bo625ss.html?page=3#manual
Jun 02, 2016 | Baumatic Ovens
I have a new Neff U15E52N3GB oven and I have to reprogram the clock each time I want to use it. Am I missing something on the original set up or is it a Naff Neff?
you are, that sounds like your setting the timer for cooking not the clock.....switch the hole thing off at the wall then put it back on, the clock should flash, then set it, check the manual for button config.
infact i just read it, & its on page 10 2nd paragraph on right hand side...........
You can only change the clock when no other clock function is
active.
ie switch it off & back on at the wall.
1.Press the < > clock function button repeatedly until
the< > O(pic of a clock) and symbols light up.
2. Set the clock using the rotary selector.
The setting is applied automatically
Dec 12, 2014 | Neff Ovens
Missing manual omega oven 00912xn
We have this oven and the F symbol has come on and we are unable to turn the oven off.
Can anyone help please?
May 18, 2012 | Ovens
How do I turn my omega oven europa 60-1 on? I turn the knobs, the electric clock is flashing but nothing comes on?
Can anyone tell me how to turn off my omega europa 60-1 oven. I have put both temp and fan to off but oven fan still going Help please as cannot find isolating switch thanks
Oct 08, 2011 | General Ovens
Oct 03, 2009 | Ovens
Omega europa 40-1 oven settings?
I had the same problem when I moved into my current apartment (mine's the 20-1 model). I was at a loss as to what all those symbols meant, so emailed info@hagemeyer.com.au and they sent me a pdf copy of the manual. It's not exactly the same model as you have, but I assume the symbols are the same. I'm happy to email you my manual if you'd like. Otherwise, the controls (for the 20-1 at least) are as follows:
I hope that all makes sense.
Apr 12, 2009 | Ovens
I have a classique gas/electric oven and need to set the clock because of power cut. Oven was in house when purchased so have no manual. Think this is model 2320 SS although not certain as plate with info...
Cassique gas top & electric oven. Oven does not have usual temperatures but has 1 to about 20. What do these numbers relate to in terms of temperature
Mar 05, 2009 | Ovens
Setting Clock and Timer
Worked it out for myself - no solution needed now thank you.
Jun 21, 2008 | Zanussi ZBS963X Electric Single Oven
Diplomat Oven ADP3650 Instructions
User manuals are hard to find.
The problem I had was setting the clock on a single Diplomat oven, with no clock button. Here's my solution :
DIPLOMAT OVEN OPERATING INSTRUCTIONS
The Diplomat single oven is controlled by two knobs and a set of buttons along the middle of the control panel.
The left knob sets the temperature of the oven, while the right knob selects the function to be performed, e.g. fan oven, grill, etc.
The buttons along the middle set the cooker clock, the start and end times of cooking, and the “+” and “-“ buttons will increase or decrease the time shown on the cooker’s clock.
PLEASE NOTE THAT THE OVEN WILL NOT OPERATE UNTIL THE CLOCK IS SET.
If there is any interruption to the power supply (including manually switching off at the main switch) the oven will not operate until the clock is reset.
Here’s how to set the clock:
First press simultaneously the first two buttons to the left of the control panel. They are marked as a Bell symbol (Alarm) , and a steaming Cooking Pot (Start of Cooking Time). Then immediately press the plus “+” or minus “-“ buttons to increase or decrease the time displayed. When the desired time has been reached, leave it for a few seconds, and it will remain set at this time. Any further changes to the displayed time will require this procedure to be repeated.
Hope this helps!
Oct 10, 2007 | Ovens
Ovens Logo
49 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
