Question about Bose Cinemate Digital Home Theater System Speaker
Olevia TV Remote doesnt work Sleep Timer
When I press the sleep button on my RC-LTU Remote, it says OFF. I used to be able to set my tv remote to have the tv shut off atfer a certain amount of time. Now the TV says OFF when I press the sleep timer button. What has happened? I need the sleep timer to work, HELP!
The TV is in 'showroom mode'. To fix: Click: Menu --> Picture --> Mode --> Power up then select: Home. Then click menu until you exit the settings. You will now be able to use the sleep timer.
Posted on Mar 06, 2010
How do you set the timer on remote
Hi, you do not set the sleep timer on the remote. You set it on the TV. In order to do this with the 076B0MQ051 REMOTE you must simply press the SLEEP button.
Oct 31, 2013 | Sharp 076b0mq051 Remote Control
How do I set the sleep timer? We got the tv from a friend and it had no manuel.
Programming the Sleep Timer:
  1. Press and release the TV key.
  2. Press and hold the SLEEP key for three seconds. The illuminated component name turns on.
  3. Release the SLEEP key.
  4. Using the number keys, enter the desired time in minutes (from 1-99 minutes). To set the timer to an umber under 10 minutes, first press 0 and then the desired number (e.g.,05 for five minutes). The illuminated component name blinks with each key press.
  5. Once the second number is entered,the illuminated component name turns off.
    Tip Any key press other than the number keys is ignored. If you don't enter the sleep time within 10 seconds after pressing the SLEEP key, you must start over at step 1. The illuminated component name blinks four times and then turns off, indicating your attempt to program the Sleep Timer has been unsuccessful.
  6. The Sleep Timer is now set.
  7. Leave remote aimed at the TV. Once the Sleep Timer is set, you can continue to use the remote without affecting the Sleep Timer. However, because the timing mechanism for the Sleep Timer is built into the remote itself, the remote must be in TV Mode and pointed at the TV to activate the Sleep Timer.
    Note: If the ON·OFF key is pressed, the Sleep Timer is canceled.
Aug 19, 2011 | RCA Rcr461 Remote Control
How do I use the sleep timer button?
Well you may please follow the steps below -
Step 1: Press and hold the "SLEEP" key, then release. The indicator light will stay lit.
Step 2: Enter time in minutes using the numerical keypad (from 1 minute to 99 minutes). For 1 to 9 minutes press 0 before the actual number. The indicator light will go off. Leave the remote aimed at the TV set.
The Sleep timer program can be cancelled (reset to zero) by pressing and holding the "SLEEP" button until the INDICATOR LIGHT blinks or by pressing the ON/OFF button.
Good Luck!!
Thanks for using FixYa!!
Oct 13, 2010 | RCA RCU410W Remote Control
TV will not come on with remote or power button
The following instructions are for the Emerson EWC1303/1903 tv/vcr. That's the closest match I could find to the Spongebob Squarepants 13' TV
If it's actually in Sleep mode, do the following:
TO CANCEL THE SLEEP TIMER
Press the WAKE UP/SLEEP button on the remote
control until “SLEEP TIMER” appears.
To view the time left for sleep timer press the WAKE
UP/SLEEP button twice, then press the MENU button
on the remote control to exit the sleep timer setting
If unsuccessful, try unplugging the TV for 1/2 hour, then plug it in and try turning it back on either manually or with the remote. Either of these should solve your problem. Best of luck to you!
May 08, 2009 | Emerson SpongeBob SquarePants TV
Sleep Timer on remote does not work
First try to access the sleep timer menu from the controls on the TV to verify the TV is working.
If that works then the remote has the problem.
Now try this;
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
If this does not work, then you may need a new remote unit.
Mar 10, 2009 | Olevia LT37HVS 37 in. LCD HDTV
This TV has a sleep mode
There are two ways to solve this, but both will require using the original remote for the Magnavox. The original remote has a SLEEP button - press it until the screen says Sleep DISABLED or Sleep OFF.
Or make sure the TV is in TV mode, and Press Menu --> TV Steup --> Sleep Timer --> change to DISABLED
-Tha Mp3 Doctor
Feb 20, 2009 | Philips Magnavox 15MF400T 15 in. LCD...
Need Code for Olevia LCD TV
there is no code for olevia.....(olevia, vizio and dynex are really new) All universals are not yet ready for theses new flat panels.............but you can use olevias remote (rc-ltu) it controls five units (cable box, olevia tv, pioneer laser disc and toshiba dvd plus a vcr if i had one)
Dec 20, 2008 | Directv RC23 Remote Control
Remote controler
press picture/sleep button. use the buttons on lower left to set. press arrow bouttons to set time and hit enter (middle button)
Jul 05, 2008 | Philips Magnavox 20MS233S 20" TV
Olevia rc ltu remote
http://remotes.com/remotes/documents/Olevia/532.pdf
Apr 14, 2008 | Bose Cinemate Digital Home Theater System...
Magnavox lcd tv
Setting the Sleep Timer sleeptimer.gif The sleep timer allows your LCD TV to automatically turn OFF after a given amount of time. You can set the sleep timer using your remote control or through the onscreen display (OSD).
TO SET THE SLEEP TIMER USING THE REMOTE CONTROL
1. Press the SLEEP button on the remote control. The sleep timer appears at
the top of your screen.
2. Press the SLEEP button one or more times to select the time you want.
3. Press the EXIT button to hide the sleep timer display. Your sleep timer is now running in the background. The sleep timer will be hidden after 10 seconds.
Turning On the LCD TV.
1. Press the MAIN POWER switch in the back of the unit (see Back Connectors for location). The Status LED on the front turns orange
and your LCD TV is ready to turn on.
2. Press the POWER button on the front of your LCD TV or on your
remote control. The Status LED on the front turns green.moz-screenshot-6.jpgmoz-screenshot-5.jpg
Dec 18, 2007 | Televison & Video
Bose Cinemate Digital Home Theater System Speaker Logo
868 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
