Question about Husqvarna Garden
Rancher 55 carb kit schematic - How do I reinstall it?
I need to install this kit and don't know how.
  • 398 Answers
REPLACE CHAIN BAR STUDS 55 RANCHER
Tom, Check the attached links,instruction and guides on Husqvarna chainsaw, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Husqvarna rancher 55 chain bolt replacement
http://www.husqvarna.com/ddoc/HUSO/HUSO2002_USen/HUSO2002_USen__1140106-95.pdf
How to Change Chain on Husqvarna Chainsaw Model 445
How to Adjust the Oiler on Husqvarna 55 Rancher
Apr 02, 2016 | Husqvarna 36 41 50 51 55 136 141 154 254...
I need to know the size and thread for the Husky decompresion valve,so I can retrofit on my Husky Rancher 55
Well it will be metric thread. The to easiest ways will be go to a nuts and bot shop, thay will tell you and should have the tap you need to cut the thread into the housing or if you buy a thread-gage, that will tell you the thread pich
Dec 17, 2013 | Husqvarna Maintenance Kit For Model 51 And...
Need thread size for Husqvarna decompresion valve
dont know off the top of my head however you can get a thread identifier tool for 5 bucks, or if you have a tap and die set you can see which one fits then read the number off the side
Dec 17, 2013 | Husqvarna Chain Saw Models 51, 55
2005 rancher won't idle. Installed new carb, but it won't stay running or idle
there must be some adjustments on the new carb that you are not aware of, did the new carb come with some instructions or some kind of schematic or diagram?
Sep 05, 2013 | Honda 2005 FourTrax Rancher 4X4
I have a Rancher 55 18" with a new chain. Started
First thing you need to check is the cylinder.Take the spark plug ouy.use a flashlight and look down the hole towards the muffler side.If its scratched up afraid the motor is shot and will need to be rebuilt.If its not scratched up let me know on here.Then I will give you more things to check.
Mar 17, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna 55 rancher-just put new piston ring and cylinder.saw start right up and idles.when i try to acellerate it bogs and try to stall.when I let off gas it idles fine again.I tried turning mixture...
The plastic carb mount has a hole and a slot, this is the pulse channel from the cylinder to work the pump diaphram in the carb, if you look behind the plastic plate there is a tube that fits into the cylinder under the black induction rubber, this feeds a positive and negative pressure to the carb as the piston rises and falls, make sure you have re fitted the small seal in the cylinder that seals this tube or you will have big running problems.
Let me know if you need more help.
Mar 02, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
My rancher was running then quit. Spark is good but plug is dry. I ripped off the carb and cleaned it but it will only run when i dump fuel in it.
Hello, I will try to give you a few ideas and hope one works. Fuel is not getting into the combustion chamber at all from what you are explaining. Is the fuel filter ok? Did you put a new kit in it specially the diaphrams? From what you describe, obviously gas is not getting to the carb. and therefore into the engine. If the bolts are all tightened properly, the gaskets or anything else is not leaking air. There is a small screen type filter in the carb that if plugged could cause that problem. The hole it is in is about 1/4 inch across maybe a little more. remove it with a needle and clean it or replace it with a new one. Actually if you installed the old carb kit back in, I suggest installing a new one. I would check the inlet needle to make sure it is not sticking, also the lever and make sure the small spring under the lever is not missing. The metering diaphram should not be stiff or have any pinholes in it. All the gaskets on the carb should not be leaking, and make sure the pulse port on the carb and the one on the intake manifold should not be blocked also the gasket between the carb and intake manifold should be plugged. That is about all the suggestions I can provide. I hope one of them might be helpful. All the best and good luck.
Jan 14, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
I have a 09 455 rancher that will start with choke on . Idles with choke off but bogs when throttled up. I believe the bottom carb gasket is leaking. Parts houses say call for carb parts.
If gas is leaking from the carb, can you see if it is a damaged fuel line with a leak or coming from the carb itself. If it is the carb tighten the screws on the carb itself. If neither one is the problem you probably do need a carb kit installed. Hope this is helpful. Best regards and good luck.
Jan 08, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarana Rancher 55 , how to clean the exhaust port
Cleaning the exhaust: on the saws I've worked with it was just to loosen two bolts at the front and then the exhaust is off the saw. Clean with brake cleaning fluid and blow with compressed air, let it dry before assembling. Don't forget to clean the fine mesh at the output side underneath the lid if present (i.e the spark arrestor).
Make sure to have your carb adjusted properly afterwards.
May 18, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Garden Logo
373 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
