Question about Makita 2 Bl1830 18v Battery,dc18ra Charger Lxt Fr Drill
Charger no light and wont charge
CHECK POWER CHORD OK FUSE OK WHATS THE PROBLEM WHY WONT IT LIGHT AND CHARGE
  • Dean
    Dean May 11, 2010
    Where are you located and what voltage version of the charger do you have? 110-120v or 230-240v?
THIS MAY OR MAY NOT HELP. THERE MAY BE SOME COMMON CIRCUITRY WITH THESE CHARGERS?
Makita 1850 battery charger FIX. A friend asked me to check his charger unit which had failed after it had been connected to a portable petrol generator that incorrectly generated 317 Volts AC and not the usual 240 Volt AC. On the charger circuit board next to the transformer wire connection is a component marked F2; this is a 2.5Amp fuse covered with heat-shrink sleeving. This fuse had ruptured/blown. Also blown was Transistor Q1, a ''P'' Mosfet labelled IRF9Z24N and Schottky Diode D9 labelled SR560. Replacing these 3 items got the charger working again. NB Resistor R31 is only 0.1ohm - don't assume it's gone short circuit! NB. I'd presume that most other Makita chargers will have this heat-shrink sleeving ''camoflaged'' fuse on the input of the circuit board and it would definitely be worth checking if the charger has stopped working. Regards Roy
Posted on May 16, 2010
  • 9 Answers
Sorry to give you my opinion, but these chargers are very delicate, I have 4 and can barely keep 2 going. My recommendation? Open it up and look for obvious shorts/loose wires, if no luck then buy another one and return the busted one as if it were the new one. You will end up with two working chargers. PS this is probably fraud...ha!
Matt Giantglobes.com
Posted on Aug 18, 2009
My gogo elite traveller wont chrage. The charging light isnt on when i plug the scooter in.
Sounds your batteries are to low in voltage for the charger to recognize. Also check the fuse on the battery box, normally a red one 10amps.
Feb 13, 2015 | Pride Mobility Products GoGo Elite...
Who fixs batter charger fix ya
It would be helpful if you provide the model number of your Pride Wheelchair. Also it would help to know which part of the world you live in so that we can direct you to the correct location for service center or dealer who could help.
If the charging light does not come on then it does not necessarily mean the charger is faulty. It could be the battery itself or the power chord or plug could be an issue. There is also sometimes an internal fuse for the charger that could be blown.
In the meantime look at this website to check if your model is listed.
Pride Mobility Products Corp Product Owners Manuals Specification Sheets
Aug 20, 2014 | Pride Health & Beauty
Why wont my celebrity x3 charge
Try the Charging circuit fuses hidden under the mat and floor hatch.
Is the charger OK?
Are the batteries coming to the end of their life?
Apr 25, 2014 | Pride Celebrity X 3-Wheel Electric Scooter...
Power does not on my laptop
This could be one of several reasons. The most common reasons that a laptop won't power up are a dead battery, or a non-functioning charging chord. My first step would be to plug the laptop into an outlet in the wall that I know for a fact works. If I am unfamiliar with that specific plug, I will plug something into that outlet that makes noise or light. Such as a lamp, stereo, or phone charger. After you have verified that the wall is giving electricity to the charging chord, the next step is to check the next step in the power chain. That would be where the chord from the wall plugs into the transformer box, that plugs into the laptop itself. So the first step is to check that the outlet that charges the laptop is receiving power. As a side not just because a top plug is getting power does not mean that a bottom plug is as well in my experience. After power received, next check connections. Those connections will include the transformer connection, and the laptop connection. Also you may wish to check for cut, loose, frayed, taped, kinked, or otherwise dangerous looking chords. I also do not recommend using third party Universal laptop chargers bought from the store. I only would use one of these in an emergency situation. I don't trust the power regulation. And on top of that a laptop charger chord is so much cheaper on-line if you buy from somewhere like e-bay. That charger will be laptop model specific. Generally a new charger is about $15-35 on e-bay, and a new battery could be as cheap as $50. Although I would also recommend finding out if your laptop is under warranty. If it is within a year old this is a good possibility. That route takes a lot of patience, but it is usually free.
Aug 31, 2011 | Computers & Internet
Unit will not power on. Light on the charger does
if the light is not on, on the charger, check the fuse in the end of the car charger...the tip unscrews and there is a tiny fuse just under the tip.
if thats ok, check the fuse to the outlet you are using in your car.
if the light comes on the charger and it still wont charge, let me know and i can help you fix it.
the 3140 are known for there bad power ports.
bill
Dec 28, 2009 | Magellan Maestro 3140 GPS Devices
MP3 Wont charge or upload
u need a new cord for charging.u lost ur receipt so no problem u can buy it any electronic or computer market i hope.
Aug 03, 2009 | SanDisk Sansa Clip MP3 Player
I HAVE A LAPTOP ACER AND THE POWER DOES NOT TURN ON
It could be a battery problem. Try switching to AC mode by plugging in to an AC outlet using your Acer power chord (battery charger also). If the charger led don't light, it means it's defective and it can't charge your battery. Please try another power chord or battery charger then. Just remember to take out your battery when using your laptop in AC mode to lengthen your battery life. Regards!
Jul 05, 2009 | E-Machines eMachines Desktop PC
No power
If your battery become too dead the trickle charger wont recognize the battery so it wont charge it. However in that case you just need hook two batteries together to even the charge so it will recognize it. if your battery is truly charged then its a loose wire somewhere or bad switch.
Nov 10, 2008 | 2001 Laverda Formula 750
No power
Nov 10, 2008 | 2000 Laverda 750 SS
No power
Nov 10, 2008 | 1974 Laverda 1000 3C
Makita 2 Bl1830 18v Battery,dc18ra Charger Lxt Fr Drill Logo
605 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
