Question about Kenmore Washing Machines
I get a dL F error when trying to push the start button.
  • 15,935 Answers
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
Now plug the washer back in and test operate. NOTE: You can run diagnostics on these washers by referring to the tech sheet provided by the manufacturer. The tech sheet is located behind the lower panel under the door, or along the interior cabinet walls. Included, are instructions on how to run diagnostics and troubleshooting tips associated with the list of fault codes. It is recommended that this tech sheet remain inside the washer to prevent it from being lost.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!
Posted on Sep 14, 2010
Whirlpool duet washer It won't start, when I push start button it sounds like it is cycling but won't respond to start button, error code is f. And then dl
Momomacg, we're sorry to learn that you are receiving an error code on your Washer. We'll be glad to further review your concerns. Please send an email with your name, contact number, address, model and serial number to Whirlpool_Reviews@Whirlpool.com with a brief description of your concern.
Oct 23, 2017 | Whirlpool Washing Machines
Door is locked dl error code
Plug off the mains, remove bottom panel. Reach upwards to lock area to find a chord, pull downwards gently, door opens. Check the lock for loose wire, check small push button in lock area to make sure it is not broken, check latch on door.
May 10, 2010 | Kenmore Elite 45986 Front Load Washer
What does the error code fdl for my kitchenaid superba front load washer mean? The machine will not start when I push the start button.
F DL
A Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code.
Potential Causes
• Door Lock Mechanism broken or removed from the Door
• Check Door Lock/Switch Assembly
• Check the wire harness connections to the Door Lock/Switch Assembly and
Central Control Unit (CCU)
• Door Lock/Switch Assembly Failure
Ohm out the door lock solenoid and the door lock switches. This is most conveniently done at the central control board--use the wiring diagram/tech sheet to locate the proper pins to test from. Unplug the washer before starting work.
hope this helps....
Oct 26, 2009 | Washing Machines
Clicking and F dl error
Error code stands for door lock. May need a new door lock.
Oct 23, 2009 | Kenmore HE3T Washer
F/dl code comes on - machine doesn't run
failed door lock error, i would first unplug the unit for about 5 minutes this will reset the board. if that doesnt work you may have a bad door latch. .inspect latch that the piece on the door that when you close door piece on the door makes contact with the latch. hope this helps
Sep 16, 2009 | Kenmore Elite 45986 Front Load Washer
An error signal "DL" - door lock signal keeps coming on
Check for loose wires from the door lock to the control board.If no loose wires,
Replace the door lock switch.
May 23, 2009 | LG WM2277H Front Load Washer
Cycle wont start then I get Error / dl
the dl code is a door lock error,open door and examine door lock assy mounted on front panel.look for a plastic push pin approx 5inches up from square lock assy.if that pin is missing,replace door lock.if pin is there,you could still have bad door lock or loose wire connected to door lock.
Sep 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washer displays DL error
The FdL fault is a door lock error code. It sounds like you may have a bad door latch. Unplugging it and/or pushing the cancel button will not clear the fault as long as the fault condition exists. At best, you may have to replace the door latch. At worst, the CCU (main computer) could also be bad, causing the fault. The door latch can run about $50. The CCU is about $200. Double check all you wiring first before replacing any parts. I hope this will help you.
Mar 11, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
16 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
