Question about Sony Playstation 3 (PS3) Console
Problem with ps3 blu ray drive making a loud clicking noise
Hi, i have a ps3 bluray drive that won't load disks at all. When I power it on it make a real long clicking noise and then stops after approx 5 seconds. I have take the console apart and have tried it and the black rail on the left hand side slide when first powered on but then when it comes all the way back(where the disk goes in) the motor keeps the cogs going and that is causing the loud noise because the rail has nowhere else to go. I would say it is misaligned but I can't fugure it out and have tried numerous methods posted on various sites on the web.
PLEASE if soeone can help it would be greatly appreciated
  • 4 more comments
  • tancolemac Mar 10, 2009
    Sorry an 80gb.
    Sorry, I have 4 USB ports.
  • Anonymous Mar 11, 2009
    same here
  • tancolemac Mar 12, 2009
    No it is the flat gray color. It is a ceche01 build.
    Thanks I have tried that using a link to Wikipedia which had a post on it. I have tried everything to no avail. I am at the point where I am going to button it up and sell it as is i think
    Here is the link http://www.wikihow.com/Realign-Your-Ps3's-Blu-Ray-So-That-a-Disc-Can-Load-and-Eject . How much do you charge for another drive.
    President:
  • 2,653 Answers
I can help you with this, no prob.
which PS3 do you have?
Posted on Mar 10, 2009
  • 3 more comments
  • RescueTechLA
    RescueTechLA Mar 10, 2009
    Do you have four usb ports, or two?
  • RescueTechLA
    RescueTechLA Mar 11, 2009
    Does the bottom of your blu-ray drive have a shiny metal bottom?
  • RescueTechLA
    RescueTechLA Mar 12, 2009
    Great, those ones are much easier.
    I just fixed a drive with the same problem so here it is while it's fresh in my mind.
    Take the metal cover off the drive.
    Remove the 5 bottom screws (3 black for the front, and the two grey ones in the back)
    Then the additional 5 on the top once the cover is off.
    Next take off the single grey screw right where the disks go in. Pull the part off (The arms)
    Once that's off you'll see a big white cog wheel to the left. Just turn it until the side rail closest to it goes all the way back, don't force it past the last few teeth on the rail. You'll notice that where you had the plastic cover arm thing that the two legs will lay flat down.
    Now to the left and right of those arms are two sprockets (around the rubber band) Just make sure they're in place correctly. They tend to rise up a bit when you get the clicking.
    OK now that everything is in order just screw back the plastic thing. BEFORE you screw it down, make sure you wiggle the arms open a tiny bit so that the cogs line up.
    Put the plastic top back on and then test it out.
    DON'T put the lids and everything back until the drive is functioning correctly or else you're just wasting your time.
    That should fix your problem, if it doesn't just use common sense. Examine the drive closely to see where it's jamming up then just figure it out.
    Hope this helps.
  • RescueTechLA
    Can you send me the link to the wiki page?
    Thx.
    You can just buy another blu-ray drive and swap the blu-ray controller board if you can't it going too.
  • RescueTechLA
    Or you can send me the drive and I'll either fix it for you for swap it out with a working drive. I don't mind fixing it for free, it only take me a minute or two.
Why My Ps3 Keeps Ejecting BD?
This is a bad drive. I'd replace it immediately before trying anymore disks lest it damage the disks. Usually this occurs when there is a read error. It is also possible there is a disk stuck in the drive, jammed inside, the sensors, sensing the second disk automatically ejects the one you put in. Either way remove the drive and replace it with a PS3 replacement drive. (Note a way to test if it's a bad bluray lense is to stick a DVD in the drive. If it accepts the DVD and plays, then it can only read the DVDs and not the blu ray disks. If this is the case you've blown the blu ray laser, it still needs to be replaced.) If all else fails take it to a tech place and have them diagnose the problem.
Jul 29, 2014 | Sony Playstation 3 (PS3) Console
Tip
Bluray drive on PS3 does not accept discs after disassembling
This tip is for people who have already disassembled their Play Station 3 console and tried to replace the laser in the Blu ray optical drive.
If you replace the laser and then reassemble the Blu ray optical drive and the drive will no longer accept discs (like there is something blocking the disc) follow these steps to resolve.
(NOTE: if your PS3 is not accepting discs because the disc just won't push in, not like there is something solid blocking the drive, or your drive is making "grinding noises" refer to this tip: http://www.fixya.com/support/r4321102-bluray_drive_ps3_makes_grinding_noise )
Remove the metal casing of the Blu ray optical if you have not already done so. This requires removing the three black screws and the two silver screws on the bottom of the Blu ray optical drive.
With the metal casing removed, locate the 5 black screws on the top of the Blu ray optical drive to remove. There are two on either side and one at the back in the middle.
Keep the drive together for now (do not take the top off) and reattach to your Play Sation 3 console.
Turn on your PS3 and wait for it to power up.
Now, take the top of the Blu ray optical drive by “unfolding it” so the top of the drive rests on the PS3 power supply.
With the top off, hit the Eject button on the front of your PS3.
The drive gears should “pop” back into place.
Turn off your PS3 and reassemble the Blu ray drive. You should test your Blu ray drive first before reassembling the whole PS3.
on Feb 16, 2010 | Video Game Consoles & Games
PS3 won't accept certain disks. A few disks i have won't play in my ps3. it happens to both blu-ray movies and games, and it seems to only happen with blu ray disks. i'll put the disk in, and...
Hello
The noise is actually a product of dust from a blue ray disc.Over time these discs heat up and leave a residue on the blue ray lens.
Try using a lens cleaner to remove dirt and clean lens.
Also i read an article that using a wireless controler can also cause freezing of the blue ray.
Oct 01, 2011 | Sony Playstation 3 (PS3) Console
Disc makes funny noises when loading and cant connect to the internet. i bought it at a pawn shop and dont know how to tell if there is anything wrong with it but the warrenty is voided.
Hi and welcome to FixYa
Ok for the internet problems try connecting it directly to your internet modem without the router and also try connecting it with the wireless option of the ps3, if none of those options works, your ps3 network card is pretty much fried. About the disc making funny noise you might want to first if you know nothing about ps3 take it to a repair store after the diagnostic of the funny noises the next symptom you are going to get is problems reading bluray discs and after that you will probably have to replace the WHOLE DRIVE piece or if you are lucky just the PS3 lens. here are links for more info about prices:
PS3 Whole Drive:
http://cgi.ebay.com/Blu-Ray-Drive-KEM-400aaa-CECHA01-60gb-PS3-PS-3-USA-/350392305080?pt=Video_Games_Accessories&hash=item51950245b8
PS3 Lens:
http://cgi.ebay.com/KES-400AAA-KES-400A-Blue-Ray-Laser-Lens-Sony-PS3-/170532718671?pt=Video_Games_Accessories&hash=item27b48ac84f
remember after buying any of those check your PS3 Model.
Sincerely,
aDynamite.
Mar 08, 2011 | Video Game Consoles & Games
Disk drive is making a loud noise, and is no longer reading the disc. just makes a loud clicking noise when injecting or ejecting the disc.
PS3 blu-ray drives are pretty problematic. The best solution is to send your ps3 back (without opening it and trying to fix it yourself (voids the warranty)) to sony. Your drive sounds broken, happened to me once before, sent it back, and now its like brand new (took a bit for them to get it back to me though)
Oct 03, 2010 | Sony Playstation 3 (PS3) Console
PS3 won't load/recognize any disc (games, DVD, Blu-Ray, etc). What could be the issue?
This is a very common problem with the PS3 and is caused by a problem with the laser on the Bluray drive which is malfunctioning and can no longer read the game disk properly.
The PS3 uses a dual laser system. This consists of either a dual refractor type lens or two entirely seperate lenses depending on which pickup is fitted to your particular system. One laser is for reading ordinary DVD disks and PS2 disks and the other for Bluray and PS3 games.
The symptoms you describe are quite typical of a failure of one or both of these lasers.
For more information on how to resolve the problem please have a look at this FixYa Tip on the subject.
Many thanks for using FixYa.
Feb 15, 2010 | Sony Playstation 3 (PS3) Console
My PS3 wont read any discs at all - blu-ray or games
Depending on usage, the ps3's Blu-Ray player is known to burn out after sometime. My solution, sadly, is to send it in for a new drive. Don't forget to deactivate your system before sending it in. There are cases where you do not receive your own ps3 back and they send you a different refurbished system.
Sep 14, 2009 | Sony Playstation 3 (PS3) Console
Ps3 does not read discs
try using a cleaning disc..if this does not work ..you can replace the drive or the optical pick or blu-ray laser..I have repaired several ps3's and replaced the drives..
Jul 28, 2009 | Video Game Consoles & Games
Blu ray movies do not play
Have you checked your video output for the bluray to make sure it is set properly? You should be able to set it to automatic so it will be able to set the signal at the proper level. It also wouldn't hurt to try a lens cleaner which is for the Bluray and ps3 system. (approx $25 at BestBuy)
May 03, 2009 | Sony PlayStation® 3 (80GB) Console
Playstation 3 Blu Ray drive not working
Hi my name is Juan and the problem you got is with the bluray laser lens they have stopped reading games you can check this out put a cd on your ps3 and at the same time place your ear on top cover and will heard 3 clicking noises of the laser but make no noise because this clicking noise is so fine that you need to make no noise i goes click click click you will hear it but make sure you put your ear on top cover at the same time you insert the disk it takes about 3 -4 seconds for the clinking noise after you have insert the cd some lasers they do try to read and they make the disk to spin off and on some they do make the disk to spin normally but nothing happen and the solution is to replace the laser lens I am a ebay trusted power seller and I can get you one if you want to
Mar 16, 2009 | Sony PlayStation 3 40GB System
Sony Playstation 3 (PS3) Console Logo
1,625 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
