Question about PUR (FM-9500) Air Purifier
Which glue to reattach chromed plastic to plastic?
I have a PUR faucet-mount water filter, vertical, probably model FM-3700 - the kind that the bottom cover unscrews from so the filter can be changed. The finish is chrome, or to be precise chromed plastic, and the chromed plastic skin just came off the bottom cover (no, NOT while I was trying to change the filter).  It's clear where the original glue was applied and it's clear how the cover and the skin go back together - but what kind of glue should I use?
    President:
  • 2,976 Answers
Use old fashioned model cement. Not the child safe type. The old type will melt the styrene to the styrene. The new stuff only fills the gap but never really makes a good bond.
Posted on Mar 10, 2009
  • Paul Cyr Jul 20, 2014
    Any clear 2 part epoxy.
There are 2 holes on underside of filter housing & when turn on filter water , out both holes, why I hate running it as you don't know if you are getting filtered water from both holes.Help
The main problems I'm seeing on these posts for this filter are design and operater issues. 1. I never run hot water through the unit in filter mode. 2. I never run cold water through the filter turned on high (pressure issues arise), it doesn't filter the water any faster. You just want enough flow to run through the filter. 3. The steel sleeve was a good solution (again pressure) but came up alittle short (ie my epoxy fix). 4. The light is powered by a chip batterey that is unreplaceable and may be bad. Try reinstalling the cartridge. I personally pay no attention to the lights other than a clue. I change my filter when the taste changes or there becomes a flow issue. 5.There are filter screens prior the filter that can become clogged if you live in a poor water area. 6. The filtered water only comes out of the spigot and no other leaks (something loose or pressure issue).
Sep 30, 2013 | PUR (FM-9500) Air Purifier
Why is my Pur faucet filter so slow? It was not before
You either need to clean the the screen filters prior to as they may be blocked. The filter cartridge itself my need to be changed as you don't say how old it is.
Aug 29, 2013 | PUR 3-Stage Vertical Faucet Mount Gray...
What can be done to repair a leak from a tiny hole on the bottom of PUR water filter?
I am having the same issue. I've just replaced the filter and it started leaking out of this hole, where it never had before.
I am thinking that maybe the filter isn't seated properly, and that's causing the leak. But I have attached a picture of the hole in question. Any advice would be helpful. Thanks!
Feb 03, 2013 | PUR (FM-9500) Air Purifier
Red led light on constantly
electronic circuit needs replacement
Feb 01, 2009 | PUR (FM-9500) Air Purifier
I have a PUR 200 water filter/hot and cold dispenser and the cold
I have the same problem as both stated earlier. The cold water is not working and the night light does not work.
Jan 21, 2009 | PUR Air Purifiers
Can't remove the filter from my Pur Flavor Options faucet mount water filter
When mine gets stuck I stick the handle of a fork or spoon into the hole where the water comes out and use that to unscrew it. Works like a charm every time.
Aug 04, 2008 | PUR (FM-9500) Air Purifier
Water filter
electronic circuit needs repair
Jun 01, 2008 | PUR (FM-9500) Air Purifier
Under Counter Water Filter Leaking after Use Sometimes!
Got it! Your return line is clogged!
I have the same dispenser, and there are 3 tubes attached to it. One of them (black on mine) goes from the faucet to the drain pipe coming down from the sink. That line can get clogged over time with stuff coming out of your sink. You can probably disconnect that line at the drain pipe end and **** oput the connection and as much of the hose as you can get too., Reattach the line and you are done. Fire it up.
On my unit, we hear a dripping sound in the drain when the unit is charging. If you don't hear the dripping sound after using the unit, that line is probably clogged up!
See ya!
Everett
Mar 14, 2008 | Biozone Water Filters for Counter Top:...
Water Filter Leaks
Since you weren't very specific where it leaks or when it started (like after a filter change) it could be tough to troubleshoot this leak.
If it is leaking at the faucet connection try tightening up where it screws onto the faucet. Depending on your strength (or lack of) you may need to use pliers to get a tight connection. Don't go crazy tight or it will crack the plastic fitting. If it still leaks remove the unit from the faucet and check the rubber washer inside where it screws onto the faucet. Make sure it's still there and is centered inside the cup and seated properly. Then reattach the unit to the faucet and tighten it well.
If it's leaking from the main body try removing the filter and reinstalling it making sure you have seated the filter properly and screwed on the cover correctly, and all the way. When it is tight the water outlet will be exactly at the bottom of the unit. Sometimes it's tricky getting it tight enough especially with wet hands.
Finally, if the leak is coming from the filter on/off selector this could be tough to fix. I would try firmly pushing and pulling the selector knob in and out several times while in both the on and off positions. This may re-seat the leaking seal. I wouldn't be too hopeful about this fix though. You may need to replace the unit if this part is leaking.
Nov 18, 2007 | PUR (FM-9500) Air Purifier
PUR (FM-9500) Air Purifier Logo
296 people viewed this question
Top Air Purifiers Experts
Michael Youngman
Michael Youngman
Are you an Air Purifier Expert? Answer questions, earn points and help others
