Question about Dell Inspiron 6000 Notebook
Mouse doesn't work properly
I replaced the palmrest and touchpad component on the Inspiron 6000, but the problem persists. The drivers are the most current available. I do not want to use any other type of mouse, that kind of defeats the purpose of having a laptop. What else can I check to fix this problem?
    President:
  • 2,653 Answers
That's it. There's nothing else.
The problem is with the motherboard and not the touchpad component.
The only thing you could try is updating the bios but it's a long shoot.
Sorry to give you bad news, but it is what it is.
Posted on Mar 10, 2009
I have to hit touch pad 3-4 times to work when doing anything Dell Inspiron 1501
Make sure you have the latest touchpad driver from support.dell.com, then in the touchpad settings (Control panel, Mouse, touchpad tab) adjust the sensitivity.
If adjusting the sensitivity has no effect then it may just be wearing out, which would mean a palmrest replacement. Those are around $20
http://shop.ebay.com/i.html?_from=R40&_trksid=p5197.m570.l1313&_nkw=inspiron+1501+palmrest&_sacat=See-All-Categories
Jul 18, 2011 | Dell Inspiron 1501 Notebook
How can I replace the left touchpad button in a Dell Inspiron 6000? it's stuck inside the touchpad and doesn't work properly.
Hi There,
I'm a pro laptop rebuilder and I've dealt with this exact problem with both Inspiron 6000s and 640Ms many times. You'd think that it would be something easy to do when you see the button sitting right there on top near the front edge but, believe me, it's one of the trickiest and time consuming repairs you can possibly do on a Dell Laptop. I will now only perform it on machines I have bought speculatively for resale because it costs the customer too much to repair.
But, what's not all that difficult at all is to replace the entire palmrest/touchpad assembly. Here is the link to the Service Guide for your laptop. Look it over and see if you think you can do the replacement. If you feel comfortable with it, go to eBay and type in "Inspiron 6000 Palmrest" in the search window. I just checked and you've got 60 choices there of used and new ones.
Here's your Service Manual Link:
http://support.dell.com/support/edocs/systems/ins6000/en/sm/index.htm
If you think you need to have a laptop guy do it for you, at least you know what he should do and can provide the part, although he may want to help you with the selection, deciding what grade of used or whether to choose new.
Best Wishes
Aug 04, 2010 | Computers & Internet
Right-click, Left-click not working....
Hi. Connect a wired usb mouse and go to the device manager. Expand pointing device and right-click the touchpad and select uninstall. Restart your computer and windows will automatically reinstall the touchpad driver.
If it doesn't work, you have to replace the entire palmrest where the touchpad is integrated with.
hope it helped... ^_^
May 17, 2010 | Dell Inspiron 1525 (dndppa1_3) Intel Core...
Dell Inspiron E1505 Buttons on mouse NOT RESPONDING, Left or right.
run your comp in safe mode, if still not working, run 32 bit dell diagnostic using teh drivers disc, test touchpad, if still not working replace palmrest
Feb 21, 2010 | Dell Inspiron E1505 Notebook
Both of my clickers on my laptop mouse will not work.
If both the mouse buttons on the touchpad do not work, then you will need to replace the palmrest assembly.
Jan 22, 2010 | Dell Inspiron 1545 Notebook
The touchpad mouse on my toshiba salellite does not function even though it shows it working properly when you go into the touchpad icon. I have an external wireless mouse (usb) hooked up that works fine...
The touchpad is most probably defective. If you have dropped your laptop the touchpad cable could have get out from its connector on the mainboard. You can get a new touchpad/palmrest on ebay. You have to remove your touchpad/palmrest as shown in the link below, steps 17 to 19 :
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-motherboard-1.htm
Identify the part number of your touchpad/palmrest. Search on ebay.com : Toshiba Satelitte A105 palmrest. Buy the one with the same part numer as yours.
...or have your laptop repaired by a professional.
Oct 09, 2009 | Toshiba Satellite A105 Notebook
1525 Right Touchpad Button Problem
It sounds like the switch on the button has failed.
Go to control panel, mouse and make sure the right click hasn't been disabled if no change, replace the palmrest.
The touchpad is part of the palmrest assembly and the entire palmrest will need to be replaced They are available on EBay for around $25
Jun 13, 2009 | Dell Inspiron 1525 Laptop
Touchpad on my 8200 insprion stop working
Try to test it using 32 bit diagnostic
tap F12 (just after Dell Splash Screen)
select Diagnostic partition
wait for test to finish
select Custom test (may need to use TAB and ENTER)
select pointing device
if it work here, it is likely a driver issues - got to support.dell.com and download latest pointer drivers (Alps under Input Devices?) You may as well do this first since it is easier than testing see http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=22&l=en&s=dfh&os=WW1&osl=en&catid=&impid=&SystemID=INS_PNT_P4_8200
If it does not work her, you'll need to pop it open and see if cables are tight, if they are the touchpad is broken and you'll need a replacement palmrest (included the palmrest)
see the manual at support.dell.com for info on disassembling your model if required.
Feb 02, 2009 | Dell Inspiron 8200 Notebook
Dell Inspiron 6000 Alps Touchpad not working
Try unistalling the touchpad driver, and reboot. The machine will find the touchpad and reinstall the driver automatically. These have a tenancy to glitch when using an external mouse, and this should clear it up. Let me know.
Aug 28, 2008 | Computers & Internet
Dell Inspiron 6000 Notebook Logo
50 people viewed this question
Alun Cox
