Question about Thermador Kitchen Ranges
Thermador range (oven) is stuck in OFF mode.
My oven seems to be stuck in a lock mode. While the oven was on I bumped into the buttons that control the oven and it shut the oven off and now when I try to push any of the buttons (conv, bake, clock, timer) it just reads OFF. I don't have the care and use manual because the range came with the house when we bought it, it seems to be an older one. Please Help.
I have exactly the same issue with the same model. Did you find a solution? Thanks.
Posted on Mar 18, 2011
  • ppeterson53 Mar 21, 2011
    I have the same issue. When I press any button for the oven, I can hear it click and see off on the panel then you can hear it click off. Need a solution.
1 of 2 bulbs in upper unit stopped working. I replaced the bulb 10W, 12v & both bulbs worked. Later, both bulbs stopped working. Both bulbs have continuity. New bulbs don't fix issue. Ideas??
Thermador Appliances ' Frequently Asked Questions ' Use ...
www.thermador.com/faq/categories.php?categoryid=53
ThermadorContact us for help with service & repair needs. ... The anti-tip bracket is not needed for 48" Harmony units. However, the anti-tip ... Oven light is not working properly. Replace ... Buy a replacement bulb. View the ... The rack positions that you would use when baking 3 racks in the convection mode would be racks 1,2 and 4.
Thermador Range/Stove/Oven Parts - RepairClinic.com
www.repairclinic.com/Shop...Parts/.../Thermador-Range-Stove-Oven-Par...
Huge selection of Thermador Range/Stove/Oven parts in stock. Same day ... Stove top potentiometer Kit that contains 2 potentiometer's and 1 simmer controller.
[PDF]for Thermador Professional Series Built-in Wall Ovens
www.msaworld.com/.../Service-Manual-Therm-Pro-BIWO_RevA3.pdf
Dec 19, 2015 | Thermador C272 Electric Double Oven
Frigidaire stuck in DR mode
Good Morning ShawnR, thank you for your post!
An error code DR commonly refers to a door lock malfunction. I understand you have reprogrammed the range by unplugging it. It is important to wait approximately ten minutes and then turn your range back on. Typically, this will clear most false error codes. If the error code continues to display, your range could possibly have a faulty door latch, light switch or EOC (electronic oven control). I am fairly confident that an authorized service agent will be able to restore your appliance to its normal operating condition. You can often locate a qualified service technician on the manufacturer website.
Thanks for allowing me the opportunity to assist you!
Nov 26, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Gas stove Thermadore 36 inch Model PGR366 PL Oven wont bake but will broil
this may seem like a silly question if you've already tried it but have you checked the over temp breaker? If you have no idea what I'm saying there is a breaker on the back side of your machine. Of course Thermador is so kind to place it convenietly behind the back panel so you'll have to remove that. There should be a little red button in there somewhere toward the top middle half of the machine I should say. If you press that button it may work.
Nov 05, 2008 | Thermador PGR366 Gas Kitchen Range
Thermador 30" Dual-Fuel Range 0FF error
Make sure there is proper electrical power going to range. Then check your kitcen circuit breakers or fuse box in your house, then reset the oven controls.
LOL look what i found, a CHILD LOCKOUT FUNCTION-- check this out
TO SET CHILD LOCKOUT
Press and hold the COOK MIN/HR and STOP TIME buttons until indicator word OFF appears in the
display (approximately 6 seconds).
TO CANCEL THE CHILD LOCKOUT
Press and Hold the COOK MIN/HR and STOP TIME buttons until indicator word OFF disappears
from the display (approximately 6 seconds). Mode selections will now be available on the control panel.
looks like someones could have been playing with the buttons and locked you out..
Let me know what happen.........................please rate this
Oct 15, 2008 | Thermador RDF30 Dual Fuel (Electric and...
Oven light
I'm Neil
No problem
Call Thermadore you have a warranty!
Please rate my soloution
Aug 24, 2008 | Thermador PGR366 Gas Kitchen Range
Flashing Lights on Thermador Oven/Range
I HAVE THE SAME PROBLEM. MY OVEN BINKS ONCE FROM BAKE AND TWICE FROM THE OTHER LIGHT. OVEN DOES NOT WORK, ADND WE REPLACE THE CONTROL BOARD ALREADY. WHAT DOES THAT MEAN?
Jul 02, 2008 | Thermador PG486GEBS Stainless Steel...
Thermador SC302T clicking noise, locked door after power outage
iodine, open the upper oven, look thru the grill below the control panel on the right side and there is your model number. The issue here is that when the power came back on the oven run thru a test and your lower lock motor has failed. It will need to be replaced. Yes the only way to stop this is to shut off the breaker.
Feb 03, 2008 | Thermador SC302T Electric Double Oven
Kitchen Ranges Logo
510 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
butch welch
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
