Question about Logitech X-530 Computer Speakers
What does the adapter cable look like?
It is the x-530 series
An adapter cable is mostly black and as one end that can connect to a computer and the other that can connect to A electronic device - you need to pay attention to see if it i the right model
I hope this helps you S.S
Posted on Dec 24, 2010
How to hook up keyboard to my dell Inspiron 530
Keyboard come with two different connection options these days. The old PS2-style (circular with ~5 pins) port are less common on current machines these days. The Dell Inspiron 530 is one of them; you need a USB keyboard or a PS2 to USB adapter. This adapter, http://www.amazon.com/Adesso-Adapter-connects-connectors-ADP-PU21/dp/B00008ZPED , is an example of how you would connect your old keyboard to your new computer. There are USB ports on the front and back of the tower.
If you bought the computer new, it should have come with a USB keyboard.
I hope this helps.
Feb 24, 2013 | Dell Inspiron 530 Desktop Computer
HP 530 wireless will not pick up any wireless networks. Please help
Hi.
First ensure that the wireless adapter is turned on.
If the adapter is on and does not detect any network, reinstall wireless network adapter drivers. the drivers can be obtained using the link below.
Download drivers and software
Reinstalling driver software usually fixes the problem, if it does not it usually means that the internal adapter is defective, in that case you will need to use an external wireless adapter (USB).
Sep 27, 2010 | HP 530 Notebook PC
Parasitic current drawn on battery on bmw 530 d tourer 1999
put an ammeter in SERIES with one of the battery cables. pull each fuse and take a reading. when it goes down to the correct draw...whatever that is, that would be the circuit with the excess draw.
Power seat, horn, alarm, anything powered without the key is suspect.
Dec 03, 2009 | 2001 BMW 5 Series
Cant comp to work,it's plugged in and when you go
Remove Any Docking Stations or Port Replicators From the Computer Note: Docking stations and port replicators are optional equipment. If you are unsure if you have a docking solution attached to your computer, refer to Table 1 and Table 2 for examples. To remove the docking station or port replicator, perform the following steps: Shut down the computer. Remove the docking station: Universal Docking Stations: Disconnect the docking station's USB cable from the computer. D/Port or D/Dock: Remove any cable locks from the security slot on the right side of the docking station. Move the slide lock forward to the unlocked position. Press the Eject button and lift the computer from the docking station. C/Port II or C/Dock II: Remove any cable locks from the security slot on the left side of the docking station. Pull the locking lever forward until it stops to eject the computer, then slide the computer out of the docking station. Dell manufactures the following docking stations and port replicators (Table 1): D-series DocksC-series DocksSpecialty Docks D/PortLatitude? C/Port IIMedia Bases D/DockLatitude? C/Dock IIInspiron? Advanced Port Replicator Table 1: Dell Docking Stations (Click an image to enlarge it) Universal docking solutions are also available from third-party manufacturers including, but not limited to, the products below (Table 2): TargusKensingtonBelkin Table 2: Universal Docking Solutions (Click an image to enlarge it) Disconnect All Peripherals from the Computer Remove all external connections from the computer. This includes but is not limited to the following devices: docking station or advanced port replicator keyboard mouse speakers or microphone printers scanners USB or 1394 devices palm pilots zip drives secondary battery Plug the AC Power Adapter into the Laptop Computer Remove the battery from the computer. Connect the AC adapter directly to the computer Verify That the AC Power Adapter Has a Solid Green or Blue Light Verify the AC power adapter displays a solid green or blue light. Older Latitude? C Series laptop computer AC adapters may not have a light. The new E series power adapter indicator light is either a blue ring or a blue dot and is located at the tip, on the DC connector, not on the power brick itself (Figure 1). Figure 1: E Series Power Adapter Indicator Light Location Numbers reference image above: E Series Power Adapter Indicator - Blue Ring E Series Power Adapter Indicator - Blue Dot D series power adapters have a green lights located on the power brick (Figure2). Figure 2: D Series Powed Adapter Indicator Light Location Numbers reference image above: D Series Power Adapter Power Brick D Series Power Adapter Power Indicator Light Shut Down the System If the computer currently is turned ON, running on the battery, shut down the system: 1 Click Start. 2 Click Shutdown. 3 Choose Shutdown from the menu. 4 Click OK. 5 Allow the system to power off. Plug the AC Adapter into a Known-Good Wall Outlet Verify the wall outlet is known-good by testing it with another device, such as a lamp. Confirm there are no power strips, surge protectors, or uninterruptible power supplies (UPS devices) connected to the power cable. UPS devices provide temporary power for a computer when there is no electricity available from the wall socket, such as during a power outage. Plug the power cable into the known-good wall outlet. Power up the system. Replace the MiniPCI Door, Rubber Feet, and System Motherboard
Nov 07, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
How do i setup x-530 to a pc
The color coded wires that come out of the main, volume controlling speaker should match those in which your computer came with. if not, logitech include an amazing little adapter that caters to computers with the red/white audio inputs in which you just need a red/white -> red/white audio cable.
Jul 02, 2009 | Logitech X-530 Computer Speakers
Can i hook X-530 to a laptop?if so how.
Yes , you can hook X-530 to a laptop.
I have the same speakers and they come with a 'game adapter'; one side of it accommodates the three plugs and the other side has two plugs for an RCA cable adapter. All you need now is a 2xRCA plug to 1x3.5mm stereo plug which you can buy for $5-$10 from JB Hi-fi and hey presto, you can plug it all into the single headphone slot on your laptop.
Thanks for using Fixya.
Mar 28, 2009 | Logitech X-530 Computer Speakers
Garmin Rino 530 battery wont charge
The video on the link below shows how to replace the battery in a Garmin Nuvi:
How To Change The Battery On A Garmin Nuvi 760
Nov 15, 2008 | Garmin Rino 530
LOGICTECH X-530
That speaker equipment should've came with an adapter to audio cables
its a rectangle that has 3 ports (orange,black,green) that lead out to 2 ports (red,white) from there u need the audio cables or AV cables
connected the red/white prong to the red/white ports on the adapter.
then connect the other end to the back of the tv where you will c white yellow and red
for dvd player connect it to the white and red ports
dont wry about the yellow 1 that is for video
Oct 18, 2008 | Logitech X-530 Computer Speakers
Speaker layout & adapters
how do i wire x 530 need diagram
Sep 04, 2008 | Logitech X-530 Computer Speakers
Connecting Logitech X-530 speakers to TV flatscreen.
It really depends on what the Tv is capable of, and how you want to strategize the connection, but yes, it can be done.
According to the X-530 User Manual , the speaker system comes with an included video game adapter, for hookup with a console. if your LCD TV has stereo RCA output jacks, you could hook up your speakers to it in that fashion. If not, you may have to buy an adapter that converts whatever you have to RCA.
Another way you could attempt to connect it, is to buy a stereo RCA-to-3.5mm (g9) adapter, and connect to your computer's line in (if it's stereo). Your computer would be doing all the speaker sound positioning, and would have to be left on while you're watching TV, but that would work, as well.
Jan 01, 2008 | Logitech X-530 Computer Speakers
Logitech X-530 Computer Speakers Logo
217 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
