Question about Amana ABB2527DES Stainless Steel Bottom Freezer Refrigerator
The ahndle on the freezer door is off can i fix it
The handle on the freezer door is off can i fix it myself. Dose the whole door need to be taken apart
  • tmrowka Mar 10, 2009
    it is an Amana ABB2527 DEW. I'm concerned that I might need to take apart the door. The two metal components. The one on the actual door is attatched witht a screw and if I tighten it the is no real way to hook it back to the metal component on the door latch,
  • 410 Answers
Most of these units have set screws that are tightened with an allen wrench the screw is on the bottom of the handle on eihter end of the handle hope that helps. if this doesnt answer your question if you would post a complete model number off of the unit I could look it up and be sure. thanks Peyton
Posted on Mar 10, 2009
Door locked shut
Hi found myself in same situation. Press in latch and insert fingers upwards there is a grey plastic strip push this up with fingers and door should open. Note upward press needed where this catch meets front of machine so just slide fingers up from latch/handle. There's actually no need to take top off to enable this.
Dec 27, 2013 | Smeg STX2 Dishwashers
My door handle on the drivers is broken. I want to replace it myself. I have the part, the door handle itself is an easy fix for me , but I'm not sure how to remove the door panel itself. My 1998 Cadillac...
save yourself some time, skinned knuckles, and grief and take the whole thing to an autobody shop. They can put it in for you quickly and fairly cheaply. I did not say dealer, i said autobody shop.
Feb 18, 2011 | 1998 Cadillac DeVille
Whirlpool stainless french door refrig...need to take handle off bottom freezer door so I can move it out of house. Is this possible without taking off the whole door?
it is much better to remove the complete door instead of handle . there are 4 screws inside that will release the complete door . if your want to do the handle use a credit card and insert it between the handle and door to release . but if stainless it some times leaves marks on door . i always remove the doors as one door is ever and i mean very costly.. mm hope this helps mm feed back pls ..
Nov 08, 2010 | Whirlpool GX5FHTXTS Stainless Steel Bottom...
Driver door handler does not open door out side
mcdevito75 here, Sounds like the linkage on the inside of the door came off the handle, let a glass repair shop fix it.
Jun 16, 2010 | 2002 Saturn Sl
I have a 1999 Astro and the dor will not open using the latch from the inside. Someone has taken the ashtray off of the door and I can slide my hand inside and move the leaver so that it will unlatch the...
there is a rod that goes from latch to the handle possible disconnected and was never reattached the rod is held in place with a plastic clip -any auto store carry them -other is handle broke and will need to replace whole handle assembly -salvage yard,online or dealer for part use a mirror to look in the door behind lock it u cant access the lock will have to pull door panel of to repair and or replace parts
Jun 14, 2010 | 2002 Chevrolet Astro
Sears trio elite ...french doors with bottom freezer...right side loose on freezer door handle...thanks
I have the same refrig. After taking the freezer basket hinges off, thinking I had to take the whole door a part to access the screws for the handle...my husband figured that the handle probably slides off...and yes that is just what it does!
Push the handle in a bit and then slide to the right. It takes a little bit of effort but that handle will come right off. Then you can tighten the screw that holds the clip in place. Then you line the handle back up to the clips, and slide to the left. Good Luck!
Apr 08, 2009 | Kenmore Refrigerators
Amana AFI2538AEW bottom freezer door handle is loose?
My dad's freezer handle is loose, model ABB2224DEW. Went to partselect.com and located drawing of freezer door parts. Found a link to a "do-it-yourselfer" that describes removal and replacement of the handle. Hopefully this helps.
Replacement of freezer door handle.
1. Removed freezer door handle. First I read the freezer door handle removal instructions in the Amana refrigerator user guide. Removing the handle requires inserting a plastic card at least 1.5 inches under the left end of the right side of the handle so it releases the butterfly clip latch on the freezer door. Next I pulled the right side of the handle to lift it away from the freezer door. Then still holding the handle away from the door, at the spot that is 1.5 inches from the inside of the right side of the handle, I held the plastic card vertically and slid one corner of it between the handle and the freezer door and worked the card down until it released the butterfly clip latch. Keeping the card at the same space under the handle so the latch was released, I then turned the card to the left until it was horizontal and was lifting the left end of the right door handle away from the freezer door. I then slid the handle across the card to the left until it cleared both door butterfly clip latches and it lifted off the door.
2. Installed freezer door handle. First I read the freezer door handle installation instructions in the Amana refrigerator user guide. The handle is curved on one edge and must be installed the curved side down. Correctly installed, the outside ends of the handle curve upward and the handle curve is down so it looks like a frowning mouth. Next holding the handle curved edge down, I turned it up so I could see the brackets and held it against the door. I lined up the handle brackets slightly to the left of the butterfly clips on the freezer door. Next I turned the handle with the brackets against the freezer door and slid it slightly to the right until the left side of the handle held onto the door butterfly clip by itself but was not latched. Then I lined up the right handle bracket with the right freezer door butterfly clip and carefully slid the whole handle to the right until I heard the left butterfly clip latch click. Next I slid the handle back slightly left once more and then slid it back to the right until I heard the right butterfly clip latch click.
Parts Used: HANDLE, DOOR (WHT) Level of difficulty: Difficult Time to do repair: 30 - 60 mins
Apr 02, 2009 | Amana AFI2538A Bottom Freezer French Door...
The entire door handle snapped off
I have the same problem- funny when we built we went all Maytag and got a bunch of lousy handles- the stove, micro, fridge, and freezer... I glued the pieces of the handle together and used plumber's putty to fix it. It's MightyPutty, but without the repackaging and cost. Just knead the putty until mixed, fill the cavity of the handle and press on the door where it was... No problem after six months so far.
Nov 30, 2008 | Maytag MMV5207A Microwave Oven
Bottom freezer door handle loose
There is a plastic card that you are supposed to slide under the right side of the handle. Once you have done this correctly the whole handle should slide off to the left.
Nov 14, 2008 | Amana ABB1927DE Bottom Freezer...
Freezer door handle loose
Use a 3/32 Allen wrench to tighten the screw on the side of the door handle
Jul 16, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
Amana ABB2527DES Stainless Steel Bottom Freezer Refrigerator Logo
117 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
