Question about Hoover F7205900 SteamVac V2 Wet/Dry Vacuum
Brushes won't spin
My Spin and Scrub Steam Vac: The brushes won't spin. I can not find what makes it spin. Is it suppose to spin under pressure or under vacuum or??? Please help. I am pretty handy, but I am stumped!
Thank you,
Jim Jensen
jimjensen@netzero.net
  • 11,896 Answers
The brushes are turned by belt and/or motor.
Posted on Mar 10, 2009
Hoover F7410-900 Steam Vac Dual V scrub brushes not working
If the brushes will to spin when you try to turn them by hand remove them from the machine. If the brushes spin ok after removing them the the turbine assembly is seized up and will likely need replaced. If the brushes won't spin when they are removed from machine take the plastic cover off the brushes and clean out the gears.
Nov 03, 2013 | Hoover F7425-900 SteamVac V2 Widepath...
The spin brushes on my hoover steam And vac don't
Either the pin on the brushes that attaches to the motor shaft is broken, or the motor is dead. Did you check the switch on the front of the unit to make sure it wasn't turned off?
May 16, 2012 | Hoover Vacuums
Does the Hoover F5835-900 have spin scrub brushes?
No. The F5893-900 has a brush but it is just a straight brush and does not spin.
Jul 18, 2010 | Hoover F5835900 Upright Steam Vacuum
Help. The brushes on my Steam Vac Spin Scrub
If you don't have the user's manual for the machine, here it is:
www.thinkvacuums.com/pdf/uprights/Hoover_F5914900.pdf
Check your system for any obstructions that could possibly causing the problem. Also, remove the brushes and see if there's a problem between the brushes and the motor.
Aug 25, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Brushes will not spin while locked in machine..
I have the same problem and think I know the solution.
The plastic pegs on the housing unit for the brushes have been stripped out. The pegs are supposed to be squared tip to click into the square hole of the machine. If the pegs aren't the same shape as the hole, the machine can't grab them to spin the brushes.
The tallest peg on mine somehow got stripped to a rounded shape. I tried wrapping tape, plastic, etc around the peg to make it fit in the hole snug, but it only worked for a few seconds and broke again. I am going to have to replace the brush set. You can order parts from Hoover but I haven't priced them yet.
I hope this helps you. Certainly is cheaper than replacing a motor or machine.
Aug 23, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
Do not know how to use Hoover Steam Vac Spin Scrub
Hoovers website, Hoover.com has them free to print.
Jun 13, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Remove the brush block, is the shaft on it or broken off. Replace the block if broken off. Turn unit over, with brush block removed, handle tilted back, is the square hole turning, if not then the turbine is bad, this is what turns the brushes.
Sep 01, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Hoover Steam Vac Spin Scrub Carpet Cleaner won't suck
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=728884
Hoover Steam Vac Spin Scrub Carpet Cleaner won't...
Posted by hoofbeats1 on Jul 01, 2008
My machine is a little more than a year old. I have used it about 5 times. It started leaking the third time I used it. The fourth time I took it out, the brushes would not spin (I did clean them and rinse them after use each time).
Now the engine screams and won't **** anything up. Do you have any suggestions? My last Hoover Steam Vac was great and lasted for 3 years! Hi,
I have a Hoover Dual V SteamVac F7425-900 that the brushes won't spin. The lint screen is clean & the brushes switch is in the on position.
It dispenses & sucks up the cleaning solution & water; just no brush action. Help
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The only thing that I can recommend is that you may have a bad switch, some vacs may have a broken belt or the drive mechanism inside the Hoover Dual V SteamVac F7425-900 in or by the brush assm section and is need of repair. Please check the trouble shooting section of the owner’s manual if you’re needing help and to save money. If you don’t have one then contact the Hoover factory cust serv. So, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 01, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
HOOVER STEAM VAC SPIN SCRUB
Cannot hook the upholstery cleaner into slot..lost manual in fire
Jun 16, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Hoover F7205900 SteamVac V2 Wet/Dry Vacuum Logo
678 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
