Question about Maytag Dryers
Can't figure out how to get belt on. On model de808. It's a older dryer.
  • Maytag Master
  • 8,220 Answers
Put the slick side down on the drum and go by ths BELT CONFIGAMATIONAL. heeheeee
Posted on Mar 10, 2009
Replace a belt on indesit dryer
Hello.
Tools needed to solve the problem
(A)Standard screwdriver,New belt
1 Unplug your dryer to disconnect power to the unit.
2 Remove the screws that hold the dryer top in place using a standard screwdriver. The screws are located along the top and sides of the dryer. With older models -- 1996 and older -- the entire top comes off the dryer. For new models, the timer and console stay in place while the rest of the top comes off.
3 Remove the screws that hold the front panel and door in place using a standard screwdriver. The screws are just inside the door at the top front left and right sides of the dryer. The front panel on older models will move to the right side and on newer models the door will move to the left.
4 Remove the existing belt by pulling the idler pulley to the right. This will take the tension off the belt and allow you to pull it away from the motor pulley.
5 Install the new dryer belt by wrapping it around the top of the drum and allowing it to fall around the circumference of the drum. The grooves of the new belt should face down toward the drum. Rotate the belt around the drum to ensure there are no twists in it.
6 Connect the new belt to the motor pulley. On newer models you can access the motor pulley on the front underneath side of the dryer. Pull the idler pulley to the right and loop the belt around it. On older models you can access the motor pulley through an access panel on the back of the dryer. Pull the dryer away from the wall and remove the access panel using a standard screwdriver. Repeat the same steps as on a newer dryer to install the belt around the motor and idler pulleys.
7 Replace the front panel of the dryer and the screws that hold it in place.
8 Replace the top of the dryer and the screws that hold it in place.
9 Plug the dryer in and make sure the belt works properly before trying to use the unit.
Thanks.
Nov 07, 2011 | Indesit W 123 Front Load Washer
Kenmore dryer,, looking for adiagram for the belt on a kenmore dryer
Below are the belt diagrams for Kenmore dryers.
Figure 1. Whirlpool-made Kenmore dryers with removable back panel, filter on top, and model numbers starting with 110 or C110.
Figure 2. Whirlpool-made Kenmore dryers with non-removable back panel, filter below the door, and model numbers starting with 110 or C110.
Figure 3. Frigidaire-made Kenmore dryers (model numbers starting with 417).
Mar 01, 2011 | Kenmore Dryers
Dryer will not turn on is there a fuse in an older kenmore heavy duty dryer
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Dec 12, 2010 | Kenmore 500 6952 Dryer
Tub is not rotating but the belt is intact,it is an older model but dont know the model number
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Nov 24, 2010 | Maytag Dryers
The belt was broken on my older model Whirlpool Imperial Ser. H/D
no there's no pulley "wheel", but it's essentially the same. the attachment should show you via the whirlpool,kenmore-kitchen aid illustration.
hope that does it for you,
good luck
Sep 28, 2009 | Whirlpool Dryers
I need a belt feed diagram/maybe owners manual for my dryer
do you have the brand and model number?
Apr 08, 2009 | Dryers
My whirlpool clothes dryer will not start.
Hello Rick,
Use this link to get information for your dryer.. it should provide you with everything you need. Get back to me if you are still having problems..
http://www.pcappliancerepair.com/model-display.php
Regards,
Rick
Nov 28, 2008 | Whirlpool Dryers
We are trying to install a dryer belt onto a GE older moder dryer and can't figure it out. The model no is GDX8060RT429
Hi. thanks for the question. remove the top. lift , remove front. slide belt on drum .clean all lint. reinstall front and top. pull away from wall. remove back panel. motor on right idler pulley on left bring the belt down to push idler down ,to give the belt tension .put belt around motor pulley . thanks the appliance doc
Oct 02, 2008 | Dryers
Dryers Logo
50 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
