Question about GE GBS22HCR Bottom Freezer Refrigerator
Inglis Fridge model# IRT184300, warm fridge, cold freezer
I have an Inglis Fridge model# IRT184300, serial# VSW3898084 and the freezer works great, but the fridge is warm. As far as I can tell, there is only one temp control(in the fridge), and it is set to the coldest setting. I also get water accumulating on the top shelf of the fridge. (caused by temp difference between the fridge and freezer maybe? dunno...) The fridge is new, MFG date is 09-08. Any ideas?
  • 2,418 Answers
There is a fan in the top of the refrig that is not turning. Ck for that fan and pos. ice build up in between.
Posted on Mar 10, 2009
Top section of my side by side kitchen aid frodge stop cooling bottom is still cooling and freezer still working
send the model number?if the freezer is cold but in fridge the top is warm and the bottom is cold it sounds like you have a bad evaporator fan motor,all it does is cold starts in the freezer at the evaporator coil,and the evap fan blows the cold air into the fridge section,warm air rises so if the fan isn't working the cold air will stay down low and the warm air will stay up on top,open the freezer door,if you don't hear the fan blowing in the freezer i would have to say the evap fan motor is bad,if the fan is working one of the doors could have been left open and the air ducts froze up or you could have a damper in your model,it's just a door that opens and closes to let the air blow in but send the model number so whoever helps you can look up your fridge,usually the model number for a sxs is in the fridge section open the fridge door look up on the right hand wall up near the ceiling or in the middle of ceiling and there should be a tag with model and serial numbers just send the model number,
Jan 07, 2018 | Refrigerators
We bought used fridge Inglis/Niagara Model ICT85000 Mfg06/93 when we close fridge door freezer door opens. When we close freeze door fridge door opens. This is a top freezer. Is there a repair
Inglis are a budget make. The cold for the fridge comes from a vent from the freezer. Don't let the door slam. You must close them gently.
Dec 30, 2016 | Refrigerators
Where is the drip pan on my Inglis IRT184300 fridge
USUALLY AT THE BACK BOTTOM OF FRIDGE OR IN THE FRONT AT BOTTOM. U MAY HAVE TO SNAP OFF THE COVER TO GET TO IT
Sep 30, 2013 | Frost Inglis 17.6 Cu. Ft. -Free Top-Mount...
II have a model 5707591 side by side in my garage.as long as the ambient temp is 35-40 F everything works great.when it gets below that the freezer cant keep frozen.temps will rise to 25 F while the fridge...
the thermostat isn't cycling because it's to cold in the garrage,the machine isn't calling for cold air because the garrage is so cold so the fridge isn't gonna run until the temperature starts to get warm and then the fridge will start again to keep it cold.put some heat in the garrage and it will run fine
Feb 27, 2011 | Kenmore Refrigerators
Freezer at top of my inglis fridge has many times warmed up for no apparent reason.It is only 1and1/2 years old.Now has stopped working altogether.The fridge is warming up too.It has only a single...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 14, 2011 | Refrigerators
Buyers Beware!
go to sears
Aug 14, 2009 | Refrigerators
My freezer works perfect but everything in the refrigerator doesn't get cold enough. My milk sours. My fridge is an inglis and supposedly brand new
Warm fridge cold freezer problem fixed
In the freezer section there was a one screw removable panel which housed a four bladed rotary fan. One blade had broken off adn was jamming the fan from rotating. Once the broken part was removed the fan was free to rotate, but out of balance, but it did get the fridge going again. It took about one minute to replace the fan once a spare was aquired. Now I understand how it works, if one side of your fridge freezer is not working it can only be the air movement or lack of it Robert
Robert
Dec 30, 2008 | Refrigerators
Can't find the adjustment for the freezer on my Inglis fridge. Model-IRT184300 Ser.VST3315228
hi thanks for the question i looked at your model no and your control is as you open the fridge door its right there on the roof of the fridge in the middle thanks for the question the appliance doc
Sep 13, 2008 | Refrigerators
Cold freezer warm fridge.
That sound was the evaporator fan motor in the freezer. This circulates the cold air from the freezer into the fresh food section. If this is not running you need to check for power to it. If the fan has power to it but not running, replace it. It should be located behind freezers back wall inside of freezer near top.
Oct 09, 2007 | Refrigerators
GE GBS22HCR Bottom Freezer Refrigerator Logo
1,209 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
