Question about Carrier 38CKC036 Air Conditioner
Goodman not working on auto on in the "on" position
My unit is about 3 years old. It seems to be blowing out cold air but the temp on the thermostat doesn't go down either.
  • 1 more comment
  • cherylmsmc Mar 10, 2009
    No, the outside is not running.
  • steve
    steve May 11, 2010
    If the outside unit is not running check high voltage power to the unit for 220 volts.
    The defrost board on the outside unit has a red wire on it, it should be labeled 24v.
    Carefully unplug then re-plug the wire on the board.
  • steve
    steve May 11, 2010
    Is the outside unit running.
  • 182 Answers
The first job of an ac is to dehumidify.Is the heumidity high?If so,give it time.
Posted on Mar 10, 2009
Fan on unit comes on but no cold air comes from the registers
is the outside compressor running or just the condensor fan.
Jun 18, 2014 | Goodman Heating & Cooling
several possibilities inside fan not running,dirty coil,duct work problem. turn tstat to fan on position see if it make a difference.
Furnace blower runs after temp is reached
Is your tstat fan selector in auto?? Does the fan ever shut off?
Jul 18, 2017 | Heating & Cooling
What happen when your hvac blows cold air and the heat is set at 73
Sounds like you have a thermostat problem. If your thermostat is not triggering the furnace to ON/HEAT you will not the heat you desire. IF you know how to trigger the furnace you could jump your furnace controller wires BUT DON'T do this. Instead, get another thermostat and try it. But be sure to get the same rated thermostat... take it with you when looking for a replacement.
Not sure about everything going on with your unit based upon what you provided but your thermostat should show the current temp and the temp you set. It also show the mode that the thermostat is in (HEAT / COOL / AUTO) Manually select heat, then increase temp above the current temp setting. listen for furnace to activate or wait a few minutes for warm air output. If not, you'll have to see assistance trom a local heating and cooling company.
Mar 09, 2011 | Goodman Heating & Cooling
Hi. I am not getting any heat. I have a White-Rodgers manual mercury thermostat model 1F56-501 and natural gas heat with GOODMAN packaged gas/electric model PGB024050-1 Before I call a service rep, I...
Hello,Good job with description.Something is keeping the condenser off(saftey).Do you have an emergency heat setting on the therm.It will run electric heat strips only until service can check it out.Very rare that the disconnect switch (black box) is it.Need electrical meter to prove it out.
Dec 01, 2010 | Goodman Heating & Cooling
WHEN THE HEATER COMES ON THE FAN STARTS INSTANTLY AND BLOWS COLD
Do you have a heat pump? If so this is normal. You are probably used to a gas furnace. There are heat pumps that do have a delay though. Look on the circuit board in the air handler. There may be a set of pins that say 0-30-60-90 yours may be at 0. Also some digital T-stats offer that function for delay off to get the extra heat or cold from the system. Find out what the model number of the air handler and call the Goodman supplier in your area to see if you have these options.
If you have a gas furnace and it's not delaying the blower there is definately something wrong.
Mar 17, 2009 | Goodman Heating & Cooling
Electric furnace won't shut off
It sounds like a bad or badly miswired T-stat
Jan 20, 2009 | Goodman CLQ36AR49 Air Conditioner
Goodman air conditioner not running
2 summers ago, exact same problem with one of our two units outside. contractor that installed the unit when home was built was not helpful and not able to come out. another a/c company explained they would not be able to make it that day, but offered knowledge that often times in my area (San Antonio, TX) ants get into the electrical contacts of the mechanical switch and block the current.
following instructions to trip all the breakers inline and checking this it was confirmed, i cleaned the contacts with pencil erasers (a trick i learned with model car electric leads) and sure enough it's still working 2 years later.
believe it or not the same year my water well had the same symptoms and it turned out to be the mechanical switch was blocked by ants also!
Jun 04, 2008 | Goodman CLQ36AR49 Air Conditioner
Carrier 38CKC036 Air Conditioner Logo
54 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
