Question about Maytag MDE508DA Dryer
Maytag Dryer MDE508DAYW Leaving black marks on clothes
The clothes are getting stuck in the dryer and leaving "scorched" marks. Sometimes they aren't even't stuck but come out with "scorched" marks. Any suggestions on how I can fix the issue? The dryer is only 2 years old.
catriver
  • 878 Answers
SOURCE: Brown marks on clothes
This is a pretty common problem with these Frigidaire dryers. Crice hit it right on the head when he said the clothing is getting stuck between the guides and drum. The upper and lower felt guides need to be changed. This is not one of the easiest jobs. The top and front panel have to come off and the guides are glued on with high temp. adhiesive. The old guides have to be scraped off. Part numbers for the upper and lower guides are 5303937139 -(upper) 5303283286 -(lower). Catriver...post back
Posted on Mar 14, 2007
gittos73
  • 244 Answers
SOURCE: Dryer leaving brown streaks on clothes
the brown streaks and holes will be when they get stuck the dryer is still turning and it will be friction marks if it is getting stuck between the inner and outer drums than check to see if there is any wobble in the inner drum by opening the door and placing your hand at the top of the outer rim of the panel and place your fingers to the top of the inner drum pull your fingers towards your hand if there is any movement than the bearings are gone which will need replacing once done then this will eliminate the problem if there is no movement check to see if there is a seal missing from between the inner and outer drum u can find this out by checking with your fingers than calling the manufacturer to see if there is supposed to be one there
Posted on Aug 20, 2007
agitateme
  • 88 Answers
SOURCE: Dryer is leaving brown streaks on cotton clothes
The 417 dryers have two seals on the front panel, the top seal has drum glides which wear down over time. Because the drum rests on those glides, when it wears down it leaves a gap between the drum and the seal, clothes will drag in that gap and come out with rust and/or seal adhesive stains. Try replacing the top and lower seals, this works most of the time...sometimes though, if left unattended long enough, the lack of support from the front glides causes too much strain on the rear drum bearing, and even after replacing the seals clothes may still catch, although the brown spotting will stop for awhile. You can feel the gap if you run your hand along the inside of the drum at the seal point.
Posted on Jan 17, 2008
Master_Tech
  • 770 Answers
SOURCE: dryer
nothing in the dryer i.e.crayon left in pocket?? there is no black grease used in the unit only White lithium style.. I dont think it came from the inside of the mach ...Best bet is to clean the tub out mild soap and a damp cloth it should go away. if not the peice maybe stuck in the baffles manually spin the drum do you hear anything rattling around?? Let me know
Posted on Jan 26, 2008
  • 67 Answers
SOURCE: Whirlpool Duet Dryer is scorching clothes
there is a sensor in the exhaust line in the dryer, near the motor. this tells the heating element to shut off when it gets to a certain temp, either during reg cycle or if the exhaust gets clogged, it is meant as a safety measure, but it sounds like yours is bad so the heating element never shuts off. it is not an expensive part and easy to replace
Posted on Oct 28, 2008
Maytag Neptune Dryer Not Drying Well, Leaves Brown Marks on Clothing. Seems like there may be multiple problems. Suggestions?
Sounds to me like an air-flow problem. Poor air-flow means dryer gets hot and scorches clothes but there is nowhere for the wet air to go, so it doesn't dry well. Check for lint-clogged ducting from the back of the dryer to the outside (or at least check both ends of the duct). Also check for a collapsed or clogged flexible tube that goes from the dryer to the duct work.
An over-heated dryer could also have warped the (usually) plastic lint filter.
Jan 07, 2015 | Maytag Dryers
Dryer eating clothes
It may be running way too hot. If the filter is clean there may be a thermostat issue.
Mar 19, 2014 | Dryers
Dryer drys great. is leaving black marks on clothes
Are the black marks a result of an ink stain in the drum or is the black marks coming for the dryer seal?
If they are coming from an ink stain then alcohol or hair spray with paper towels will normally get them off the drum.
If the black marks are coming from the seal, that means that the seal is not positioned correctly and would require that the dryer be disassebled and a new seal be installed.
Jun 18, 2011 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag gas dryer about 10 years old leaving black smudge marks on clothing. The wheel was hanging up on the dryer drum. Could there be other causes for the smudge marks?
your clothes are getting caught between the drum and the rim due to bearings out of the wheel guides. These guides are what the drum rests on when it is turning. Most dryers you can access these guides by taking the front off the dryer. Not a big expense just a little difficult to get to .
Apr 12, 2011 | Dryers
Maytag dryer is leaving black marks or rings on clothes
If your clothes get marked or torn in your dryer, check these: Rollers Rear seal Front glides Front seal Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set. Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it. Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set. Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it.
Aug 01, 2010 | Maytag Dryers
Dryer is occasionally leaving rusty looking smudge marks on clothing.
don't open door (stop dryer) until cool-down and dryer stops. many times the heating element is still hot and when you stop the dryer in the middle of the cycle, the rear of the dryer where the heating element is, will scorch your clothes.
Nov 29, 2009 | Frigidaire FGQ332ES Gas Dryer
Dryer is leaving black marks on cloths.
was a pen or crayon placed in the machine by mistake ? You will need to
remove the residue, use rubbing alcohol on a rag for marker or pen ink , crayon use a razor scraper and then clenser and scrunge pad.
Oct 26, 2009 | Fisher and Paykel DE06 Electric Dryer
Brown streak on clothes
It could be from scorching due to getting too hot. This may be the start of a problem for you.
It is best to judge how long clothes need drying for before drying them. If they are left too long, sometimes the heat builds up.
Try a smaller load in there, and if you can reduce the temperature any then do.
Often it's just overloading is the issue.
Hope this is a solution for you, If so, Please rate as Fixya! Thanks.
Jun 18, 2008 | Kenmore Elite HE4 Electric Dryer
Parts of clothes get stuck in edge of dryer...seems to burn them.
I have had this same problem with my stack-able dryer. It was leaving small burns on my kids clothes and my good sheets. My dryer has a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer can get caught and scorched or torn in the space between the clothes drum and the front of the dryer interior. My seal was worn out, so I needed to replace it. I had someone come in and do the work the first time but when it wore out again I just order the part and replaced it myself. It is fixable:)
Apr 07, 2008 | Kenmore 98702 Stacked Washer/Dryer
Dryer
Jan 26, 2008 | Dryers
Dryers Logo
375 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
