Question about RCA RT2250 System
When i push am/fm button i have no sound - RCA RT2250 System
  • cirwin7224 Mar 12, 2009
    yes i unplug it and then the green light on the side come on and then it goes off. everything works fine when that light goes off. ut sometimes the green light comes back on and the sound starts going on and off. so i got to unplug it again to get it to work again.
  • 3 Answers
Have you tried turning if all the way off and back on...like when u reboot your computer.?
Posted on Mar 10, 2009
Programming FM tuner preset buttons
scan for the station when you have the station hold the number button you would like the station to be on in until it flashes when flashing leave and push memory or dont push memory and wait until it stops.
Dec 28, 2013 | Audio Players & Recorders
RADIO CAR CLOCK SCREEN ONLY INDICATING -- -- HOW DO I PUT FIGURES
Try this...it is for the 2000 series but should work for all KDCs:
Hold the "Menu" button for about one second to enter the Kenwood's menu. This button is located on the right side of the faceplate.
Push "AM" or "FM" until the Kenwood's screen shows "Clk Adjust."
Hold the "Right Seek" button for about two seconds. The clock will start to blink. It's now ready to be set.
Push the "AM" button repeatedly to increase the hour. If you want to decrease the hour, push the "FM" button.
Push the "Right Seek" button to increase the minute. Push the "Left Seek" button to decrease the minute. Push "Menu" to set the time.
Sep 21, 2011 | Kenwood KDC-W3037A CD-receiver,...
When listening to the fm tuner on my yamaha htr 6060, will all 7 speakers still make sound? i' having trouble getting sound from the other speaker connections other than the L and R front connection.
analog fm is broadcast in stereo you would need to use a simulated surround setting to have sound come out of your rear and mid surround speakers.
your manual says the default setting for fm broadcast is:
Radio Listening TUNER MUSIC ENHANCER
7ch Enhancer
Select this SCENE template when you enjoy FM or AM
radio programs.
make sure you unit is not in straight mode try pushing the straight button on the front of the receiver let us know if more troubleshooting is needed.
Cheers!
Feb 15, 2010 | Yamaha HTR-6060
I FOLLOWED THE CUSTOMER MANUAL BUT CAN NOT FIND THE FM MODE
i think i have a solution. if it is pretty easy to press that button you are talking about than the button might be jammed.
Jan 04, 2009 | Nextar MA933A MP3 Player
Radio code
If you don't have the radios security code, you can try entering 1111 as some replacement radios were coded with this security code. Your local Audi Dealer may be able to provide the correct security code for your vehicle, if you provide them with your vehicles Identification Number (VIN). This VIN is typically located on the drivers door pillar.
The radio should have a serial number on the unit which also can be given to the Audi dealer and checked in their data base of radio security codes. The serial number will start with AUZ, one radio serial number for example is AUZ1Z9A1965412.
To enter the code on the Wiesbaden Radio: Turn on the radio, SAFE should be displayed.
Push and hold the AM/FM button, then while holding the AM button down, push and hold down the SCAN button. Release the AM/FM and SCAN buttons, and the display should show 1000. Now enter the correct code using the radio pre-set station buttons (1-4). Button 1 changes the first digit in the code "1"000, Button 2 changes the second digit in the code 1"0"00, button 3 changes the third digit, button 4 changes the last digit in the code. In most cases the first digit is a 1 and won't need to be changed. You push each pre-set station button multiple times to step through the digits (1-9) to get the correct code displayed.
Code 1246 would entered by pushing button "2" two times, pushing button 3 four times, and pushing button 4, six times.
After entering the correct security code, push and hold down the AM/FM button, then while holding down the AM/FM button, push and hold down the SCAN button. The display will then show SAFE, release the two buttons, and now the radio should play correctly.
Sep 19, 2008 | 2001 Audi S4
Set frequancy
Mount your Roady 2 in your Truck .Make sure the power is on & the antenna is connected. The middle connection should be open. Push the menu button, you should see FM Frequency at the top.Push the scroll button(Top Right) and you should see FM station numbers. Scroll though the stations and pick a frequency that isnt being used in your area. Push the scroll button in to set the station. The display will show that number set 88.3 set for example. Set the FM Tuner in your truck to the same station. You should be go to go. Good Luck
Dec 18, 2007 | Delphi Roady2 SA10085 XM Radio Receiver...
Onkyo receiver playing in mono only
sounds like a reception problem. Is there a visual meter for the reception? Check your antenna.
Feb 02, 2007 | Onkyo TX-8210 Receiver
RCA RT2250 System Logo
123 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
