Question about Sanyo DS31520 31" TV
On/off - fuse blows out
We have replaced the fuse that goes to on / off button several times over the years. However this time the fuse blows as soon as you turn on tv.
  • mindyme Mar 12, 2009
    it had a 4 amp fuse we tried 5 amp - should we go with an even higher amp ?
  • 59 Answers
Use a higher amp fuse this should solve your problem if its not a electrical fault in the set.
Posted on Mar 10, 2009
My GMC Envoy keeps blowing the 10 amp fuse for the heaters.I unplugged the front blower fan but it still does it. Is the other fan in the consul?
The fuse isn't for blower motor. I saw a fuse 39 and fuse 36 both 10 amp, both for hvac. I don't know which one is blowing? One fuse is for actuator doors under the dash, the other is battery voltage to hvac control module. One is hot all the time, the other goes hot with key on.
What is model year? Does it blow as soon as you turn on the key? Any applicable hvac trouble codes? About all I can do is track wiring circuits.
Nov 08, 2017 | GMC Cars & Trucks
What could it be when put auto in drive suddenly fuse blows under hood?
Which fuse is blowing? Look at a wiring diagram for that fuse circuit. If that fuse only controls one component, the component may be faulty or the wiring circuit has a problem.
If the fuse circuit controls several components, you may need to disconnect/reconnect components one at a time to try and see which component or wiring circuit is faulty. Hopefully when you unplug the faulty component, the fuse will no longer blow. It is possible that test would not be conclusive because every time you unplug something you lower the amp draw on the fuse.
Jun 06, 2015 | 1998 Jeep Cherokee Grand 2WD
Blower motor fuse
always start on a switch when they all they cause that
Nov 13, 2013 | 1998 Mercury Mystique
PCM fuse keeps blowing
It's possible you ran the battery down, trying to start? Have to make sure battery has a full charge and battery connections all good. If battery is down, have to use a charger and get it charged, we can't test anything if battery is down.
I did look at power distribution wiring diagram for your vehicle, I found pcmB fuse--20 amp. Two fuse legs goes to pcm, the other goes to load side of fuel pump relay. If I had to guess, I'd say the fuel pump has a problem. If the wiring before the fuel pump relay or the pcm was the problem, then the fuse would blow as soon as soon as you plug it in. The fuse circuit shows to be hot all the time. Just my opinion. There might be other issues, but, I can't track it from where I am.
Aug 06, 2017 | 2005 GMC Yukon XL
Ignition fuse keeps blowing, sometimes I drive 130 miles till it blows n sometimes 1/4 mile and sometimes as soon az I replace it it blows orther times I put a new fuse in and the fuel pump runs and when I...
I'd replace the fuel gauge sensor as a first thought, however, before doing that, I'd meter the sensor the times that it blows immediately.
You may want to check and see if it blows at a specific fuel level.
Trace the wiring to the fuel guage itself and make sure the wire isn't intermittantly shorting somewhere like where it runs through the headlight (if it does) and where it goes into the fuel gauge (or low fuel light).
You seem to have tracked the problem to the root area and just need to isolate it to the specific area.
Jun 28, 2011 | Harley Davidson FLHRS - FLHRSI Road King...
My ge profile microwave keeps blowing its fuse. i
Don't increase the amp size of the fuse this could cause the wiring to get hot or component to get hot and catch on fire. Is the fuse the main fuse the one that the power cord goes to?
Sep 11, 2009 | Microwave Ovens
DeWalk DC500 wet/dry vaccum doesn't work
Vacuum works with the battery but does not work with 120 volt. Every time I plug it in it blows the internal fuse. I have replaced the fuse inside the vaccum several times and every time i plug it in it blows. What do you think it could be?
Feb 21, 2009 | Dewalt DC500 Canister Wet/Dry Vacuum
Years of good service...now it keeps blowing fuse
The voltage of the fuse is not the issue. It sounds like you may have some blown internal transistors (probably in the output area). Time for a trip to the repair shop I'm afraid.
May 18, 2007 | Sony STR-DE525
Sanyo DS31520 31" TV Logo
97 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
