Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Water freezing up the blower when the icebox is full and spill over water is dripping to it
  • 27 Answers
Defrost the freezer and restart
Posted on Mar 10, 2009
What is the problem when an air conditioner begins to freeze up?
Freezing up is caused by
•dirty air filter or evaporator coil(indoor coil)
•dirty blower wheel or blower fan blades
•low freon
•weak or slow blower motor
If air filter and indoor coil are clean may be low on freon. Blower wheels seldom get dirty on window units. Pull unit from window and clean both coils with a water hose. Careful not to get any electrical wet. Let dry for a while and reinstall. If it continues to freeze its a freon problem most the time.
Jun 23, 2015 | Norpole 5000BTU Mechanical Window Air...
Ice maker water freezes before getting to Ice maker
likely you have a bad water valve where the water goes into the fridge. The valve is not sealing all the way and the water is dripping even when it closes allowing the water to freeze up
May 17, 2012 | Frigidaire Refrigerators
I do not believe the other advisor understand my problem. I have a GE Profile Arctica refrigerator PSS25NGMDBB. The problem is the cup fill (GE part name) is frozen and full of ice. So when the ice...
You are right. The water inlet valve is leaking a small drip and it freezes when it reaches the cold air in the freezer at the fill tube. Melt the ice in the tube with a hairdryer and replace the water inlet valve. It's on the back where the water supply connects to the back.
Feb 22, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
The refrigerator is warm
could be your compressor going out. how old is the fridge.make sure that was water and not freon check your coils unde the fridge see if there really warm. and most people don't clean these out so the icebox has to work harder.
Apr 14, 2010 | Whirlpool ET8MHEXR Top-Mount Refrigerator...
After the ice maker fills up with water more water spills out of it and freezes all the ice cubes together
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Mar 07, 2010 | Refrigerators
Ice maker leaking water into the bottom of icebox
Aug 29, 2009 | KitchenAid Refrigerators
Makes ice for three days, water drips to fan, freezing up,
there is a device like a switch that makes the icemaker stops the solenoid valve of the water intake, u should check that switch...
Mar 09, 2009 | GE Profile PSW26P Stainless Steel Side by...
Water dripping inside refrigerator
the defoost drain is cloged the drain inlet is located in the freezer behind the back wall under the coils. to clear the drain remove the back wall in the freezer and clear the ice underneth the coils then use hot water to clear the drain inlet, I use a garden sprayer to spray hot water.
Dec 24, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Ice maker freezes up and drips water
I am assuming you have the ice maker that the tray twists to release the ice. There is a new tray out with a wall to prevent the water spilling over. The part number is
3390JA1150A
Sgt 48
Mar 09, 2008 | LG LRSC26980 Refrigerator
Ariston fridge freezer - drips water
I'm afraid if the door isn't sealing properly and staying cold then the ice will always be melting somewhat and dripping. Is there ANY way to glue/epoxy/fiberglass that part back on or repair the door, etc.? If you can't get repair parts either you may be stuck with a broken cooler. It seems like some shop (boat shop, auto bodyshop, etc.) should be able to repair those items with fiberglass or something. I guess it just depends on the cost to repair verses to buy new again.
Jan 23, 2007 | Ariston Technologies CBC96 Wine Cooler...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
53 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
